[mpich-discuss] MPICH2-1.1.1p1 Cygwin Install On Vista
Andy Newman anewman at atmos.colostate.edu
Fri Aug 28 12:07:59 CDT 2009
Hi all,
I'm new to MPI and I've been trying to install MPICH2-1.1.1p1 on a
32-bit Windows Vista Home Premium dual core Dell laptop with Cygwin,
Cygwin.dll version 1.5.25-15.  I've been able to configure, make and
install a version of MPICH2.  Also, the make installcheck runs
successfully for all tests except the three logging library steps.  I've
also been able to run most of the checks in the install guide.  I can
start and successfully complete the "mpdcheck -s" and "mpdcheck -c"
step.  I can also run "mpiexec -n 4 /bin/hostname.exe" and "mpiexe -n 1
PATH_TO_MPICH2_EXAMPLES/icpi.exe".  However when I try to run "mpiexe -n
2 PATH_TO_MPICH2_EXAMPLES/icpi.exe"  I receive the following output:
Fatal error in MPI_Init: Other MPI error, error stack:
MPIR_Init_thread(394)................: Initialization failed
MPID_Init(118)...........................: channel initialization failed
MPIDI_CH3_Init(43)..................:
MPID_nem_init_chpt(213).........:
MPIDI_CH3I_Seg_commit(388):
MPIU_SHMW_Seg_detach(744): unable to remove shared memory - unlink
permission denied
rank 0 in job 12 Andy-laptop_49669 caused collective abort of all ranks
exit status of rank 0: return code 1
The configure options I used are:
./configure --prefix=/usr/local/mpich2 CC="gcc-4" CPP="cpp-4"
CXX="g++-4" CXXCPP="cpp-4" F77="gfortran-4" F90="gfortran-4" --with-mpe
--enable-mpe --with-thread-package=posix --enable-threads=default
--enable-romio --enable-f77 --enable-f90 --enable-cxx
--enable-timer-type=gettimeofday --enable-smpcoll
I have the sshd, cygserver and portmap process running, have configured
ssh for public key authentication and run the Cygwin terminal as an
administrator.  The CYGWIN environment variable is set to CYGWIN=ntsec
server
I have also attached configure, make, make install and make installcheck
log files for anyone who is interested.  I'm at a loss on this.  Any
help would be greatly appreciated!
Thanks a bunch!
Andy
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090828/fbd6ea17/attachment-0004.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090828/fbd6ea17/attachment-0005.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090828/fbd6ea17/attachment-0006.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090828/fbd6ea17/attachment-0007.bin>
