[mpich-discuss] Hydra issues
    Scott Atchley
    atchley at myri.com
    Wed Aug 26 15:09:42 CDT 2009
No, the ring starts fast enough. It is connecting 1024 processes that
is slow (allgatherv).
By contrast, Intel MPI launched in < 10 seconds.
Scott
On Aug 26, 2009, at 4:07 PM, Rusty Lusk wrote:
> I assume that you mean launching the MPD ring is slow.  Once the MPD
> ring is up, launching should be quick.   The original idea was that
> the MPD ring would be persistent across jobs, even from different
> people, as long as the jobs used the same nodes.
> Rusty
> On Wednesday,Aug 26, 2009, at 2:45 PM, Scott Atchley wrote:
>> On Aug 26, 2009, at 3:39 PM, Pavan Balaji wrote:
>>>>> However you could use one of the various workarounds for this,
>>>>> such as an LD_PRELOADed setvbuf call: http://lists.gnu.org/archive/html/bug-coreutils/2008-11/msg00164.html
>>>> This does not change the behavior.
>>>> I am still stumped as to why there is no delay when using
>>>> persistent (launch-mode=2) versus a delay with no proxies (launch-
>>>> mode=1).
>>> This works for me. We need to figure out how to make this portable
>>> now.
>>> -- Pavan
>> Thanks for your persistence (no pun intended).
>> When running with 1,024 ranks, launching via MPD can take several
>> minutes. I am assuming that hydra will launch in seconds.
>> Scott
