[mpich-discuss] Hydra issues
    Scott Atchley
    atchley at myri.com
    Wed Aug 26 15:08:37 CDT 2009
On Aug 26, 2009, at 3:58 PM, Dave Goodell wrote:
> On Aug 26, 2009, at 2:45 PM, Scott Atchley wrote:
>> On Aug 26, 2009, at 3:39 PM, Pavan Balaji wrote:
>>>>> However you could use one of the various workarounds for this,
>>>>> such as an LD_PRELOADed setvbuf call: http://lists.gnu.org/archive/html/bug-coreutils/2008-11/msg00164.html
>>>> This does not change the behavior.
>>>> I am still stumped as to why there is no delay when using
>>>> persistent (launch-mode=2) versus a delay with no proxies (launch-
>>>> mode=1).
>>> This works for me. We need to figure out how to make this portable
>>> now.
>>> -- Pavan
>> Thanks for your persistence (no pun intended).
>> When running with 1,024 ranks, launching via MPD can take several
>> minutes. I am assuming that hydra will launch in seconds.
> MPD launches shouldn't be that slow in 1.1.1p1, at least for most
> common process layouts.  Are you still seeing slow MPD launches with
> 1.1.1p1 (as opposed to 1.1.0)?
> -Dave
Yes. A customer and I were running tests over 128 nodes with 8 ppn. I
will have access to another cluster next week to test more. We were
running IMB allgatherv so it requires all processes to connect up.
Scott
