[mpich-discuss] Hydra issues
Dave Goodell
goodell at mcs.anl.gov
Wed Aug 26 12:38:57 CDT 2009
On Aug 26, 2009, at 9:19 AM, Dave Goodell wrote:
> On Aug 26, 2009, at 8:58 AM, Scott Atchley wrote:
>> Ok, I was not patient enough. If I let it run, it eventually
>> starts. The actual walltime is nearly the same as when I use
>> proxies, but the stdout is delayed until the application completes.
> I think I know why this happens. It ought to be fixed once I finish
> up some Hydra I/O work that was mostly done by one of our students
> this summer. The work is basically done and lives on a development
> branch but it needs a little bit of cleanup and to be rebased onto
> the current trunk.
I was mistaken on this particular issue. There was another buffering
issue that we ran into during the student's work and I was thinking of
that one. There isn't any current hydra-side fix for this that I know
of.
However you could use one of the various workarounds for this, such as
an LD_PRELOADed setvbuf call: http://lists.gnu.org/archive/html/bug-coreutils/2008-11/msg00164.html
With a little thought and man page reading someone could probably come
up with the Mac equivalent if that were also needed.
DYLD_INSERT_LIBRARIES is the equivalent of LD_PRELOAD on Darwin, IIRC.
We could also maybe include this workaround approach in hydra via a
command-line option (for platforms where it is possible).
"mpiexec.hydra --disable-output-buffering ..." or some such option.
-Dave
