[mpich-discuss] MPI_File_write_at_all issue
    Rob Latham
    robl at mcs.anl.gov
    Wed Aug 26 11:00:33 CDT 2009
On Tue, Aug 25, 2009 at 10:27:49AM -0500, Mohamad Chaarawi wrote:
> I have attached the test case, which basically creates a file view in a
> way where each process writes/reads 4 integers 4 times.
> In a 2 process scenario the file view is:
> (PROC 0 --> 4 ints)(PROC 1 --> 4 ints)(PROC 0 --> 4 ints)(PROC 1 --> 4
> ints)(PROC 0 --> 4 ints)(PROC 1 --> 4 ints)(PROC 0 --> 4 ints)(PROC 1
> --> 4 ints)
> When using MPI_File_write_at_all with an offset of 16 (which means 16*4
> = 64bytes) since the etype used to create the file view is an int, and
> each process writing 16 integers, I would expect the size of the file to
> be 256, since each process is starting to write 16 integers into the
> file view, or basically skipping one iteration of the file view into the
> file.. however Im getting a file size of 240.
> Im not sure if Im misunderstanding the way write_at_all works or there
> is some bug somewhere..
I think what you have done here is that you have forgotten the rules for tiling of MPI file types.
When you skip over 16 ints, you skip over 16 ints as given by
the struct type you created, or one entire struct type.  Now we place
the next ints based on the 2nd iteration of the tiled type.
This is tricky, but important:  when tiling types, the only thing that
matters is the lower bound and upper bound.   The LB for rank 0 is 0
and the UB is 128.  The LB for rank 1 is 16 and the UB is also 128.
(you can confirm this with a call to MPI_TYPE_GET_EXTENT )
As soon as you tile this type, you will have un-done the careful
placement you tried to achieve, and actually end up with rank 0 and
rank 1 writing to the same offsets.
You have created a struct type with an MPI_UB, so just add an MPI_LB
in your struct declaration.
==rob
Rob Latham
Mathematics and Computer Science Division
Argonne National Lab, IL USA
