[mpich-discuss] Hydra issues
    Pavan Balaji
    balaji at mcs.anl.gov
    Tue Aug 25 20:48:19 CDT 2009
Scott,
Are you using Hydra from mpich2-1.1.1p1? Are other programs running fine?
Darius just noticed the problem with the persistent proxies dying on
mpiexec aborts as well. I'll fix it soon-ish.
  -- Pavan
On 08/25/2009 02:37 PM, Scott Atchley wrote:
> Hi all,
> I tried using Hydra to launch 16 processes (2 hosts, 8 ppn). All I see is:
> $ /usr/bin/time -p mpiexec.hydra -binding none -f hosts -n 16
> -print-rank-map $PWD/IMB-MPI1.mpich2-mx -npmin 16
> Warning: Permanently added the RSA host key for IP address '10.125.1.53'
> to the list of known hosts.
> Warning: Permanently added the RSA host key for IP address '10.125.1.76'
> If I use the persistent proxies _or_ if I call IMB with just pingpong
> (or any other test alone), however, it works fine.
> Separately, if I kill a mpiexec.hydra running with persistent proxies,
> the proxies also die. Is this expected?
> Scott
Pavan Balaji
http://www.mcs.anl.gov/~balaji
