[mpich-discuss] Installation problems: More details
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Thu Aug 20 10:43:44 CDT 2009
  To run your MPI job across machines you need to make sure that all the
machines have the same version of MPICH2 (However your current pblm is not
that...).
  Try uninstalling MPICH2 manually (from Add/Remove programs) on all the
systems ? Install MPICH2 1.1.1p1 on all the systems. Let us know if it
works.
(PS: Always try to make a restore point before manually editing your
registry entries, http://support.microsoft.com/kb/322756. Meanwhile, you
should find MPICH related entries in the following reg directories,
HKEY_LOCAL_MACHINE\SOFTWARE\MPICH
HKEY_LOCAL_MACHINE\SOFTWARE\MPICH2
HKEY_CURRENT_USER\SOFTWARE\MPICH
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ =>
This directory will contain a directory (a unique GUID) containing MPICH2
uninstall info.
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Service\mpich2_smpd
Jayesh
-----Original Message-----
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Hiatt, Dave M
Sent: Wednesday, August 19, 2009 6:15 PM
Subject: [mpich-discuss] Installation problems: More details
I tried uninstalling and reinstalling on the one remaining working system,
and now both exhibit the same problem and message as stated below.  It
appears that there could be an issue with uninstalling and trying to
reinstall 1.1.  Right now I just need some way out of this fix.
[mailto:mpich-discuss-bounces at mcs.anl.gov]On Behalf Of Hiatt, Dave M
[CH-REL]
Sent: Wednesday, August 19, 2009 5:37 PM
I had MPICH2 1.07 up and running between a set of test machines with no
problems.  But thanks to local IT staff, one of my systems was trashed and
had to be reimaged from ground 0.  I downloaded version 1.1 and installed
it, but was having communication problems between the system on 1.07 and
1.1, so I decided to install 1.1 on the system that had not been touched.
I believe I actually installed it twice.  The first time seemed to go ok,
but and mpiconfig would show green around the two hosts names for a short
while, but then drop.  In all the checking and rechecking, I came to doubt
I had installed the 1.1 on one of the systems and installed it again.
When the installation started the 2nd time, I asked if I wanted to repair
or uninstall MPI, so I decided to start from scratch again, and said
uninstall.  When that completed I started the install again, but now it
always fails at the very end, with the message
"Three is a problem with this Windows Installer package.  A program run as
part of the setup did not finish as expected.  Contact your support
personnel or package vendor".  Of course all of this would happen three
days before a major release and has brought my testing to a total halt.
Any help would be greatly appreciated.
I deleted everything and culled through the registry and deleted anything
that had mpich on it, but to no avail.  Where should I look for a
diagnostic on what the run that failed has a problem with?
Desperate in St. Louis
"Premature optimization is the root of all evil" - Donald Knuth Dave Hiatt
Manager, Market Risk Systems Integration CitiMortgage, Inc.
1000 Technology Dr.
Third Floor East, M.S. 55
O'Fallon, MO 63368-2240
Phone:  636-261-1408
Mobile: 314-452-9165
FAX:    636-261-1312
Email:     Dave.M.Hiatt at citigroup.com
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090820/64937ca8/attachment-0001.htm>
