[mpich-discuss] nemesis
    shenqian at tsinghua.org.cn
    Sun Aug 16 23:47:28 CDT 2009
Hi Rajeev,
I run "make testing" in the top-level mpich2-1.1.1 directory, got many many errors! Indeed, there are 94 tests failed against the all 553 tests in the summary.xml. My configure options are:
./configure --prefix=/opt/mpich2-install --with-device=ch3:nemesis:mx  --with-mx-lib=/opt/open-mx/lib/ --with-mx-include=/opt/open-mx/include/ --enable-sharedlibs=gcc
I also build mpich2-1.1.1 with the default settings, and run "make testing" in the top directory . The all 553 test passed! No fail in summary.xml.
So is it really that Nemesis/MX is compatible with Open-MX? Or are there any missing options for configure?
Qian Shen
> You can also run "make testing" in the top-level mpich2 directory. It
> will run the entire test suite in test/mpi. If they run, it would
> indicate there is something wrong with your program.
> Rajeev
> > -----Original Message-----
> > From: mpich-discuss-bounces at mcs.anl.gov
> > [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of
> > Sent: Sunday, August 16, 2009 8:54 AM
> > To: mpich-discuss at mcs.anl.gov
> > Subject: Re: [mpich-discuss] nemesis
> > Hi Guillaume,
> > Thanks for your response.
> > Because the program is another company's property, I can't
> > send it to you :-(  If I can reproduce it with my own
> > program, I will send it to you as soon as possible.
> > I'm trying to using Nemesis/MX on top of open-mx for high
> > performance. I got a good performance improvement by using
> > open-mx instead of TCP/IP, but the hang problem at
> > MPI_Barrier() puzzles me these days. Would you tell me some
> > way to debug it?
> > Thanks,
> > Qian Shen
> > > Hello,
> > > Yes, Nemesis/MX is supposed to be compatible with Open-MX.
> > Could you
> > > sent me your example program so that I can find out what is the
> > > problem?
> > > Thanks.
> > > Guillaume
> > > shenqian at tsinghua.org.cn a écrit :
> > > > Hi,
> > > > I build mpich2-1.1.1 on top of open-mx-1.1.1, and have
> > ch3:nemesis:mx enabled. Nemesis/MX should be compatible with
> > Open-MX, isn't it? I test the examples shipped by mpich2,
> > they work well. But my MPI program always hang on
> > MPI_Barrier(). The output messages are:
> > > > Open-MX: Send request (seqnum 105 sesnum 0) timeout, already sent
> > > > 1001 times, resetting partner status
> > > > Open-MX: Cleaning partner 00:11:09:5b:7d:16 endpoint 0
> > > > Open-MX: Dropped 1 pending send requests to partner
> > > > It seems like that the requests can not be send to other
> > nodes. If I switch to the traditional TCP/IP stack, use the
> > ch3:nemesis device, the program can run successfully.
> > > > Could anyone tell me how to handle this issue?
> > > > Regards,
> > > > Qian Shen
