[mpich-discuss] mpich-discuss Digest, Vol 11, Issue 8
    Dorian Krause
    ddkrause at uni-bonn.de
    Wed Aug 12 08:44:45 CDT 2009
if you create outvector like
vector<int> ourvector(2);
and than push_back "99" the vector will look like
{ 98, (whatever), 99}
Try to do call the constructor
vector<int> ourvector(1);
Then you should (If I understand the stl correctly) end up with
{ 98, 99 }
as you intend.
Hope this helps ...
Dorian
Vineet Pratap (Vampaier) wrote:
> Plz Correct this code................
> #include<iostream>
> #include<vector>
> #include "mpi.h"
> using namespace std;
> int main(int argc, char *argv[])
>         MPI::Status status;
>         MPI::Init();
>         int myrank = MPI::COMM_WORLD.Get_rank();
>         int numprocs = MPI::COMM_WORLD.Get_size();
>         if(myrank == 0){
>         ourvector[0] = 98;
> //      cout << "The max number the vector can hold is : " <<
> ourvector.max_size();
> //      cout << "\nourvector has : " << ourvector.capacity() << "
> elements in it";
>         ourvector.push_back(99);
> //      cout << "\nNow ourvector has : " << ourvector.size() << "
> elements in it";
> //      cout << "\nThe Value of the first vector element is : " <<
> ourvector[0];
> //      cout << "\nThe Value of our second vector element is : " <<
> ourvector.at(1) << endl;
>          MPI::COMM_WORLD.Send(&ourvector[0],2,MPI::INT, 1, 1);
>         // MPI::COMM_WORLD.Send(&ourvector[1],1,MPI::INT, 1, 1);
>         else{
>         ourvector.reserve(2);
>        MPI::COMM_WORLD.Recv(&ourvector[0],2, MPI::INT,0,1);
>         // MPI::COMM_WORLD.Recv(&ourvector[1],1, MPI::INT,0,1);
>         //ourvector.pop_back();
>         cout << "ourvector now has : " << ourvector.capacity() << "
> elements" <<  endl;
>       cout << "\nNow ourvector has 1st : " << ourvector[0];
>         cout << "\nNow ourvector has 2nd : " << ourvector[1]<< endl;
> //      cout << "Our fisrt element in ourvector is : " <<
> ourvector.front() << endl;
>         ourvector.resize(9);
>         ourvector.at(8)  = 99;
> //      cout << "Our last element in ourvect is : " <<
> ourvector.back() << endl;
> //      cout << "ourvector now holds : " << ourvector.size() << "
> elements" << endl;
>       MPI::Finalize();
>         return 0;
> } <http://trac.guake-terminal.org/files/>
> Now MY output is
> $ mpirun -np 2 ./vec.out
> ourvector now has : 2 elements
> Now ourvector has 1st : 98
> Now ourvector has 2nd :0
> I want output like <http://trac.guake-terminal.org/files/>
> Now ourvector has 2nd :99
