[mpich-discuss] Problem with mpi and mcnpx
    chan at mcs.anl.gov
    chan at mcs.anl.gov
    Mon Aug 10 13:56:31 CDT 2009
I was under the impression that you were able to build mpich2 already.
Can you send me your configure and make outputs as seen on your terminal
(as stated in README for bug reporting) ?  I need the outputs to make sure
that your mpich2 is installed correctly.
Also, assume you have mpich2 installed correctly, then you
need to recompile (or reconfigure) mcnpx with it before you
launched the application.
A.Chan
----- "Arthur Adkins" <aaa1156 at ufl.edu> wrote:
> Anthony,
> These are the flags I am setting when I run the configure script for
> mpich2 are these correct?
> ./configure cc=gcc fc=ifort f90=ifort --prefix=/opt/mpichinstall
> Arthur
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of
> chan at mcs.anl.gov
> Sent: Monday, August 10, 2009 1:44 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] Problem with mpi and mcnpx
> mpich2's README or the install.pdf/user.pdf in
> <mpich2-install-dir>/share/doc should contain
> the steps to start mpich2 job. e.g.
> mpdboot -n <number-of-nodes> -f nodenames.txt
> mpiexec -n <number-of-process> <executable_name>
> There are a lot more details in the documentation
> that covers the different scenarios.
> A.Chan
> > Hey Anthony,
> > It appeared when I installed mpich2 on the computer it worked
> alright
> > but when I tried to run mcnpx I received an error.  I think I am
> still
> > not sure on how to start mpich2 on the head computer along with all
> of
> > the slave nodes.  Do you know how to do this? Thanks
> > Arthur
> > [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Anthony
> Chan
> > Sent: Saturday, August 08, 2009 12:54 AM
> > If you get p4 error, that means you are using mpich1.
> > I thought you were able to use mpich2 ?  What command you
> > used that got the p4 error ?
> > A.Chan
> > ----- "ARTHUR AVERY ADKINS" <aaa1156 at ufl.edu> wrote:
> > > When trying to run a program called mcnpx with mpi I continually
> > > get a p4 error and then it will not run.  Does anyone know why
> > > this is and what I can do in order to fix it or try to fix it?
> > > Arthur
