[mpich-discuss] Problem with mpi and mcnpx
    chan at mcs.anl.gov
    chan at mcs.anl.gov
    Mon Aug 10 12:43:47 CDT 2009
mpich2's README or the install.pdf/user.pdf in
<mpich2-install-dir>/share/doc should contain
the steps to start mpich2 job. e.g.
mpdboot -n <number-of-nodes> -f nodenames.txt
mpiexec -n <number-of-process> <executable_name>
There are a lot more details in the documentation
that covers the different scenarios.
A.Chan
----- "Arthur Adkins" <aaa1156 at ufl.edu> wrote:
> Hey Anthony,
> It appeared when I installed mpich2 on the computer it worked alright
> but when I tried to run mcnpx I received an error.  I think I am still
> not sure on how to start mpich2 on the head computer along with all of
> the slave nodes.  Do you know how to do this? Thanks
> Arthur
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Anthony Chan
> Sent: Saturday, August 08, 2009 12:54 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] Problem with mpi and mcnpx
> If you get p4 error, that means you are using mpich1.
> I thought you were able to use mpich2 ?  What command you
> used that got the p4 error ?
> A.Chan
> ----- "ARTHUR AVERY ADKINS" <aaa1156 at ufl.edu> wrote:
> > When trying to run a program called mcnpx with mpi I continually
> > get a p4 error and then it will not run.  Does anyone know why
> > this is and what I can do in order to fix it or try to fix it?
> > Arthur
