[mpich-discuss] please Help me............
Dorian Krause
ddkrause at uni-bonn.de
Thu Aug 6 13:32:52 CDT 2009
Hi Vineet,
what is the template parameter of your vector? If it is just a double or
float or another pod type you can safely do
MPI_Send(&vec[0], ...)
On the receive side you would have to probe the incoming message using
MPI_Probe - Retrieve the message length from the status variable and
then call
vec.resize(...)
MPI_Recv(&vec[0], ...)
Note that boost::MPI
(http://www.boost.org/doc/libs/1_39_0/doc/html/mpi.html) allows you to
send a vector without such "tricks".
Hope this helps.
Dorian
Vineet Pratap wrote:
> Respected Sir,
> i am Vineet Pratap and new in MPI Programming.
> my problem is How to send/recv a C++ STL vector with MPI?
> my STL vector is object type.
> Please reply me if there is a way to do it..............
> Thanks to you..
> Vineet Pratap
> Yahoo! recommends that you upgrade to the new and safer Internet
> Explorer 8
> <http://in.rd.yahoo.com/tagline_ie8_1/*http://downloads.yahoo.com/in/internetexplorer/>.
