[mpich-discuss] Fatal error in MPI_Init
    Luiz Carlos da Costa Junior
    lcjunior at ufrj.br
    Wed Aug  5 16:38:35 CDT 2009
I could make the program work, but there are some points I still would like
to clarify.
The problem is that my program also links to another library using its dll
file. However, in my development environment, these dll's are not placed in
the same directory where I build my application. Actually, I keep these
dll's in the library's installation directory and my PATH environment
variable points to this folder.
I could just figure out of the problem because I was trying to reduce my
applications size and, in order to do that, I replaced many of the
subroutines by dummy ones. When I disabled my part of the code related to
the second library, it worked.
So, the solution I found was to copy the needed dll's to my application's
folder. But I'm not so comfortable with this because this scheme had always
worked, even with MPICH1 (i.e., when I link and run my application with
MPIRUN).
Is such behavior expected? Why does mpiexec work differently from mpirun?
Any mistake from my side?
Another point is that I use to include 'mpif.h' in my Fortran routines that
use MPICH2 and, I link my application with mpich2.lib and fmpich2.lib, which
are the import libraries I have created from mpich2.dll and fmpich2.dll,
using OpenWatcom "wlib" utility.
I didn't know that the correct library to use was mpich2mpi.dll. Sorry for
the question, but what are the differences?
As I could make it run with mpich2.dll and fmpich2.dll, what kind of errors
may I expect?
Thanks again.
LC
2009/7/28 Jayesh Krishna <jayesh at mcs.anl.gov>
>  Hi,
> >> create library files from mpich2.dll and fmpich2.dll (distributed with
> MPICH2 setup),
>   How are you creating lib files from the dlls (In any case you should be
> using mpich2mpi.dll instead of mpich2.dll)?
> >> compile all my code with the MPICH2 libraries
>   Are you compiling your code with the libraries distributed with MPICH2 ?
> Or are you using the libs created by you ?
> >> run my code using "mpiexe -host hostname -n N myapplication"
>   Can you run your code on the localhost (Does "mpiexec -n N myapplication"
> work ? )?
> Regards,
> Jayesh
> *From:* lccostajr at gmail.com [mailto:lccostajr at gmail.com] *On Behalf Of *Luiz
> *Sent:* Monday, July 27, 2009 8:06 PM
> *To:* Jayesh Krishna
> *Cc:* mpich-discuss at mcs.anl.gov
> *Subject:* Re: [mpich-discuss] Fatal error in MPI_Init
> Hi Jayesh,
> I compile my code with OpenWatcom compiler.
> The procedure I use is:
>    1. create library files from mpich2.dll and fmpich2.dll (distributed
>    with MPICH2 setup),
>    2. compile all my code with the MPICH2 libraries
>    3. run my code using "mpiexe -host hostname -n N myapplication"
> I had already used procedure successfully before, but I don't know what is
> happening now.
> I have tried with MPICH2 versions 1.0.8 and the newer one 1.1.1, but the
> error is the same.
> I also tried to repeat this procedure on a computer without MPI's
> installation, but I got the same.
> As I told before, I'am able to run CPI and also non-MPI programs.
> Any clue that can help me?
> Thanks
> 2009/7/27 Jayesh Krishna <jayesh at mcs.anl.gov>
>>  Hi,
>>  Did you recompile your code with MPICH2 ? Which version of MPICH2 are you
>> using ? How are you launching your MPI job (the command used to launch your
>> job) ? Are you able to run non-MPI programs (Does "mpiexec -n 2 hostname"
>> work ?)?
>> (PS: The error message)
>> Regards,
>> Jayesh
>> *From:* mpich-discuss-bounces at mcs.anl.gov [mailto:
>> mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of *Luiz Carlos da Costa
>> Junior
>> *Sent:* Friday, July 24, 2009 10:56 PM
>> *To:* MPICH Discuss
>> *Subject:* [mpich-discuss] Fatal error in MPI_Init
>>   Dears sirs,
>> I got the following message when I tried to run my code under Windows XP:
>> Fatal error in MPI_Init: Other MPI error, error stack:
>> MPIR_Init_thread(394): Initialization failed
>> MPID_Init(90)........: channel initialization failed
>> MPID_Init(357).......: PMI_Init returned -1
>> [0] PMI_Init failed: FAIL - init called when another process has exited
>> without calling init
>> job aborted:
>> rank: node: exit code[: error message]
>> 0: amsterdam: 1: Fatal error in MPI_Init: Other MPI error, error stack:
>> 1: amsterdam: -1073741515
>> 2: amsterdam: -1073741515
>> 3: amsterdam: -1073741515
>> 4: amsterdam: -1073741515
>> This software can be compiled against Linux (using Intel) and Windows
>> (using Open Watcom).
>> Under Linux, it works normally.
>> Under Windows, I got the message above.
>> SMPD seems to be ok once the distributed CPI program works normally.
>> If I link my code with MPICH1-1.2.6 and run with "mpirun", it also works
>> fine.
>> The weird thing is that I could already make it work with
>> MPICH2/Windows/Open Watcom.
>> Do you have any clue regarding the reason of this error?
>> What can I be doing wrong?
>> Thanks in advance,
>> LC
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090805/c65abcd6/attachment.htm>
