[mpich-discuss] basic datatype for MPI_Offset
Wei-keng Liao
wkliao at ece.northwestern.edu
Tue Apr 28 12:46:32 CDT 2009
Hi, Rob,
I found that every time I build mpich2-1.0.8p1 or its
romio subtree separately, the ADIO_OFFSET is always defined to
MPI_DOUBLE instead of MPI_LONG_LONG_INT. Can you check
romio/configure? I think something is not right there.
The machine I used is a Linux
Linux 2.6.23.9-85.fc8 #1 SMP x86_64 x86_64 x86_64 GNU/Linux
I am using gcc 4.1.2
Wei-keng
On Apr 27, 2009, at 8:22 AM, Rob Latham wrote:
> And if you are hacking ROMIO, there are preprocessor macros so that
> you can use 'ADIO_OFFSET' as the MPI type and the preprocessor will
> replace it with a big-enough type.
> ==rob
> Rob Latham
> Mathematics and Computer Science Division
> Argonne National Lab, IL USA
