[mpich-discuss] Running one MPI program from another
Jayesh Krishna
jayesh at mcs.anl.gov
Fri Apr 24 08:57:06 CDT 2009
Great... Let us know if you need any help.
Jayesh
_____
Sent: Friday, April 24, 2009 8:50 AM
To: Jayesh Krishna
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [mpich-discuss] Running one MPI program from another
Jayesh
The environment block was the problem. I've included a modified version of
the test program that works. I've also made the mod in my actual
application and works OK .
Thanks for your help, much appreciated.
Rod
#include "stdafx.h"
#include "Userenv.h"
#include <afx.h>
#include "mpi.h"
int run_program( char * program )
STARTUPINFO si;
PROCESS_INFORMATION pi;
LPVOID env = NULL;
CreateEnvironmentBlock(&env, NULL, FALSE);
ZeroMemory( &si, sizeof(si) );
si.cb = sizeof(si);
ZeroMemory( &pi, sizeof(pi) );
if( !CreateProcess( NULL, // No module name (use command line)
program, // Command line
NULL, // Process handle not inheritable
NULL, // Thread handle not inheritable
FALSE, // Set handle inheritance to FALSE
CREATE_UNICODE_ENVIRONMENT, // Created environment
block contains unicode
env, // Use created environment block
NULL, // Use parent's starting directory
&si, // Pointer to STARTUPINFO structure
&pi ) // Pointer to PROCESS_INFORMATION structure
return -1;
WaitForSingleObject( pi.hProcess, INFINITE );
CloseHandle( pi.hProcess );
CloseHandle( pi.hThread );
return 0;
int main(int argc, char* argv[])
MPI_Init(NULL,NULL);
run_program("prog");
MPI_Finalize();
return 0;
----- Original Message -----
From: Jayesh <mailto:jayesh at mcs.anl.gov> Krishna
To: 'Rod Cook' <mailto:rod at cookies.demon.co.uk>
Sent: Thursday, April 23, 2009 3:53 PM
Subject: RE: [mpich-discuss] Running one MPI program from another
Since you are passing in a NULL value for the environment block the new
process created is inheriting the environment from the parent (since this
environment includes the runtime env for an MPI process it should not be
shared among two MPI processes). This could be your problem. Can you try
passing a dummy environment block instead of NULL in CreateProcess() ?
Jayesh
_____
Sent: Thursday, April 23, 2009 3:42 AM
To: Jayesh Krishna
Jayesh
Using "mpiexec -n 1 prog" doesn't work.
Cheers
Rod
Sent: Wednesday, April 22, 2009 8:38 PM
Subject: [mpich-discuss] Running one MPI program from another
Try launching "mpiexec -n 1 prog" instead of "prog" with CreateProcess().
Let us know if it works for you.
Jayesh
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Rod Cook
Sent: Wednesday, April 22, 2009 10:12 AM
To: Jayesh Krishna
Jayesh,
I can get my example code to work using MPI_Comm_spawn but it doesn't work
for my actual application. The problem with using MPI_Comm_spawn is that I
don't know how to tell that the spawned program has finished -- this is
why I used CreateProcess because it is possible to wait for the program to
terminate. The spawned program could be a non MPI executable or a
standalone MPI executable which can't communicate with the program calling
MPI_Comm_spawn.
Cheers,
Rod
To: 'Rod Cook'
Sent: Wednesday, April 22, 2009 3:40 PM
Did you try MPI_Comm_spawn() ?
Jayesh
Sent: Wednesday, April 22, 2009 7:50 AM
I am trying to run an MPI program (prog) from another MPI program (test)
using CreateProcess under Windows XP. I am using MPICH2 v1.08.
Source for test
#include "stdafx.h"
#include <afx.h>
#include "mpi.h"
STARTUPINFO si;
si.cb = sizeof(si);
if( !CreateProcess( NULL, program, NULL, NULL, FALSE, 0, NULL, NULL,
&si, &pi ) )
return -1;
return 0;
MPI_Finalize();
return 0;
Source for prog
#include "stdafx.h"
#include "mpi.h"
MPI_Init( NULL, NULL );
MPI_Finalize();
return 0;
I get the following error when I run test:
>mpiexec -n 1 test
MPIDU_Sock_post_connect failed.
[0] PMI_ConnectToHost failed: unable to post a connect to Yellowtail
yellowtail
:2057, error: Unknown error class, error stack:
MPIDU_Sock_post_connect(1228): unable to connect to Yellowtail yellowtail
on port 2057, exhausted all endpoints (errno -1)
MPIDU_Sock_post_connect(1275): unable to connect to on
port 2057,
No connection could be made because the target machine actively refused
it. (er
rno 10061)
MPIDU_Sock_post_connect(1275): unable to connect to yellowtail on port
2057, No
connection could be made because the target machine actively refused it.
(errno
10061)
MPIDU_Sock_post_connect(1275): unable to connect to Yellowtail on port
2057, No
(errno
10061)
uPMI_ConnectToHost returning PMI_FAIL
[0] PMI_Init failed.
Fatal error in MPI_Init: Other MPI error, error stack:
MPIR_Init_thread(294): Initialization failed
MPID_Init(83)........: channel initialization failed
MPID_Init(334).......: PMI_Init returned -1
In my actual application prog is either a standalone MPI program which I
can't change or a non MPI program (in which case test works) .
I'd be gratefull for any help.
Thanks
Rod Cook
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090424/76e15057/attachment.htm>
