[mpich-discuss] Running one MPI program from another
Rod Cook rod at cookies.demon.co.uk
Thu Apr 23 03:42:04 CDT 2009
[mpich-discuss] Running one MPI program from anotherJayesh
Using "mpiexec -n 1 prog" doesn't work.
Cheers
Rod
  ----- Original Message -----
  To: 'Rod Cook'
  Cc: mpich-discuss at mcs.anl.gov
  Sent: Wednesday, April 22, 2009 8:38 PM
  Subject: [mpich-discuss] Running one MPI program from another
   Try launching "mpiexec -n 1 prog" instead of "prog" with CreateProcess(). Let us know if it works for you.
  Jayesh
  From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Rod Cook
  Sent: Wednesday, April 22, 2009 10:12 AM
  To: Jayesh Krishna
  Subject: Re: [mpich-discuss] Running one MPI program from another
  Jayesh,
  I can get my example code to work using MPI_Comm_spawn but it doesn't work for my actual application. The problem with using MPI_Comm_spawn is that I don't know how to tell that the spawned program has finished -- this is why I used CreateProcess because it is possible to wait for the program to terminate. The spawned program could be a non MPI executable or a standalone MPI executable which can't communicate with the program calling MPI_Comm_spawn.
  Cheers,
  Rod
  To: 'Rod Cook'
  Sent: Wednesday, April 22, 2009 3:40 PM
  Subject: RE: [mpich-discuss] Running one MPI program from another
   Did you try MPI_Comm_spawn() ?
  Jayesh
  Sent: Wednesday, April 22, 2009 7:50 AM
  I am trying to run an MPI program (prog) from another MPI program (test) using CreateProcess under Windows XP.  I am using MPICH2 v1.08.
  Source for test
  #include "stdafx.h"
  #include <afx.h>
  #include "mpi.h"
  int run_program( char * program )
     STARTUPINFO si;
     PROCESS_INFORMATION pi;
     ZeroMemory( &si, sizeof(si) );
     si.cb = sizeof(si);
     ZeroMemory( &pi, sizeof(pi) );
     if( !CreateProcess( NULL, program, NULL, NULL, FALSE, 0, NULL, NULL, &si, &pi )  )
        return -1;
     WaitForSingleObject( pi.hProcess, INFINITE );
     CloseHandle( pi.hProcess );
     CloseHandle( pi.hThread );
     return 0;
  int main(int argc, char* argv[])
     MPI_Init(NULL,NULL);
     run_program("prog");
     MPI_Finalize();
   return 0;
  Source for prog
  #include "stdafx.h"
  #include "mpi.h"
     MPI_Init( NULL, NULL );
     MPI_Finalize();
     return 0;
  I get the following error when I run test:
  >mpiexec -n 1 test
  MPIDU_Sock_post_connect failed.
  [0] PMI_ConnectToHost failed: unable to post a connect to Yellowtail yellowtail
                   :2057, error: Unknown error class, error stack:
  MPIDU_Sock_post_connect(1228): unable to connect to Yellowtail yellowtail
   on port 2057, exhausted all endpoints (errno -1)
  MPIDU_Sock_post_connect(1275): unable to connect to                  on port 2057,
   No connection could be made because the target machine actively refused it. (er
  rno 10061)
  MPIDU_Sock_post_connect(1275): unable to connect to yellowtail on port 2057, No
  connection could be made because the target machine actively refused it. (errno
  10061)
  MPIDU_Sock_post_connect(1275): unable to connect to Yellowtail on port 2057, No
  10061)
  uPMI_ConnectToHost returning PMI_FAIL
  [0] PMI_Init failed.
  Fatal error in MPI_Init: Other MPI error, error stack:
  MPIR_Init_thread(294): Initialization failed
  MPID_Init(83)........: channel initialization failed
  MPID_Init(334).......: PMI_Init returned -1
  In my actual application prog is either a standalone MPI program which I can't change or a non MPI program (in which case test works) .
  I'd be gratefull for any help.
  Thanks
  Rod Cook
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090423/7a2a109d/attachment.htm>
