[mpich-discuss] MPI_Barrier(MPI_COMM_WORLD) failed
Rajeev Thakur thakur at mcs.anl.gov
Mon Apr 20 20:30:39 CDT 2009
If the MPICH2 test suite runs (run make testing in top-level mpich2
directory), then I don't know what the problem might be.
Rajeev
> -----Original Message-----
> From: Xiao Bo Lu [mailto:xiao.lu at auckland.ac.nz]
> Sent: Monday, April 20, 2009 6:27 PM
> To: Rajeev Thakur; mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] MPI_Barrier(MPI_COMM_WORLD) failed
> Hi,
> Yes. It is a Fortran 90 code. I did re-compile all the source
> code and libraries with the new MPICH2. The cofiguration
> option I made is as:
> ./configure -prefix=/hpc/xlu012 CC=gcc F90=gfortran
> and when I compiled all the files with the mpif90. I also did
> a few simple mpi tests with the mpiexec and it seems to work
> fine. I'm starting to wonder if there is anything to do with
> the memory allocation or some other communication variables
> that blocks some of the messages from a large array(??).
> Regards
> Xiao
> Rajeev Thakur wrote:
> > If it's Fortran code, just make sure no mpif.h files are
> left around
> > from the old implementation. Also make sure that the entire
> code (all
> > files) have been recompiled with MPICH2.
> > Rajeev
> >> From: mpich-discuss-bounces at mcs.anl.gov
> >> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Xiao Bo Lu
> >> Sent: Monday, April 20, 2009 5:57 PM
> >> To: mpich-discuss at mcs.anl.gov
> >> Hi Rajeev,
> >> Yes. The code was working but on a different platform
> (IBM-aix system
> >> with POE). I have to move the code to the new system since
> the lease
> >> on the old one just expired.
> >> Regards
> >> Xiao
> >>> Was this code that worked earlier?
> >>> Rajeev
> Xiao Bo Lu
> >>>> Sent: Monday, April 20, 2009 12:51 AM
> >>>> Subject: [mpich-discuss] MPI_Barrier(MPI_COMM_WORLD) failed
> >>>> Hi all,
> >>>> I've recently installed MPICH2-1.0.8 on my local machine
> >>>> (x86_64 Linux,
> >>>> gfortran 4.1.2) and I am now experiencing errors with my
> mpi code.
> >>>> The error messages are:
> >>>> Fatal error in MPI_Barrier: Other MPI error, error stack:
> >>>> MPI_Barrier(406)..........................:
> >>>> failed
> >>>> MPIR_Barrier(77)..........................:
> >>>> MPIC_Sendrecv(126)........................:
> >>>> MPIC_Wait(270)............................:
> >>>> MPIDI_CH3i_Progress_wait(215).............: an error
> >> occurred while
> >>>> handling an event returned by MPIDU_Sock_Wait()
> >>>> MPIDI_CH3I_Progress_handle_sock_event(420):
> >>>> MPIDU_Socki_handle_read(637)..............: connection failure
> >>>> (set=0,sock=1,errno=104:Connection reset by peer)[cli_0]:
> >>>> aborting job:
> >>>> failed
> >> occurred while
> >>>> MPIDU_Socki_handle_read size of processor is:
>         4
> >>>> I searched the net and found quite a few links about such
> >> error, but
> >>>> none of the posts could give a definitive fix. Do some
> of you know
> >>>> what could cause this error (e.g. incorrect installation;
> >>>> environmental
> >>>> setting..) and how to fix it?
> >>>> Regards
> >>>> Xiao
