[mpich-discuss] mpich2 under Ubuntu?
Mathieu Dubois
mathieu.dubois at limsi.fr
Thu Apr 16 12:58:37 CDT 2009
Hi Pavan,
I don't remember why I used this ./configure options. I remember that I
had problems with simpler command lines.
I will retry with your suggestion in mind (but it will take a few hours...).
Thank you very much for your fast reply.
Mathieu
Pavan Balaji wrote:
> Is there a particular reason why you want to use dllchan instead of
> the default? dllchan is experimental currently. If you want to use the
> default, you can just do:
> $ ./configure --prefix=/usr/local/mpich2 --enable-sharedlibs=gcc
> -- Pavan
> Mathieu Dubois wrote:
>> Hello everyone,
>> First I'm a newbie in the MPI world so please excuse me if I ask
>> stupid questions.
>> Let me explain my problem. I'm using Ubuntu 8.10 /Intrepid Ibex/ on a
>> x86_64 machine. I need to install MPICH2 in order to compile and run
>> the PCSIM neural simulator (http://www.lsm.tugraz.at/pcsim/).
>> I have found packages for mpich2 in
>> http://ppa.launchpad.net/metlov/ppa/ubuntu . Unfortunately those
>> packages doesn't provide shared libraries (.so files).
>> So I tried to compile mpich2-1.0.8 from source with the following
>> configure:
>> ./configure --prefix=/usr/local/mpich2/ --enable-sharedlibs=gcc
>> --with-device=ch3:dllchan:sock,shm,ssm
>> Compilation was ok and I installed it under /usr/local/mpich2 . I see
>> a lot of .so files under /usr/local/mpich2/lib as expected.
>> I successfully compiled PCSIM with this library.
>> But when I import the pcsim python package I get the following errors:
>> >>> import pypcsim
>> Fatal error in MPI_Init: Other MPI error, error stack:
>> MPIR_Init_thread(294): Initialization failed
>> MPID_Init(75)........:
>> MPICH_CH3_PreLoad(63):
>> MPIU_DLL_Open(42)....: Unable to load the dynamically loadable
>> library libmpich2-ch3-sock.so for reason
>> /usr/local/mpich2/lib/libmpich2-ch3-sock.so: undefinedsymbol:
>> MPIDI_Process[unset]: aborting job:
>> MPIDI_Process
>> This looks like something is missing in MPICH libraries (something
>> like a compilation option)... I haven't found anything relevant on
>> the web.
>> Does anyone have an idea? Any help would be appreciated.
>> Thanks in advance,
>> Mathieu
>> P.S.: I have set the LD_LIBRARY_PATH variable
>> $ export LD_LIBRARY_PATH=/usr/local/mpich2/lib/
