[mpich-discuss] mpich2 under Ubuntu?
Mathieu Dubois
mathieu.dubois at limsi.fr
Thu Apr 16 12:36:01 CDT 2009
Hello everyone,
First I'm a newbie in the MPI world so please excuse me if I ask stupid
questions.
Let me explain my problem. I'm using Ubuntu 8.10 /Intrepid Ibex/ on a
x86_64 machine. I need to install MPICH2 in order to compile and run the
PCSIM neural simulator (http://www.lsm.tugraz.at/pcsim/).
I have found packages for mpich2 in
http://ppa.launchpad.net/metlov/ppa/ubuntu . Unfortunately those
packages doesn't provide shared libraries (.so files).
So I tried to compile mpich2-1.0.8 from source with the following configure:
./configure --prefix=/usr/local/mpich2/ --enable-sharedlibs=gcc
--with-device=ch3:dllchan:sock,shm,ssm
Compilation was ok and I installed it under /usr/local/mpich2 . I see a
lot of .so files under /usr/local/mpich2/lib as expected.
I successfully compiled PCSIM with this library.
But when I import the pcsim python package I get the following errors:
>>> import pypcsim
Fatal error in MPI_Init: Other MPI error, error stack:
MPIR_Init_thread(294): Initialization failed
MPID_Init(75)........:
MPICH_CH3_PreLoad(63):
MPIU_DLL_Open(42)....: Unable to load the dynamically loadable library
libmpich2-ch3-sock.so for reason
/usr/local/mpich2/lib/libmpich2-ch3-sock.so: undefinedsymbol:
MPIDI_Process[unset]: aborting job:
/usr/local/mpich2/lib/libmpich2-ch3-sock.so: undefinedsymbol: MPIDI_Process
This looks like something is missing in MPICH libraries (something like
a compilation option)... I haven't found anything relevant on the web.
Does anyone have an idea? Any help would be appreciated.
Thanks in advance,
Mathieu
P.S.: I have set the LD_LIBRARY_PATH variable
$ export LD_LIBRARY_PATH=/usr/local/mpich2/lib/
