[mpich-discuss] Cannot build mpich2-1.0.8p1 (nemesis) with PGI8.0-4 on Linux x86_64
Rajeev Thakur
thakur at mcs.anl.gov
Wed Apr 1 17:56:29 CDT 2009
Gus,
ssm uses shared memory within a node and TCP across nodes. You can use
it with the PGI compilers until we get the Nemesis build to work with PGI
compilers.
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Gus Correa
> Sent: Wednesday, April 01, 2009 4:48 PM
> To: Mpich Discuss
> Subject: Re: [mpich-discuss] Cannot build mpich2-1.0.8p1
> Hi Rajeev, list
> Rajeev Thakur wrote:
> >>> We have dual-socket quad-core Opteron processor nodes (8
> >> cores/node).
> >>> I am afraid ch3:sock may not be the best choice for this type of
> >>> "fat" node, where shared memory shortcuts (memcpy ?) may
> work better
> >>> than sockets.
> > You could try the ch3:ssm channel then.
> > Rajeev
> Sure, and I did use ch3:ssm on a standalone multicore
> workstation with good results.
> However, for a Beowulf cluster, ch3:nemesis seems to promise
> the best of all worlds: shared memory communication for
> intranode, and a TCP/IP mechanism for internode.
> In addition, a number of codes we run here require more than
> 8 processes, and will use more than one node at a time, which
> cannot be done with ch3:ssm.
> It is also a matter of convenience, otherwise I would have to
> keep MPICH2 builds for ch3:ssm, ch3:sock, and ch3:nemesis,
> which combined with different compilers (Gnu, Intel, PGI, and
> hybrid compiler mixes) would give me too large a number of
> libraries to build and maintain.
> I would rather build MPICH2 with the most flexible
> communication channel, which seems to be nemesis, right?
> Also, I heard from the MPICH2 pros
> (i.e. a gentleman called Rajeev Thakur and his team) very
> convincing arguments to use ch3:nemesis.
> And I believe them! :)
> Gus Correa
> Gustavo Correa
> Lamont-Doherty Earth Observatory - Columbia University
> Palisades, NY, 10964-8000 - USA
