[mpich-discuss] Is MPICH2 connection failure aware ?
Seifer Lin seiferlin at gmail.com
Wed Apr 1 00:30:58 CDT 2009
Hi all:
I have run 2 MPI tasks in 2 different nodes. (2 nodes are with Windows XP
Professional)
The mpiexec command is run on node1.
During the parallel computing, if I unplug the network wire of node1, the
parallel computing will crash.
But if I unplug the network wire of node2, the parallel computing just
hangs! I notice that the hanging results from
that I unplug the wire before a MPI_Barrier, therefore node1 waits at
MPI_Barrier, but node2 will never reach that point.
Is there any mechanism to make the parallel computing crash after the
network wire of node2 is unplugged ?
regards,
Seifer
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090401/21f1e39b/attachment.htm>
