[mpich-discuss] Strange behavior of mpd
    Rajeev Thakur
    thakur at mcs.anl.gov
    Mon Sep 29 16:26:45 CDT 2008
It is odd because mpd is not involved in the communication. Communication
takes place directly between the MPI processes.
Rajeev
  _____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Bellanca Gaetano
Sent: Monday, September 29, 2008 3:48 PM
Subject: Re: [mpich-discuss] Strange behavior of mpd
Hi Gus,
I thought to something similar, and modify/increase the dimension of the
buffer for mpi. But this didn't solve the problem. Moreover, I had the same
problem on my PC at home, and on a two CPU system at the University, where
there are 16GB of memory.
Moreover, in both the configuration the simulation work once I have
restarted mpd after the boot and also using mpd not launched at boot time
(with root privileges) but started by the user before running the
simulation.
Note that also running mpd  after  the bot with root privileges results in a
correct behavior of the code.
I really don't know: it seems something relevant to the boot-time startup.
For the moment, I use the solution of mpd launched by the user, but the one
with mpd started by the root at boot time is more 'elegant'.
Regards.
Gaetano
  _____
Gaetano Bellanca - Department of Engineering - University of Ferrara
Via Saragat, 1 - 44100 - Ferrara - ITALY
Voice (VoIP):  +39 0532 974809     Fax:  +39 0532 974870
mailto:gaetano.bellanca at unife.it
  _____
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080929/f1a0d26b/attachment.htm>
