[mpich-discuss] libmpich.so not found
    Christopher Tanner
    christopher.tanner at gatech.edu
    Thu Sep 25 07:50:22 CDT 2008
Thanks for quick response! I have one issue though:
We are running some Fortran applications that haven't been able to be
compiled by gfortran so we had to use the Intel Fortran compiler
(ifort). However, since MPICH2 doesn't support shared libraries with
icc yet, I just used gcc to build the shared libraries. Thus the
configure command looks like:
$ ./configure --prefix=/usr/local/mpi/mpich2 --enable-f77 --enable-f90
--enable-cxx --enable-dynamiclibs --enable-sharedlibs=gcc --enable-
fast=defopt CC=icc CFLAGS=-m64 CXX=icpc CXXFLAGS=-m64 F77=ifort
FFLAGS=-m64 F90=ifort F90FLAGS=-m64
This resulted in some make errors -- the make output is attached
(make.log) and the error occurs at the end of the file. Is this make
error a result of using the Intel compilers or of trying to use
different C compilers for the executables and the shared libraries?
Chris Tanner
Space Systems Design Lab
Georgia Institute of Technology
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080925/d14d2811/attachment.obj>
On Sep 25, 2008, at 12:52 AM, Rajeev Thakur wrote:
> -----Original Message-----
> From: Rajeev Thakur [mailto:thakur at mcs.anl.gov]
> Sent: Wednesday, September 24, 2008 8:39 AM
> To: 'mpich-discuss at mcs.anl.gov'
> Subject: RE: [mpich-discuss] libmpich.so not found
> You need to build MPICH2 for shared libraries. If you are running on
> Linux
> with gcc, you can configure with --enable-sharedlibs=gcc .
> Rajeev
>> From: owner-mpich-discuss at mcs.anl.gov
>> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Christopher
>> Tanner
>> Sent: Wednesday, September 24, 2008 8:32 AM
>> To: mpich-discuss at mcs.anl.gov
>> Subject: [mpich-discuss] libmpich.so not found
>> I am trying to run MPP-DYNA (the multi-processor version of
>> LS-DYNA) using MPICH2. However, it requires the library libmpich.so,
>> which was not created or installed when I compiled MPICH2 1.0.7. Is
>> this library available specific only to MPICH1 or do I have to
>> compile
>> a separate source to obtain that library? Thanks!
>> Chris Tanner
