[mpich-discuss] Compiling mpich2 with icc
    Brian Harker
    brian.harker at gmail.com
    Wed Sep 24 15:05:14 CDT 2008
I see the same behavior on an AMD Turion64 x2 box, which sucks,
because I'd really like to use those hardcore optimizations.
On Wed, Sep 24, 2008 at 12:22 PM, Anthony Chan <chan at mcs.anl.gov> wrote:
> I tried 10.1 "icc -fast" on a simple program on a AMD box.
>> icc -fast ~/ts_C/ts_main_rc.c ; echo $?
> ipo: remark #11001: performing single-file optimizations
> ipo: remark #11005: generating object file /tmp/ipo_iccSrFoSL.o
> 0
>> a.out
> Fatal Error: This program was not built to run on the processor in your system.
> The allowed processors are: Intel(R) Core(TM) Duo processors and compatible Intel processors with supplemental Streaming SIMD Extensions 3 (SSSE3) instruction support.
> I tried -xT and -xP as well, both give the same error message.  It appear
> -fast can't be used on at least AMD box.
> ----- "Rajeev Thakur" <thakur at mcs.anl.gov> wrote:
>> I am able to reproduce the problem if I use the -fast option to icc.
>> But
>> without -fast it works. Wonder if it is a problem with icc. I used
>> version
>> 10.1.
>> Rajeev
>> > -----Original Message-----
>> > From: owner-mpich-discuss at mcs.anl.gov
>> > [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Robert
>> Kubrick
>> > Sent: Wednesday, September 24, 2008 11:54 AM
>> > To: mpich-discuss at mcs.anl.gov
>> > Subject: Re: [mpich-discuss] Compiling mpich2 with icc
>> > Compiling with ipcp returns this error:
>> > make[4]: Entering directory `/home/pts/archives/mpich2-1.1.0a1/src/
>> > mpid/common/locks'
>> >    CC              mpidu_process_locks.c
>> > ../../../include/pmi.h(740): error: parameter type involves
>> > pointer to array of unknown bound
>> >    int PMI_Args_to_keyval(int *argcp, char *((*argvp)[]),
>> > PMI_keyval_t **keyvalp, int *size);
>> > compilation aborted for mpidu_process_locks.c (code 2)
>> > make[4]: *** [mpidu_process_locks.o] Error 2
>> > make[4]: Leaving directory `/home/pts/archives/mpich2-1.1.0a1/src/
>> > mpid/common/locks'
>> > make[3]: *** [all-redirect] Error 2
>> > make[3]: Leaving directory `/home/pts/archives/mpich2-1.1.0a1/src/
>> > mpid/common'
>> > make[2]: *** [all-redirect] Error 2
>> > make[2]: Leaving directory
>> > `/home/pts/archives/mpich2-1.1.0a1/src/mpid'
>> > make[1]: *** [all-redirect] Error 2
>> > make[1]: Leaving directory `/home/pts/archives/mpich2-1.1.0a1/src'
>> > make: *** [all-redirect] Error 2
>> > I tried nm -a libmpich.a and it didn't return the required
>> > symbols. I am not too familiar with nm, but I am not sure
>> > this symbol table is
>> > right:
>> > me at harper1:~/archives/mpich2-1.1.0a1> nm -a lib/libmpich.a
>> > |grep MPIR_Version_date me at harper1:~/archives/mpich2-1.1.0a1>
>> > mpidu_process_locks.o:
>> > 00000000 a .strtab
>> > 00000000 a .symtab
>> > 00000000 n __ildata
>> >           w __ildata_included
>> > 00000000 a mpidu_process_locks.c
>> > mpidu_atomic_primitives.o:
>> > 00000000 a .strtab
>> > 00000000 a .symtab
>> > 00000000 n __ildata
>> >           w __ildata_included
>> > 00000000 a mpidu_atomic_primitives.c
>> > mpidu_queue.o:
>> > 00000000 a .strtab
>> > 00000000 a .symtab
>> > 00000000 n __ildata
>> >           w __ildata_included
>> > 00000000 a mpidu_queue.c
>> > dataloop.o:
>> > 00000000 a .strtab
>> > 00000000 a .symtab
>> > 00000000 n __ildata
>> >           w __ildata_included
>> > 00000000 a dataloop.c
>> > On Sep 24, 2008, at 12:00 PM, Rajeev Thakur wrote:
>> > > Can you do an "nm" on libmpich.a and see if those symbols are in
>> > > there.
>> > > Also, use icpc as the C++ compiler.
>> > > Rajeev
>> > Robert Kubrick
>> > >> Sent: Wednesday, September 24, 2008 10:55 AM
>> > >> initinfo.c compiles fine, but there are several warnings during
>> > >> compilation. I am attaching here the complete make log.
Cheers,
Brian
"In science, there is only physics; all the rest is stamp-collecting."
 -Ernest Rutherford
