[mpich-discuss] Compiling mpich2 with icc
    Anthony Chan
    chan at mcs.anl.gov
    Wed Sep 24 13:22:33 CDT 2008
I tried 10.1 "icc -fast" on a simple program on a AMD box.
> icc -fast ~/ts_C/ts_main_rc.c ; echo $?
ipo: remark #11001: performing single-file optimizations
ipo: remark #11005: generating object file /tmp/ipo_iccSrFoSL.o
0
> a.out
Fatal Error: This program was not built to run on the processor in your system.
The allowed processors are: Intel(R) Core(TM) Duo processors and compatible Intel processors with supplemental Streaming SIMD Extensions 3 (SSSE3) instruction support.
I tried -xT and -xP as well, both give the same error message.  It appear
-fast can't be used on at least AMD box.
----- "Rajeev Thakur" <thakur at mcs.anl.gov> wrote:
> I am able to reproduce the problem if I use the -fast option to icc.
> But
> without -fast it works. Wonder if it is a problem with icc. I used
> version
> 10.1.
> Rajeev
> > -----Original Message-----
> > From: owner-mpich-discuss at mcs.anl.gov
> > [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Robert
> Kubrick
> > Sent: Wednesday, September 24, 2008 11:54 AM
> > To: mpich-discuss at mcs.anl.gov
> > Subject: Re: [mpich-discuss] Compiling mpich2 with icc
> > Compiling with ipcp returns this error:
> > make[4]: Entering directory `/home/pts/archives/mpich2-1.1.0a1/src/
> > mpid/common/locks'
> >    CC              mpidu_process_locks.c
> > ../../../include/pmi.h(740): error: parameter type involves
> > pointer to array of unknown bound
> >    int PMI_Args_to_keyval(int *argcp, char *((*argvp)[]),
> > PMI_keyval_t **keyvalp, int *size);
> > compilation aborted for mpidu_process_locks.c (code 2)
> > make[4]: *** [mpidu_process_locks.o] Error 2
> > make[4]: Leaving directory `/home/pts/archives/mpich2-1.1.0a1/src/
> > mpid/common/locks'
> > make[3]: *** [all-redirect] Error 2
> > make[3]: Leaving directory `/home/pts/archives/mpich2-1.1.0a1/src/
> > mpid/common'
> > make[2]: *** [all-redirect] Error 2
> > make[2]: Leaving directory
> > `/home/pts/archives/mpich2-1.1.0a1/src/mpid'
> > make[1]: *** [all-redirect] Error 2
> > make[1]: Leaving directory `/home/pts/archives/mpich2-1.1.0a1/src'
> > make: *** [all-redirect] Error 2
> > I tried nm -a libmpich.a and it didn't return the required
> > symbols. I am not too familiar with nm, but I am not sure
> > this symbol table is
> > right:
> > me at harper1:~/archives/mpich2-1.1.0a1> nm -a lib/libmpich.a
> > |grep MPIR_Version_date me at harper1:~/archives/mpich2-1.1.0a1>
> > mpidu_process_locks.o:
> > 00000000 a .strtab
> > 00000000 a .symtab
> > 00000000 n __ildata
> >           w __ildata_included
> > 00000000 a mpidu_process_locks.c
> > mpidu_atomic_primitives.o:
> > 00000000 a .strtab
> > 00000000 a .symtab
> > 00000000 n __ildata
> >           w __ildata_included
> > 00000000 a mpidu_atomic_primitives.c
> > mpidu_queue.o:
> > 00000000 a .strtab
> > 00000000 a .symtab
> > 00000000 n __ildata
> >           w __ildata_included
> > 00000000 a mpidu_queue.c
> > dataloop.o:
> > 00000000 a .strtab
> > 00000000 a .symtab
> > 00000000 n __ildata
> >           w __ildata_included
> > 00000000 a dataloop.c
> > On Sep 24, 2008, at 12:00 PM, Rajeev Thakur wrote:
> > > Can you do an "nm" on libmpich.a and see if those symbols are in
> > > there.
> > > Also, use icpc as the C++ compiler.
> > > Rajeev
> > Robert Kubrick
> > >> Sent: Wednesday, September 24, 2008 10:55 AM
> > >> initinfo.c compiles fine, but there are several warnings during
> > >> compilation. I am attaching here the complete make log.
