[mpich-discuss] File I/O causing collective abort of all ranks
Brian Harker
brian.harker at gmail.com
Wed Sep 24 08:41:27 CDT 2008
yeah, just a typo, sorry.
On Wed, Sep 24, 2008 at 1:53 AM, William Gropp <wgropp at illinois.edu> wrote:
> Is this the *exact* code? If so, the problem is that both the do loop and
> the implied loop in the write statement refer to the same variable - i (as
> in EYE), instead of one being a loop over j (JAY) and one over i (EYE). j
> (JAY) may not be set, or set out-of-range.
> If this is just a typo in the example, then ignore this note :) . But in
> that case, it would help to see the exact code.
> Bill
> On Sep 23, 2008, at 12:13 PM, Brian Harker wrote:
>> Hello list-
>> I have a problem with process 0 being able to open a file for writing
>> and subsequently write to it. The pertinent section of code looks as
>> follows:
>> if ( proc_id == 0 ) then
>> open( unit = 1, file = "fubar.dat", status="new" )
>> do i = 1, ny
>> write(1,*) ( array(i,j), i = 1, nx )
>> end do
>> close(1)
>> end if
>> When this part of the code is reached, the program seems to hang for a
>> long time while trying to open the file, then spits out the following
>> error message:
>> rank 0 in job 11 $HOSTNAME_##### caused collective abort of all ranks
>> exit status of rank 0: killed by signal 9
>> I am confused about this error, because it is seemingly isolated to
>> this particular write-to-file by process 0. During execution, my
>> slave processes write out other files using this exact same syntax.
>> Has anyone run across this? I can't seem to find any useful
>> information on the interweb. I have run into this problem with both
>> MPICH2-1.0.6p1 and MPICH2-1.0.7. I am using the Intel fortran
>> compiler, ifort 10.1.012.
>> Thanks in advance for any input!
>> Cheers,
>> Brian
>> "In science, there is only physics; all the rest is stamp-collecting."
>> -Ernest Rutherford
> William Gropp
> Paul and Cynthia Saylor Professor of Computer Science
> University of Illinois Urbana-Champaign
Cheers,
Brian
-Ernest Rutherford
