[mpich-discuss] Multithread server using MPICH-2
Rob Latham
robl at mcs.anl.gov
Fri Sep 19 09:20:48 CDT 2008
Gisele Machado de Souza wrote:
> For do that I used MPI(mpich2-1.1.0a1.tar.gz) and pthreads.
> The problem I'm having is that the server and the thread are not working
> in parallel successfully. Sometimes, the program hangs, do nothing, and
> in another times a fatal error appears (Assertion failed in file
> sock_wait.i at line 236: (pollfd->events & (0x001 | 0x004)) ||
> pollfd->fd == -1).
Hi. I'm afraid I don't have a good answer for you, other than we've seen
similar problems when we try to use dynamic processes in
MPI_THREAD_MULTIPLE environments.
Unfortunately, I can't tell you to try your code out with OpenMPI: often
different MPI implementations can help make sure you are following the
spec, but in this case you'll get an assertion almost immediately.
> When I put the server to sleep for a moment, before he will wait another
> connection, during the time he was sleeping the created thread works
> fine. Once the server wakes up and starts to wait for a connection,
> things stop working.
That does point to some kind of race condition.
> A peace of my code (Server):
These classes of problems are quite tricky to work out. It would be a
huge help if you could cut down your program to the smallest possible
test case. I know that's a lot of work, but it would really help us
pinpoint the problem.
==rob
