[mpich-discuss] Unable to connect issue
    bob ilgner
    bobilgner at gmail.com
    Fri Sep 19 06:53:17 CDT 2008
I have installed mpich2 1.0.7 on 2 XP Pro hosts and am trying to run the cpi
process on both hosts with the command
mpiexec -hosts 2 images17 images17 cpi
where images16 and images17 are the hosts and cpi is the supplied example
application and get the error:
abort: unable to connect to images16
I have checked passwords and regsitration is the same on both hosts.
Firewalls are both down. Host names defined in hosts file under system32. I
have ensured that smpd is operating on both machines. Usernames and password
are the same on both hosts and have both been delegated. I have gone through
the mpich2 user manual and find no way forward with this. Is there anything
else I could try ?
Would it help if I listed the output from the mpiexec with the verbose
switch on.
Regards, bob
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080919/6a0dca65/attachment.htm>
