[mpich-discuss] mpif90 and mpicc problems
    Anthony Chan
    chan at mcs.anl.gov
    Fri Sep  5 14:36:22 CDT 2008
The output of "make installcheck" confirms that your mpicc
and mpif77 from mpich2 install directory are working as expected.
So I don't understand your 1st email that you had problem with mpicc.
Is your problem only limited to mpif90 ?  Can you also explain how
you use mpif90 ?
A.Chan
----- "jcrosby" <jcrosby at scotiaweather.com> wrote:
> Alrighty, it's attached.
> Anthony Chan wrote:
> > Can you cd to your "mpich2 build directory" and do "make
> installcheck"
> > and send us the output of the command ?
> > Thanks,
> > A.Chan
> >> Alrighty, I've attached the configure, make and make install logs.
> >> Anthony Chan wrote:
> >>> Can you send us the configure and make outputs as stated in
> >>> mpich2's installer guide ?
> >>> A.Chan
> >>>> No they havent.
> >>>> Anthony Chan wrote:
> >>>>> do mpif90 and mpicc ever work since you install mpich2 ?
> >>>>> A.Chan
> >>>>>> Good morning,
> >>>>>> I'm having a few problems getting mpif90 and mpicc to work.
> >>>> Whenever
> >>>>>> I
> >>>>>> run them I get the following errors:
> >>>>>> MPIF90:
> >>>>>> /opt/intel/fc/10.1.015/lib/for_main.o: In function `main':
> /users/nbtester/x86linux_nightly/branch-10_1/20080313_000000/libdev/frtl/src/libfor/for_main.c:(.text+0x39):
> >>>>>> undefined reference to `MAIN__'
> >>>>>> MPICC:
> >>>>>> /usr/lib/gcc/i486-linux-gnu/4.2.3/../../../../lib/crt1.o: In
> >>>> function
> >>>>>> `_start':
> >>>>>> (.text+0x18): undefined reference to `main'
> >>>>>> collect2: ld returned 1 exit status
> >>>>>> Joseph Crosby
> >>>>>> Network Administrator
> >>>>>> Scotia Weather Service Inc.
> >>>>>> netadmin at scotiaweather.com
> >>>>>> A byte walks into a bar and orders a pint. Bartender asks him
> >>>> "What's
> >>>>>> wrong?" Byte says "Parity error." Bartender nods and says
> "Yeah,
> >> I
> >>>>>> thought you looked a bit off."
> >>>> Joseph Crosby
> >> "What's
> >>>> wrong?" Byte says "Parity error." Bartender nods and says "Yeah,
> I
> >> Joseph Crosby
> "What's
> >> wrong?" Byte says "Parity error." Bartender nods and says "Yeah, I
> >> Configuring MPICH2 version 1.0.7 with '--prefix=/usr/local/mpich2'
> >> Running on system: Linux snow 2.6.24-19-generic #1 SMP Wed Jun 18
> >> 14:43:41 UTC 2008 i686 GNU/Linux
> >> Executing mpich2prereq in /usr/local/mpich2-1.0.7/src/mpid/ch3
> with
> >> /usr/local/mpich2-1.0.7/src/mpid/ch3/channels/sock
> >> sourcing /usr/local/mpich2-1.0.7/src/pm/mpd/mpich2prereq
> >> sourcing /usr/local/mpich2-1.0.7/src/pm/mpd/setup_pm
> >> checking for gcc... gcc
> >> checking for C compiler default output file name... a.out
> >> checking whether the C compiler works... yes
> >> checking whether we are cross compiling... no
> >> checking for suffix of executables...
> >> checking for suffix of object files... o
> >> checking whether we are using the GNU C compiler... yes
> >> checking whether gcc accepts -g... yes
> >> checking for gcc option to accept ANSI C... none needed
> >> checking whether C compiler accepts option -O2... yes
> >> checking whether routines compiled with -O2 can be linked with
> ones
> >> compiled without -O2... yes
> >> checking for type of weak symbol support... pragma weak
> >> checking whether __attribute__ ((weak)) allowed... yes
> >> checking for multiple weak symbol support... yes
> >> checking for g77... g77
> >> checking whether we are using the GNU Fortran 77 compiler... yes
> >> checking whether g77 accepts -g... yes
> >> checking whether Fortran 77 compiler accepts option -O2... yes
> ones
> >> checking how to get verbose linking output from g77... -v
> >> checking for Fortran libraries of g77...
> >> -L/usr/lib/gcc/i486-linux-gnu/3.4.6
> >> -L/usr/lib/gcc/i486-linux-gnu/3.4.6/../../../../lib
> >> -L/usr/lib/gcc/i486-linux-gnu/3.4.6/../../.. -L/lib/../lib
> >> -L/usr/lib/../lib -lfrtbegin -lg2c -lm -lgcc_s
> >> checking whether g77 accepts the FLIBS found by autoconf... yes
> >> checking whether C can link with
> >> -L/usr/lib/../lib -lfrtbegin -lg2c -lm -lgcc_s... yes
> >> checking for linker for Fortran main programs... Use Fortran to
> link
> >> programs
> >> checking for Fortran 77 name mangling... lower doubleunderscore
> >> checking what libraries are needed to link Fortran programs with C
> >> routines that use stdio... none
> >> checking for f90... no
> >> checking for xlf90... no
> >> checking for pgf90... no
> >> checking for ifort... ifort
> >> checking that f works as the extension for Fortran 90 program...
> yes
> >> checking whether we are using the GNU Fortran 90 compiler... no
> >> checking whether ifort accepts -g... yes
> >> checking for extension for Fortran 90 programs... f90
> >> checking whether the Fortran 90 compiler (ifort  ) works... yes
> >> checking whether the Fortran 90 compiler (ifort  ) is a
> >> cross-compiler... no
> >> checking whether Fortran 90 works with Fortran 77... yes
> >> checking whether Fortran accepts ! for comments... yes
> >> checking for include directory flag for Fortran... -I
> >> checking for Fortran 77 flag for library directories... -L
> >> checking for which Fortran libraries are needed to link C with
> >> Fortran... none
> >> checking whether Fortran compiler processes .F files with C
> >> preprocessor... yes
> yes
> (cached)
> >> no
> >> checking whether ifort accepts -g... (cached) yes
> >> checking for Fortran 90 module extension... mod
> >> checking for Fortran 90 module include flag... -I
> >> checking whether Fortran 90 accepts f90 suffix... yes
> >> checking whether Fortran 90 compiler accepts option -O2... yes
> ones
> >> checking whether Fortran 90 compiler processes .F90 files with C
> >> preprocessor... yes
> >> checking what libraries are needed to link Fortran90 programs with
> C
> >> checking for f90 compiler vendor... intel
> >> checking for c++... c++
> >> checking whether we are using the GNU C++ compiler... yes
> >> checking whether c++ accepts -g... yes
> >> checking whether the C++ compiler c++ can build an executable...
> yes
> >> checking whether the compiler supports exceptions... yes
> >> checking whether the compiler recognizes bool as a built-in
> type...
> >> yes
> >> checking whether the compiler implements namespaces... yes
> >> checking whether <iostream> available... yes
> >> checking whether the compiler implements the namespace std... yes
> >> checking whether <math> available... no
> >> checking for GNU g++ version... 4 . 2
> >> checking whether C++ compiler accepts option -O2... yes
> ones
> >> checking for perl... /usr/bin/perl
> >> checking for ar... ar
> >> checking for ranlib... ranlib
> >> checking for etags... no
> >> checking for killall... killall
> >> checking for a BSD-compatible install... /usr/bin/install -c
> >> checking whether install works... yes
> >> checking whether install breaks libraries... no
> >> checking whether mkdir -p works... yes
> >> checking for make... make
> >> checking whether clock skew breaks make... no
> >> checking whether make supports include... yes
> >> checking whether make allows comments in actions... yes
> >> checking for virtual path format... VPATH
> >> checking whether make sets CFLAGS... no
> >> checking for bash... /bin/sh
> >> checking whether /bin/sh supports arrays... yes
> >> checking for doctext... false
> >> checking for location of doctext style files... unavailable
> >> checking for an ANSI C-conforming const... yes
> >> checking for volatile... yes
> >> checking for restrict... __restrict
> >> checking for inline... inline
> >> checking whether __attribute__ allowed... yes
> >> checking whether __attribute__((format)) allowed... yes
> >> checking whether byte ordering is bigendian... no
> >> checking whether C compiler allows unaligned doubles... yes
> >> checking whether gcc supports __func__... yes
> >> Using gcc to determine dependencies
> >> checking whether long double is supported... yes
> >> checking whether long long is supported... yes
> >> checking for max C struct integer alignment... four
> >> checking for max C struct floating point alignment... four
> >> checking for max C struct alignment of structs with doubles...
> four
> >> checking for max C struct floating point alignment with long
> >> doubles... four
> >> checking if alignment of structs with doubles is based on
> position...
> >> no
> >> checking if alignment of structs with long long ints is based on
> >> position... no
> >> checking if double alignment breaks rules, find actual alignment...
> no
> >> checking for alignment restrictions on pointers... int or better
> >> checking for egrep... grep -E
> >> checking for ANSI C header files... no
> >> checking for sys/types.h... yes
> >> checking for sys/stat.h... yes
> >> checking for stdlib.h... yes
> >> checking for string.h... yes
> >> checking for memory.h... yes
> >> checking for strings.h... yes
> >> checking for inttypes.h... yes
> >> checking for stdint.h... yes
> >> checking for unistd.h... yes
> >> checking for char... yes
> >> checking size of char... 1
> >> checking for short... yes
> >> checking size of short... 2
> >> checking for int... yes
> >> checking size of int... 4
> >> checking for long... yes
> >> checking size of long... 4
> >> checking for long long... yes
> >> checking size of long long... 8
> >> checking for float... yes
> >> checking size of float... 4
> >> checking for double... yes
> >> checking size of double... 8
> >> checking for long double... yes
> >> checking size of long double... 12
> >> checking for wchar_t... yes
> >> checking size of wchar_t... 4
> >> checking for void *... yes
> >> checking size of void *... 4
> >> checking for size of float int... 8
> >> checking for size of double int... 12
> >> checking for size of long int... 8
> >> checking for size of short int... 6
> >> checking for size of 2 int... 8
> >> checking for size of long double int... 16
> >> checking for sys/bitypes.h... yes
> >> checking for int16_t... yes
> >> checking for int32_t... yes
> >> checking for int64_t... yes
> >> checking for size of Fortran type integer... 4
> >> checking for size of Fortran type real... 4
> >> checking for size of Fortran type double precision... 8
> >> checking whether integer*1 is supported... yes
> >> checking whether integer*2 is supported... yes
> >> checking whether integer*4 is supported... yes
> >> checking whether integer*8 is supported... yes
> >> checking whether integer*16 is supported... no
> >> checking whether real*4 is supported... yes
> >> checking whether real*8 is supported... yes
> >> checking whether real*16 is supported... no
> >> checking for C type matching Fortran integer... int
> >> checking for size of MPI_Status... 20
> >> checking for values of Fortran logicals... True is 1 and False is
> 0
> >> checking how to run the C preprocessor... gcc -E
> >> checking for Fortran 90 integer kind for 4-byte integers... 4
> >> checking for Fortran 90 integer kind for 8-byte integers... 8
> >> checking for bool... yes
> >> checking size of bool... 1
> >> checking how to run the C++ preprocessor... c++ -E
> >> checking for complex... yes
> >> checking for Complex... yes
> >> checking size of Complex... 8
> >> checking for DoubleComplex... yes
> >> checking size of DoubleComplex... 16
> >> checking for LongDoubleComplex... yes
> >> checking size of LongDoubleComplex... 24
> >> checking if char * pointers use byte addresses... yes
> >> checking for alignment restrictions on int64_t... no
> >> checking for alignment restrictions on int32_t... no
> >> checking for size of MPI_BSEND_OVERHEAD... 59
> >> checking for gcc __asm__ and pentium cmpxchgl instruction... yes
> >> checking for gcc __asm__ and AMD x86_64 cmpxchgq instruction... no
> >> checking for gcc __asm__ and IA64 xchg4 instruction... no
> >> checking for ANSI C header files... (cached) no
> >> checking for stdlib.h... (cached) yes
> >> checking for stdarg.h... yes
> >> checking for sys/types.h... (cached) yes
> >> checking for inttypes.h... (cached) yes
> >> checking for limits.h... yes
> >> checking for stddef.h... yes
> >> checking for errno.h... yes
> >> checking for sys/socket.h... yes
> >> checking for sys/time.h... yes
> >> checking for unistd.h... (cached) yes
> >> checking for endian.h... yes
> >> checking for assert.h... yes
> >> checking for sys/uio.h... yes
> >> checking for size_t... yes
> >> checking for setitimer... yes
> >> checking for alarm... yes
> >> checking for vsnprintf... yes
> >> checking for vsprintf... yes
> >> checking whether vsnprintf needs a declaration... no
> >> checking for strerror... yes
> >> checking for snprintf... yes
> >> checking whether snprintf needs a declaration... no
> >> checking for va_copy... yes
> >> checking for working alloca.h... yes
> >> checking for alloca... yes
> >> checking for strdup... yes
> >> checking whether strdup needs a declaration... no
> >> checking for clock_gettime... no
> >> checking for clock_getres... no
> >> checking for gethrtime... no
> >> checking for gettimeofday... yes
> >> sourcing /usr/local/mpich2-1.0.7/src/mpid/ch3/setup_device
> >> RUNNING SETUP_DEVICE FOR THE CH3 DEVICE
> >> sourcing
> >> /usr/local/mpich2-1.0.7/src/mpid/ch3/channels/sock/setup_channel
> >> RUNNING SETUP_CHANNEL FOR THE SOCK CHANNEL
> >> sourcing /usr/local/mpich2-1.0.7/src/mpid/common/sock/setup
> >> RUNNING SETUP FOR THE SOCK INTERFACE
> >> checking for pthread.h... yes
> >> checking for pthread_yield... no
> >> checking for library containing pthread_key_create... -lpthread
> >> checking for pthread_cleanup_push... no
> >> checking whether pthread_cleanup_push is available (may be a macro
> in
> >> pthread.h)... no
> >> checking for sched_yield... yes
> >> checking for yield... no
> >> checking for usleep... yes
> >> checking for sleep... yes
> >> checking for select... yes
> >> RUNNING CONFIGURE FOR CH3 DEVICE
> >> checking whether make sets CFLAGS... yes
> >> checking for uuid/uuid.h... no
> >> checking for time.h... yes
> >> checking for ctype.h... yes
> >> checking for arpa/inet.h... yes
> >> checking for net/if.h... yes
> >> checking for ANSI C header files... yes
> >> checking for string.h... (cached) yes
> >> checking for pid_t... yes
> >> checking for inet_pton... yes
> >> checking for gethostname... yes
> >> checking whether gethostname needs a declaration... no
> >> checking for CFUUIDCreate... no
> >> checking for uuid_generate... no
> >> checking for time... yes
> >> checking for library containing uuid_generate... no
> >> checking whether CPP accepts variable length argument lists... yes
> >> checking whether we can use struct ifconf... yes
> >> checking for etags... true
> >> configure: creating ./config.status
> >> config.status: creating Makefile
> >> config.status: creating src/Makefile
> >> config.status: creating util/Makefile
> >> config.status: creating util/shm/Makefile
> >> config.status: creating util/shmbase/Makefile
> >> config.status: creating channels/Makefile
> >> config.status: creating localdefs
> >> config.status: creating include/mpid_thread.h
> >> config.status: creating include/mpidi_ch3_conf.h
> >> config.status: include/mpidi_ch3_conf.h is unchanged
> >> config.status: executing default-1 commands
> >> copying
> /usr/local/mpich2-1.0.7/src/mpid/ch3/../common/thread/mpid_thread_mpe.c
> >> to src/mpid_thread.c
> >> configure: configuring in util/sock
> >> configure: running /bin/sh
> >> '/usr/local/mpich2-1.0.7/src/mpid/ch3/util/sock/configure'
> >> --prefix=/usr/local/mpich2  '--prefix=/usr/local/mpich2' 'CC=gcc'
> >> 'CFLAGS= -O2' --cache-file=/dev/null
> >> --srcdir=/usr/local/mpich2-1.0.7/src/mpid/ch3/util/sock
> >> RUNNING CONFIGURE FOR CH3 UTIL SOCK ROUTINES
> >> config.status: creating ch3usockconf.h
> >> config.status: ch3usockconf.h is unchanged
> >> Updating dependency directories .deps
> >> configure: configuring in channels/sock
> >> '/usr/local/mpich2-1.0.7/src/mpid/ch3/channels/sock/configure'
> >> --srcdir=/usr/local/mpich2-1.0.7/src/mpid/ch3/channels/sock
> >> RUNNING CONFIGURE FOR THE SOCK CHANNEL
> >> checking for netdb.h... yes
> >> checking for sys/ioctl.h... yes
> >> checking for sys/sockio.h... no
> >> checking for netinet/in.h... yes
> >> config.status: creating include/mpidi_ch3i_sock_conf.h
> >> config.status: include/mpidi_ch3i_sock_conf.h is unchanged
> >> RUNNING CONFIGURE FOR THE SOCK INTERFACE
> >> config.status: creating mpidu_sock_conf.h
> >> config.status: mpidu_sock_conf.h is unchanged
> >> configure: configuring in poll
> >> '/usr/local/mpich2-1.0.7/src/mpid/common/sock/poll/configure'
> >> --srcdir=/usr/local/mpich2-1.0.7/src/mpid/common/sock/poll
> >> RUNNING CONFIGURE FOR THE POLL IMPLEMENTATION OF SOCK
> >> checking for poll... yes
> >> checking for fcntl.h... yes
> >> checking for netinet/tcp.h... yes
> >> checking for poll.h... yes
> >> checking for sys/param.h... yes
> >> checking for sys/poll.h... yes
> >> checking if struct poll is defined... yes
> >> checking if a simple program using poll() can be compiled... yes
> >> checking whether bit fields work in ip.h... yes
> >> checking for library containing socket... none required
> >> checking for library containing gethostbyname... none required
> >> checking whether socklen_t is defined (in sys/socket.h if
> present)...
> >> yes
> >> config.status: creating mpidu_socki_conf.h
> >> config.status: mpidu_socki_conf.h is unchanged
> >> Configuring with args --prefix=/usr/local/mpich2
> >> checking for architecture... LINUX
> >> ROMIO home directory is /usr/local/mpich2-1.0.7/src/mpi/romio
> >> checking for memalign... yes
> >> checking Fortran external names
> >> Fortran externals are lower case and have two trailing underscores
> >> checking fcntl.h usability... yes
> >> checking fcntl.h presence... yes
> >> checking malloc.h usability... yes
> >> checking malloc.h presence... yes
> >> checking for malloc.h... yes
> >> checking stddef.h usability... yes
> >> checking stddef.h presence... yes
> >> checking for int large enough for pointers... yes
> >> checking for Fortran 90 KIND parameter for 8-byte integers...
> >>   8
> >> checking that we can use integer*8 to declare
> >> MPI_DISPLACMENT_CURRENT... yes
> >> Overriding Array test for MPICH2
> >> checking for weak symbol support... pragma weak
> >> checking that weak symbols are visible to other files... yes
> >> checking that the compiler correctly implements weak symbols...
> yes
> >> checking whether struct flock compatible with MPI_Offset... yes
> >> checking for pvfs2-config... notfound
> >> checking configured file systems... testfs ufs nfs
> >> configure: WARNING: File locks may not work with NFS.  See the
> >> Installation and
> >> users manual for instructions on testing and if necessary fixing
> this
> >> checking for library containing aio_write... -lrt
> >> checking signal.h usability... yes
> >> checking signal.h presence... yes
> >> checking for signal.h... yes
> >> checking if aio.h exists and can be compiled... yes
> >> checking if sys/aio.h exists and can be compiled... no
> >> checking whether aio routines can be used... yes
> >> checking for obsolete two-argument aio_write... no
> >> checking for obsolete two-argument aio_suspend... no
> >> checking for aio_fildes member of aiocb structure... yes
> >> checking for aio_whence member of aiocb structure... no
> >> checking for aio_handle member of aiocb structure... no
> >> checking for aio_reqprio member of aiocb structure... yes
> >> checking for aio_sigevent member of aiocb structure... yes
> >> checking sys/vfs.h usability... yes
> >> checking sys/vfs.h presence... yes
> >> checking for sys/vfs.h... yes
> >> checking sys/param.h usability... yes
> >> checking sys/param.h presence... yes
> >> checking sys/mount.h usability... yes
> >> checking sys/mount.h presence... yes
> >> checking for sys/mount.h... yes
> >> checking sys/statvfs.h usability... yes
> >> checking sys/statvfs.h presence... yes
> >> checking for sys/statvfs.h... yes
> >> checking whether struct statfs properly defined... yes
> >> checking for f_fstypename member of statfs structure... no
> >> checking for sys/stat.h... (cached) yes
> >> checking for stat... yes
> >> checking for st_fstype member of stat structure... no
> >> checking for sys/statvfs.h... (cached) yes
> >> checking for sys/vfs.h... (cached) yes
> >> checking for statvfs... yes
> >> checking for f_basetype member of statvfs structure... no
> >> checking for large file defines... yes
> >> checking whether off64_t is an scalar type... yes
> >> checking for lstat... yes
> >> checking whether lstat needs a declaration... yes
> >> checking for readlink... yes
> >> checking whether readlink needs a declaration... no
> >> checking for fsync... yes
> >> checking whether fsync needs a declaration... no
> >> checking for ftruncate... yes
> >> checking whether ftruncate needs a declaration... no
> >> setting SYSDEP_INC to
> >> setting CC to gcc
> >> setting F77 to g77
> >> setting TEST_CC to /usr/local/mpich2-1.0.7/bin/mpicc
> >> setting TEST_F77 to /usr/local/mpich2-1.0.7/bin/mpif77
> >> setting CFLAGS to  -O2  -DFORTRANDOUBLEUNDERSCORE
> >> -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H
> >> setting USER_CFLAGS to
> >> setting USER_FFLAGS to
> >> config.status: creating mpi-io/Makefile
> >> config.status: creating mpi2-other/info/Makefile
> >> config.status: creating mpi2-other/array/Makefile
> >> config.status: creating adio/common/Makefile
> >> config.status: creating test/Makefile
> >> config.status: creating test/misc.c
> >> config.status: creating test/large_file.c
> >> config.status: creating test/runtests
> >> config.status: creating util/romioinstall
> >> config.status: creating include/mpio.h
> >> config.status: creating include/mpiof.h
> >> config.status: creating adio/ad_nfs/Makefile
> >> config.status: creating adio/ad_ufs/Makefile
> >> config.status: creating adio/ad_bgl/Makefile
> >> config.status: creating adio/ad_bglockless/Makefile
> >> config.status: creating adio/ad_panfs/Makefile
> >> config.status: creating adio/ad_xfs/Makefile
> >> config.status: creating adio/ad_sfs/Makefile
> >> config.status: creating adio/ad_pfs/Makefile
> >> config.status: creating adio/ad_testfs/Makefile
> >> config.status: creating adio/ad_pvfs/Makefile
> >> config.status: creating adio/ad_pvfs2/Makefile
> >> config.status: creating adio/ad_gridftp/Makefile
> >> config.status: creating adio/ad_lustre/Makefile
> >> config.status: creating mpi-io/fortran/Makefile
> >> config.status: creating mpi2-other/info/fortran/Makefile
> >> config.status: creating mpi2-other/array/fortran/Makefile
> >> config.status: creating test/fmisc.f
> >> config.status: creating test/fcoll_test.f
> >> config.status: creating test/pfcoll_test.f
> >> config.status: creating test/fperf.f
> >> config.status: creating mpi-io/glue/mpich2/Makefile
> >> config.status: creating mpi-io/glue/mpich1/Makefile
> >> config.status: creating mpi-io/glue/default/Makefile
> >> config.status: creating common/dataloop/Makefile
> >> config.status: creating adio/include/romioconf.h
> >> RUNNING CONFIGURE FOR THE SIMPLE PMI
> >> checking for sys/socket.h... (cached) yes
> >> checking for sys/un.h... yes
> >> checking for socket... yes
> >> checking for setsockopt... yes
> >> checking for gethostbyname... yes
> present)...
> >> yes
> >> checking whether struct hostent contains h_addr_list... yes
> >> config.status: creating pmiconf.h
> >> config.status: pmiconf.h is unchanged
> >> checking whether make sets $(MAKE)... yes
> >> checking whether ln -s works... yes
> >> checking whether install /usr/bin/install -c works... yes
> >> Using INSTALL=/usr/bin/install -c
> >> checking for totalview... no
> >> checking for python2.5... python2.5
> >> checking for python2.4... no
> >> checking for python2.3... no
> >> checking for python2.2... no
> >> checking for python2... no
> >> checking for python... python
> >> checking that python2.5 is a valid python version... yes
> >> checking that the cPickle module is available for python2.5... yes
> >> checking for sys/wait.h that is POSIX.1 compatible... yes
> >> checking for strings.h... (cached) yes
> >> checking sys/time.h usability... yes
> >> checking sys/time.h presence... yes
> >> checking for putenv... yes
> >> config.status: creating mpdconf.h
> >> Configuring MPE Profiling System with '--prefix=/usr/local/mpich2'
> >> 'CC=gcc' 'CFLAGS= -O2' 'F77=g77' 'FFLAGS= -O2'
> >> 'MPI_CC=/usr/local/mpich2-1.0.7/bin/mpicc'
> >> 'MPI_F77=/usr/local/mpich2-1.0.7/bin/mpif77'
> >> checking gnumake... yes using --no-print-directory
> >> checking BSD 4.4 make... no - whew
> >> checking OSF V3 make... no
> >> This MPE build is part of the MPICH2 build
> >> checking whether MPI_CC has been set ...
> >> checking whether MPI_F77 has been set ...
> >> -L/usr/lib/../lib -lpthread -lrt -lfrtbegin -lg2c -lm -lgcc_s
> >> -L/usr/lib/../lib -lpthread -lrt -lfrtbegin -lg2c -lm -lgcc_s...
> yes
> link
> >> programs
> >> checking for leftover Makefiles in subpackages ...  "src/misc"
> >> "src/callstack" "src/logging" "src/wrappers" "src/graphics"
> >> "src/collchk" "src/slog2sdk" cleaned
> >> config.status: creating sbin/mpetestlink
> >> config.status: creating sbin/mpetestexec
> >> config.status: creating sbin/mpetestexeclog
> >> config.status: creating sbin/mpeinstall
> >> config.status: creating sbin/mpecheckinstall
> >> config.status: creating sbin/mpecheckbuild
> >> config.status: creating etc/mpe_help.conf
> >> config.status: creating etc/mpe_f77env.conf
> >> config.status: creating mpe_conf.h
> >> configure: configuring in src/misc
> >> '/usr/local/mpich2-1.0.7/src/mpe2/src/misc/configure'
> >> --srcdir=/usr/local/mpich2-1.0.7/src/mpe2/src/misc
> >> Configuring MPE Miscellaneous Library with
> >> '--prefix=/usr/local/mpich2' 'CC=gcc' 'CFLAGS= -O2' 'F77=g77'
> 'FFLAGS=
> >> -O2' 'MPI_CC=/usr/local/mpich2-1.0.7/bin/mpicc'
> '--cache-file=/dev/null'
> >> '--srcdir=/usr/local/mpich2-1.0.7/src/mpe2/src/misc'
> >> checking build system type... i686-pc-linux-gnu
> >> checking host system type... i686-pc-linux-gnu
> >> checking for dbx... no
> >> checking for gdb... /usr/bin/gdb
> >> checking for sysinfo... yes
> >> checking for uname... yes
> >> checking netdb.h usability... yes
> >> checking netdb.h presence... yes
> >> checking sys/systeminfo.h usability... no
> >> checking sys/systeminfo.h presence... no
> >> checking for sys/systeminfo.h... no
> >> checking for sighandler_t... no
> >> checking for kill... yes
> >> checking whether kill needs a declaration... no
> >> config.status: creating src/dbxerr.c
> >> config.status: creating mpe_misc_conf.h
> >> configure: configuring in src/callstack
> >> '/usr/local/mpich2-1.0.7/src/mpe2/src/callstack/configure'
> >> --srcdir=/usr/local/mpich2-1.0.7/src/mpe2/src/callstack
> >> Configuring MPE CallStack Library with
> >> '--srcdir=/usr/local/mpich2-1.0.7/src/mpe2/src/callstack'
> >> checking stdio.h usability... yes
> >> checking stdio.h presence... yes
> >> checking for stdio.h... yes
> >> checking execinfo.h usability... yes
> >> checking execinfo.h presence... yes
> >> checking for execinfo.h... yes
> >> checking whether <execinfo.h> defines backtrace_symbols_fd() ...
> yes
> >> checking if <execinfo.h> links with -Wl,--export-dynamic ... yes
> >> checking for fdopen... yes
> >> checking whether fdopen needs a declaration... no
> >> config.status: creating include/mpe_callstack.h
> >> config.status: creating etc/mpe_callstack_ldflags.conf
> >> config.status: creating mpe_callstack_conf.h
> >> configure: configuring in src/logging
> >> '/usr/local/mpich2-1.0.7/src/mpe2/src/logging/configure'
> >> --srcdir=/usr/local/mpich2-1.0.7/src/mpe2/src/logging
> >> Configuring MPE Logging Library and Tools with
> 'FFLAGS=
> >> '--srcdir=/usr/local/mpich2-1.0.7/src/mpe2/src/logging'
> >> checking sys/bitypes.h usability... yes
> >> checking sys/bitypes.h presence... yes
> >> checking for header that defines C99 integer types, intXX_t ...
> >> <stdint.h>
> >> checking whether <inttypes.h> defines the PRIdXX macros ... yes
> >> checking if <stdint.h> can be behind system headers ... yes
> >> checking for address-sized integer ... CLOG_int32_t
> >> checking for mkstemp... yes
> >> checking whether mkstemp needs a declaration... no
> >> checking for srand48... yes
> >> checking whether srand48 needs a declaration... no
> >> checking for lrand48... yes
> >> checking whether lrand48 needs a declaration... no
> >> checking for special C compiler options needed for large files...
> no
> >> checking for _FILE_OFFSET_BITS value needed for large files... 64
> >> checking for _LARGE_FILES value needed for large files... no
> >> checking for O_LARGEFILE for open() ... needs _LARGEFILE64_SOURCE
> >> checking for O_BINARY for open() ... no
> >> checking pthread.h usability... yes
> >> checking pthread.h presence... yes
> >> checking for pthread_mutex_lock in -lpthread... yes
> >> config.status: creating include/clog_inttypes.h
> >> config.status: creating include/mpi_null.h
> >> config.status: creating include/mpe_log_thread.h
> >> config.status: creating etc/mpe_log.conf
> >> config.status: creating etc/mpe_nolog.conf
> >> config.status: creating etc/mpe_log_postlib.conf
> >> config.status: creating mpe_logging_conf.h
> >> configure: configuring in src/wrappers
> >> '/usr/local/mpich2-1.0.7/src/mpe2/src/wrappers/configure'
> >> --srcdir=/usr/local/mpich2-1.0.7/src/mpe2/src/wrappers
> >> Configuring MPE Wrapper Libraries For MPI with
> 'FFLAGS=
> >> '--srcdir=/usr/local/mpich2-1.0.7/src/mpe2/src/wrappers'
> >> checking stdarg.h usability... yes
> >> checking stdarg.h presence... yes
> >> checking for stdarg is correct... yes
> >> checking if compiler accepts prototypes ... yes
> >> checking for safe PMPI invocations ... no
> >> checking for the value of MPI_STATUS_SIZE ... 5
> >> config.status: creating etc/mpe_mpilog.conf
> >> config.status: creating etc/mpe_mpitrace.conf
> >> config.status: creating mpe_wrappers_conf.h
> >> configure: configuring in src/graphics
> >> '/usr/local/mpich2-1.0.7/src/mpe2/src/graphics/configure'
> >> --srcdir=/usr/local/mpich2-1.0.7/src/mpe2/src/graphics
> >> Configuring MPE X Graphics Library with
> >> '--srcdir=/usr/local/mpich2-1.0.7/src/mpe2/src/graphics'
> >> checking for X... libraries , headers in standard search path
> >> checking for long pointer... no
> >> checking for system... yes
> >> config.status: creating contrib/life/Makefile
> >> config.status: creating contrib/mandel/Makefile
> >> config.status: creating contrib/mastermind/Makefile
> >> config.status: creating contrib/test/Makefile
> >> config.status: creating etc/mpe_mpianim.conf
> >> config.status: creating etc/mpe_graphics.conf
> >> config.status: creating mpe_graphics_conf.h
> >> configure: configuring in src/collchk
> >> '/usr/local/mpich2-1.0.7/src/mpe2/src/collchk/configure'
> >> --srcdir=/usr/local/mpich2-1.0.7/src/mpe2/src/collchk
> >> Configuring MPE Collective and Datatype Checking Library with
> 'FFLAGS=
> >> '--srcdir=/usr/local/mpich2-1.0.7/src/mpe2/src/collchk'
> >> config.status: creating etc/mpe_mpicheck.conf
> >> config.status: creating mpe_collchk_conf.h
> >> configure: configuring in src/slog2sdk
> >> '/usr/local/mpich2-1.0.7/src/mpe2/src/slog2sdk/configure'
> >> --srcdir=/usr/local/mpich2-1.0.7/src/mpe2/src/slog2sdk
> >> Configuring SLOG2SDK with '--prefix=/usr/local/mpich2' 'CC=gcc'
> >> '--srcdir=/usr/local/mpich2-1.0.7/src/mpe2/src/slog2sdk'
> >> checking if CLASSPATH is set... no, good to go
> >> checking for java in user's PATH... found /usr/bin/java
> >> checking if /usr/bin/java works... yes
> >> checking if /usr/bin/java runs simple jar file... yes
> >> checking if /usr/bin/java runs simple Swing class... yes
> >> checking if /usr/bin/java runs simple Swing jar file... yes
> >> checking for Java version... java full version "gcj-1.5.0", i.e.
> Java
> >> 2 SDK
> >> checking for cygpath... no
> >> creating sample logfiles from source
> >> checking for leftover Makefiles in subpackages ... none
> >> config.status: creating sbin/install-package
> >> config.status: creating bin/slog2print
> >> config.status: creating bin/slog2navigator
> >> config.status: creating bin/slog2filter
> >> config.status: creating bin/slog2updater
> >> config.status: creating bin/logconvertor
> >> config.status: creating bin/jumpshot
> >> config.status: creating bin/clogprint
> >> config.status: creating bin/clogTOslog2
> >> config.status: creating bin/clog2print
> >> config.status: creating bin/clog2TOslog2
> >> configure: configuring in trace_rlog
> '/usr/local/mpich2-1.0.7/src/mpe2/src/slog2sdk/trace_rlog/configure'
> >> --srcdir=/usr/local/mpich2-1.0.7/src/mpe2/src/slog2sdk/trace_rlog
> >> Configuring TRACE_RLOG implementation with
> 'FFLAGS=
> '--srcdir=/usr/local/mpich2-1.0.7/src/mpe2/src/slog2sdk/trace_rlog'
> >> 'CXXFLAGS= -O2' 'CXX=c++'
> >> checking ctype.h usability... yes
> >> checking ctype.h presence... yes
> >> checking errno.h usability... yes
> >> checking errno.h presence... yes
> >> checking for __int64... no
> >> checking size of __int64... 0
> >> checking for sed... sed
> >> checking for a sed that does not truncate output... /bin/sed
> >> checking for ld used by gcc... /usr/bin/ld
> >> checking if the linker (/usr/bin/ld) is GNU ld... yes
> >> checking for /usr/bin/ld option to reload object files... -r
> >> checking for BSD-compatible nm... /usr/bin/nm -B
> >> checking how to recognise dependent libraries... pass_all
> >> checking dlfcn.h usability... yes
> >> checking dlfcn.h presence... yes
> >> checking for dlfcn.h... yes
> >> checking the maximum length of command line arguments... 32768
> >> checking command to parse /usr/bin/nm -B output from gcc object...
> ok
> >> checking for objdir... .libs
> >> checking for strip... strip
> >> checking if gcc static flag  works... yes
> >> checking if gcc supports -fno-rtti -fno-exceptions... no
> >> checking for gcc option to produce PIC... -fPIC
> >> checking if gcc PIC flag -fPIC works... yes
> >> checking if gcc supports -c -o file.o... yes
> >> checking whether the gcc linker (/usr/bin/ld) supports shared
> >> libraries... yes
> >> checking whether -lc should be explicitly linked in... no
> >> checking dynamic linker characteristics... GNU/Linux ld.so
> >> checking how to hardcode library paths into programs... immediate
> >> checking whether stripping libraries is possible... yes
> >> checking if libtool supports shared libraries... yes
> >> checking whether to build shared libraries... yes
> >> checking whether to build static libraries... no
> >> configure: creating libtool
> >> appending configuration tag "CXX" to libtool
> >> checking for ld used by c++... /usr/bin/ld
> >> checking whether the c++ linker (/usr/bin/ld) supports shared
> >> libraries... yes
> >> checking for c++ option to produce PIC... -fPIC
> >> checking if c++ PIC flag -fPIC works... yes
> >> checking if c++ supports -c -o file.o... yes
> >> libraries... yes
> >> appending configuration tag "F77" to libtool
> >> checking for g77 option to produce PIC... -fPIC
> >> checking if g77 PIC flag -fPIC works... yes
> >> checking if g77 supports -c -o file.o... yes
> >> checking whether the g77 linker (/usr/bin/ld) supports shared
> >> libraries... yes
> >> checking for malloc in -lefence... no
> >> checking for strstr... yes
> >> checking target system type... i686-pc-linux-gnu
> >> checking for javah in user's PATH... not found
> >> checking for javah in known locations... not found
> >> configure: WARNING:  Invalid JNI include dir, exit!
> >> configure: WARNING: SLOG2SDK: No sub-package has been configured
> >> MPE2:  "src/misc" "src/callstack" "src/logging" "src/wrappers"
> >> "src/graphics" "src/collchk" "src/slog2sdk" have been configured
> >> checking the sizeof MPI_Offset... 8
> >> checking whether the Fortran Offset type works with Fortran77...
> yes
> >> checking whether the Fortran Offset type works with Fortran90...
> yes
> >> Running Configure for F90 Type routines
> >> checking for cc... gcc
> >> checking whether the C compiler sets its return status
> correctly...
> >> yes
> >> checking for an ANSI C-conforming const... no
> yes
> >> checking for Fortran 90 compiler default output file name... a.out
> >> checking whether the Fortran 90 compiler works... yes
> >> checking for precision and range of reals...  6 , 37
> >> checking for precision and range of double precision...  15 , 307
> >> checking for range of integers...  9
> link
> >> programs
> >> checking for available integer kinds and ranges...  2 , 1, 4 , 2, 9
> >> 4, 18 , 8,
> >>  {  2 , 1 , 1 }, {  4 , 2 , 2 }, {  9 , 4 , 4 }, {  18 , 8 , 8 },
> >> config.status: creating mpif90model.h
> >> config.status: creating src/include/Makefile
> >> config.status: creating src/include/mpich2info.h
> >> config.status: creating mpich2-doxygen
> >> config.status: creating src/include/mpichtimer.h
> >> config.status: creating src/binding/Makefile
> >> config.status: creating src/binding/cxx/Makefile
> >> config.status: creating src/binding/cxx/mpicxx.h
> >> config.status: creating src/binding/f77/Makefile
> >> config.status: creating src/binding/f77/mpif.h
> >> config.status: creating src/binding/f77/setbotf.f
> >> config.status: creating src/binding/f90/Makefile
> >> config.status: creating src/binding/f90/mpi_sizeofs.f90
> >> config.status: creating src/pkgconfig/mpich2-ch3.pc
> >> config.status: creating src/pkgconfig/Makefile
> >> config.status: creating src/env/mpicc
> >> config.status: creating src/env/mpicc.conf
> >> config.status: creating src/env/mpicc.bash
> >> config.status: creating src/env/mpicxx
> >> config.status: creating src/env/mpicxx.conf
> >> config.status: creating src/env/mpicxx.bash
> >> config.status: creating src/env/mpif77
> >> config.status: creating src/env/mpif77.conf
> >> config.status: creating src/env/mpif77.bash
> >> config.status: creating src/env/mpif90
> >> config.status: creating src/env/mpif90.conf
> >> config.status: creating src/env/mpif90.bash
> >> config.status: creating src/env/parkill
> >> config.status: creating src/env/Makefile
> >> config.status: creating src/util/createshlib
> >> config.status: creating src/mpi/Makefile
> >> config.status: creating src/mpi/attr/Makefile
> >> config.status: creating src/mpi/coll/Makefile
> >> config.status: creating src/mpi/comm/Makefile
> >> config.status: creating src/mpi/datatype/Makefile
> >> config.status: creating src/mpi/debugger/Makefile
> >> config.status: creating src/mpi/errhan/Makefile
> >> config.status: creating src/mpi/group/Makefile
> >> config.status: creating src/mpi/init/Makefile
> >> config.status: creating src/mpi/misc/Makefile
> >> config.status: creating src/mpi/pt2pt/Makefile
> >> config.status: creating src/mpi/rma/Makefile
> >> config.status: creating src/mpi/spawn/Makefile
> >> config.status: creating src/mpi/timer/Makefile
> >> config.status: creating src/mpi/topo/Makefile
> >> config.status: creating src/mpid/Makefile
> >> config.status: creating src/mpid/common/Makefile
> >> config.status: creating src/mpid/common/datatype/Makefile
> >> config.status: creating src/mpid/common/datatype/dataloop/Makefile
> >> config.status: creating src/mpid/common/locks/Makefile
> >> config.status: creating src/pm/Makefile
> >> config.status: creating src/pmi/Makefile
> >> config.status: creating src/nameserv/Makefile
> >> config.status: creating src/nameserv/file/Makefile
> >> config.status: creating src/nameserv/mpd/Makefile
> >> config.status: creating src/nameserv/pmi/Makefile
> >> config.status: creating src/nameserv/test/Makefile
> >> config.status: creating src/util/Makefile
> >> config.status: creating src/util/info/Makefile
> >> config.status: creating src/util/instrm/Makefile
> >> config.status: creating src/util/thread/Makefile
> >> config.status: creating src/util/thread/mpe_thread.h
> >> config.status: creating src/util/mem/Makefile
> >> config.status: creating src/util/msgs/Makefile
> >> config.status: creating src/util/param/Makefile
> >> config.status: creating src/util/dbg/Makefile
> >> config.status: creating src/util/dbg/getfuncstack
> >> config.status: creating src/util/osserv/Makefile
> >> config.status: creating src/include/mpi.h
> >> config.status: creating test/util/Makefile
> >> config.status: creating test/basic/Makefile
> >> config.status: creating test/commands/Makefile
> >> config.status: creating test/commands/cmdtests
> >> config.status: creating test/mpid/Makefile
> >> config.status: creating test/mpid/ch3/Makefile
> >> config.status: creating examples/Makefile
> >> config.status: creating examples/f77/Makefile
> >> config.status: creating examples/f90/Makefile
> >> config.status: creating examples/cxx/Makefile
> >> config.status: creating src/util/logging/Makefile
> >> config.status: creating src/util/logging/common/Makefile
> >> config.status: creating doc/Makefile
> >> config.status: creating doc/mansrc/Makefile
> >> config.status: creating doc/mansrc/createhtmlindex
> >> config.status: creating doc/refman/Makefile
> >> config.status: creating doc/installguide/Makefile
> >> config.status: creating doc/userguide/Makefile
> >> config.status: creating doc/logging/Makefile
> >> config.status: creating doc/design/Makefile
> >> config.status: creating doc/smpd/Makefile
> >> config.status: creating doc/windev/Makefile
> >> config.status: creating src/include/mpichconf.h
> >> config.status: src/include/mpichconf.h is unchanged
> >> config.status: executing default-2 commands
> >> config.status: executing default-3 commands
> >> config.status: executing default-4 commands
> >> copying ./src/util/thread/mpe_thread_posix.c to
> >> src/util/thread/mpe_thread.c
> >> moving mpe_thread.h to src/include
> >> config.status: executing default-5 commands
> >> config.status: executing default-6 commands
> >> config.status: executing default-7 commands
> >> config.status: executing default-8 commands
> >> config.status: executing default-9 commands
> >> config.status: executing default-10 commands
> >> config.status: executing default-11 commands
> >> config.status: executing default-12 commands
> >> config.status: executing default-13 commands
> >> config.status: executing default-14 commands
> >> configure: configuring in test/mpi
> >> configure: running /bin/sh './configure' --prefix=/usr/local/mpich2
> >> '--prefix=/usr/local/mpich2' --cache-file=/dev/null --srcdir=.
> >> RUNNING CONFIGURE FOR MPI TESTS
> >> Configuring tests for MPICH2
> >> checking whether struct hostent contains h_addr_list... no
> >> checking for Fortran libraries needed for getarg... none needed
> >> checking whether Fortran has pointer declaration... no
> yes
> >> checking whether Fortran 90 has Cray-style pointer declaration...
> yes
> >> config.status: creating maint/testmerge
> >> config.status: creating runtests
> >> config.status: creating basic/Makefile
> >> config.status: creating attr/Makefile
> >> config.status: creating coll/Makefile
> >> config.status: creating comm/Makefile
> >> config.status: creating datatype/Makefile
> >> config.status: creating errhan/Makefile
> >> config.status: creating group/Makefile
> >> config.status: creating info/Makefile
> >> config.status: creating init/Makefile
> >> config.status: creating pt2pt/Makefile
> >> config.status: creating rma/Makefile
> >> config.status: creating spawn/Makefile
> >> config.status: creating topo/Makefile
> >> config.status: creating io/Makefile
> >> config.status: creating f77/Makefile
> >> config.status: creating f77/attr/Makefile
> >> config.status: creating f77/attr/attraints.h
> >> config.status: creating f77/pt2pt/attr1aints.h
> >> config.status: creating f77/ext/add1size.h
> >> config.status: creating f77/datatype/Makefile
> >> config.status: creating f77/datatype/typeaints.h
> >> config.status: creating f77/util/Makefile
> >> config.status: creating f77/coll/Makefile
> >> config.status: creating f77/comm/Makefile
> >> config.status: creating f77/topo/Makefile
> >> config.status: creating f77/init/Makefile
> >> config.status: creating f77/rma/addsize.h
> >> config.status: creating f77/pt2pt/Makefile
> >> config.status: creating f77/info/Makefile
> >> config.status: creating f77/spawn/Makefile
> >> config.status: creating f77/spawn/type1aint.h
> >> config.status: creating f77/rma/Makefile
> >> config.status: creating f77/ext/Makefile
> >> config.status: creating f77/ext/testlist
> >> config.status: creating f77/io/Makefile
> >> config.status: creating f77/io/iooffset.h
> >> config.status: creating f77/io/iodisp.h
> >> config.status: creating f77/io/ioaint.h
> >> config.status: creating f90/Makefile
> >> config.status: creating f90/attr/Makefile
> >> config.status: creating f90/datatype/Makefile
> >> config.status: creating f90/f90types/Makefile
> >> config.status: creating f90/util/Makefile
> >> config.status: creating f90/coll/Makefile
> >> config.status: creating f90/comm/Makefile
> >> config.status: creating f90/topo/Makefile
> >> config.status: creating f90/init/Makefile
> >> config.status: creating f90/pt2pt/Makefile
> >> config.status: creating f90/rma/Makefile
> >> config.status: creating f90/info/Makefile
> >> config.status: creating f90/spawn/Makefile
> >> config.status: creating f90/timer/Makefile
> >> config.status: creating f90/ext/Makefile
> >> config.status: creating f90/ext/testlist
> >> config.status: creating f90/io/Makefile
> >> config.status: creating f90/misc/Makefile
> >> config.status: creating cxx/Makefile
> >> config.status: creating cxx/util/Makefile
> >> config.status: creating cxx/attr/Makefile
> >> config.status: creating cxx/pt2pt/Makefile
> >> config.status: creating cxx/comm/Makefile
> >> config.status: creating cxx/coll/Makefile
> >> config.status: creating cxx/info/Makefile
> >> config.status: creating cxx/datatype/Makefile
> >> config.status: creating cxx/io/Makefile
> >> config.status: creating cxx/init/Makefile
> >> config.status: creating cxx/rma/Makefile
> >> config.status: creating cxx/spawn/Makefile
> >> config.status: creating threads/Makefile
> >> config.status: creating threads/pt2pt/Makefile
> >> config.status: creating threads/util/Makefile
> >> config.status: creating threads/comm/Makefile
> >> config.status: creating errors/Makefile
> >> config.status: creating errors/coll/Makefile
> >> config.status: creating errors/comm/Makefile
> >> config.status: creating errors/group/Makefile
> >> config.status: creating errors/pt2pt/Makefile
> >> config.status: creating errors/rma/Makefile
> >> config.status: creating errors/spawn/Makefile
> >> config.status: creating errors/topo/Makefile
> >> config.status: creating errors/io/Makefile
> >> config.status: creating errors/cxx/Makefile
> >> config.status: creating errors/cxx/errhan/Makefile
> >> config.status: creating errors/cxx/io/Makefile
> >> config.status: creating errors/f77/Makefile
> >> config.status: creating errors/f90/Makefile
> >> config.status: creating manual/Makefile
> >> config.status: creating manual/manyconnect
> >> config.status: creating perf/Makefile
> >> config.status: creating testlist
> >> config.status: creating cxx/testlist
> >> config.status: creating f77/testlist
> >> config.status: creating f90/testlist
> >> config.status: creating errors/testlist
> >> config.status: creating errors/cxx/testlist
> >> config.status: creating include/mpitestconf.h
> >> config.status: include/mpitestconf.h is unchanged
> >> Configuration completed.
> >> if [ ! -d /usr/local/mpich2 ] ; then mkdir -p /usr/local/mpich2 ;
> fi
> >> if [ ! -d /usr/local/mpich2/www ] ; then mkdir -p
> >> /usr/local/mpich2/www ; fi
> >> if [ ! -d /usr/local/mpich2/man ] ; then mkdir -p
> >> /usr/local/mpich2/man ; fi
> >> if [ ! -d /usr/local/mpich2/include ] ; then mkdir -p
> >> /usr/local/mpich2/include ; fi
> fi
> >> if [ ! -d /usr/local/mpich2/lib ] ; then mkdir -p
> >> /usr/local/mpich2/lib ; fi
> >> make install-local
> >> make[1]: Entering directory `/usr/local/mpich2-1.0.7'
> >> if [ "no" = "yes" ] ; then \
> >> 	    /usr/bin/install -c -m 644 src/mpi/debugger/libtvmpich2.so \
> >> 			/usr/local/mpich2/lib/libtvmpich2.so ; fi
> >> if [ -n "" ] ; then \
> >> 	    for pm in  /dev/null ; do \
> >> 		if [ -d src/pm/$pm ] ; then \
> >> 		     (cd src/pm/$pm && make install-alt ) ; fi ; \
> >> 	    done ; \
> >> 	fi
> >> make[1]: Leaving directory `/usr/local/mpich2-1.0.7'
> >> /usr/bin/install -c -m 644 src/include/mpi.h
> >> /usr/local/mpich2/include/mpi.h
> >> /usr/bin/install -c -m 644 lib/libmpich.a
> >> /usr/local/mpich2/lib/libmpich.a
> >> if [ ! -d /usr/local/mpich2/doc ] ; then mkdir -p
> >> /usr/local/mpich2/doc ; fi
> >> /usr/bin/install -c -m 644 index.htm
> /usr/local/mpich2/www/index.htm
> >> /usr/local/mpich2/www/www1/index.htm
> >> /usr/bin/install -c -m 644 mpicc.html
> >> /usr/local/mpich2/www/www1/mpicc.html
> >> /usr/bin/install -c -m 644 mpicxx.html
> >> /usr/local/mpich2/www/www1/mpicxx.html
> >> /usr/bin/install -c -m 644 mpiexec.html
> >> /usr/local/mpich2/www/www1/mpiexec.html
> >> /usr/bin/install -c -m 644 mpif77.html
> >> /usr/local/mpich2/www/www1/mpif77.html
> >> /usr/bin/install -c -m 644 mpif90.html
> >> /usr/local/mpich2/www/www1/mpif90.html
> >> /usr/bin/install -c -m 644 MPI.html
> >> /usr/local/mpich2/www/www1/MPI.html
> >> /usr/local/mpich2/www/www3/index.htm
> >> /usr/bin/install -c -m 644 MPI_Abort.html
> >> /usr/local/mpich2/www/www3/MPI_Abort.html
> >> /usr/bin/install -c -m 644 MPI_Accumulate.html
> >> /usr/local/mpich2/www/www3/MPI_Accumulate.html
> >> /usr/bin/install -c -m 644 MPI_Add_error_class.html
> >> /usr/local/mpich2/www/www3/MPI_Add_error_class.html
> >> /usr/bin/install -c -m 644 MPI_Add_error_code.html
> >> /usr/local/mpich2/www/www3/MPI_Add_error_code.html
> >> /usr/bin/install -c -m 644 MPI_Add_error_string.html
> >> /usr/local/mpich2/www/www3/MPI_Add_error_string.html
> >> /usr/bin/install -c -m 644 MPI_Address.html
> >> /usr/local/mpich2/www/www3/MPI_Address.html
> >> /usr/bin/install -c -m 644 MPI_Allgather.html
> >> /usr/local/mpich2/www/www3/MPI_Allgather.html
> >> /usr/bin/install -c -m 644 MPI_Allgatherv.html
> >> /usr/local/mpich2/www/www3/MPI_Allgatherv.html
> >> /usr/bin/install -c -m 644 MPI_Alloc_mem.html
> >> /usr/local/mpich2/www/www3/MPI_Alloc_mem.html
> >> /usr/bin/install -c -m 644 MPI_Allreduce.html
> >> /usr/local/mpich2/www/www3/MPI_Allreduce.html
> >> /usr/bin/install -c -m 644 MPI_Alltoall.html
> >> /usr/local/mpich2/www/www3/MPI_Alltoall.html
> >> /usr/bin/install -c -m 644 MPI_Alltoallv.html
> >> /usr/local/mpich2/www/www3/MPI_Alltoallv.html
> >> /usr/bin/install -c -m 644 MPI_Alltoallw.html
> >> /usr/local/mpich2/www/www3/MPI_Alltoallw.html
> >> /usr/bin/install -c -m 644 MPI_Attr_delete.html
> >> /usr/local/mpich2/www/www3/MPI_Attr_delete.html
> >> /usr/bin/install -c -m 644 MPI_Attr_get.html
> >> /usr/local/mpich2/www/www3/MPI_Attr_get.html
> >> /usr/bin/install -c -m 644 MPI_Attr_put.html
> >> /usr/local/mpich2/www/www3/MPI_Attr_put.html
> >> /usr/bin/install -c -m 644 MPI_Barrier.html
> >> /usr/local/mpich2/www/www3/MPI_Barrier.html
> >> /usr/bin/install -c -m 644 MPI_Bcast.html
> >> /usr/local/mpich2/www/www3/MPI_Bcast.html
> >> /usr/bin/install -c -m 644 MPI_Bsend.html
> >> /usr/local/mpich2/www/www3/MPI_Bsend.html
> >> /usr/bin/install -c -m 644 MPI_Bsend_init.html
> >> /usr/local/mpich2/www/www3/MPI_Bsend_init.html
> >> /usr/bin/install -c -m 644 MPI_Buffer_attach.html
> >> /usr/local/mpich2/www/www3/MPI_Buffer_attach.html
> >> /usr/bin/install -c -m 644 MPI_Buffer_detach.html
> >> /usr/local/mpich2/www/www3/MPI_Buffer_detach.html
> >> /usr/bin/install -c -m 644 MPI_Cancel.html
> >> /usr/local/mpich2/www/www3/MPI_Cancel.html
> >> /usr/bin/install -c -m 644 MPI_Cart_coords.html
> >> /usr/local/mpich2/www/www3/MPI_Cart_coords.html
> >> /usr/bin/install -c -m 644 MPI_Cart_create.html
> >> /usr/local/mpich2/www/www3/MPI_Cart_create.html
> >> /usr/bin/install -c -m 644 MPI_Cartdim_get.html
> >> /usr/local/mpich2/www/www3/MPI_Cartdim_get.html
> >> /usr/bin/install -c -m 644 MPI_Cart_get.html
> >> /usr/local/mpich2/www/www3/MPI_Cart_get.html
> >> /usr/bin/install -c -m 644 MPI_Cart_map.html
> >> /usr/local/mpich2/www/www3/MPI_Cart_map.html
> >> /usr/bin/install -c -m 644 MPI_Cart_rank.html
> >> /usr/local/mpich2/www/www3/MPI_Cart_rank.html
> >> /usr/bin/install -c -m 644 MPI_Cart_shift.html
> >> /usr/local/mpich2/www/www3/MPI_Cart_shift.html
> >> /usr/bin/install -c -m 644 MPI_Cart_sub.html
> >> /usr/local/mpich2/www/www3/MPI_Cart_sub.html
> >> /usr/bin/install -c -m 644 MPI_Close_port.html
> >> /usr/local/mpich2/www/www3/MPI_Close_port.html
> >> /usr/bin/install -c -m 644 MPI_Comm_accept.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_accept.html
> >> /usr/bin/install -c -m 644 MPI_Comm_call_errhandler.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_call_errhandler.html
> >> /usr/bin/install -c -m 644 MPI_Comm_compare.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_compare.html
> >> /usr/bin/install -c -m 644 MPI_Comm_connect.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_connect.html
> >> /usr/bin/install -c -m 644 MPI_Comm_create_errhandler.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_create_errhandler.html
> >> /usr/bin/install -c -m 644 MPI_Comm_create.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_create.html
> >> /usr/bin/install -c -m 644 MPI_Comm_create_keyval.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_create_keyval.html
> >> /usr/bin/install -c -m 644 MPI_Comm_delete_attr.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_delete_attr.html
> >> /usr/bin/install -c -m 644 MPI_Comm_disconnect.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_disconnect.html
> >> /usr/bin/install -c -m 644 MPI_Comm_dup.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_dup.html
> >> /usr/bin/install -c -m 644 MPI_Comm_free.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_free.html
> >> /usr/bin/install -c -m 644 MPI_Comm_free_keyval.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_free_keyval.html
> >> /usr/bin/install -c -m 644 MPI_Comm_get_attr.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_get_attr.html
> >> /usr/bin/install -c -m 644 MPI_Comm_get_errhandler.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_get_errhandler.html
> >> /usr/bin/install -c -m 644 MPI_Comm_get_name.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_get_name.html
> >> /usr/bin/install -c -m 644 MPI_Comm_get_parent.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_get_parent.html
> >> /usr/bin/install -c -m 644 MPI_Comm_group.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_group.html
> >> /usr/bin/install -c -m 644 MPI_Comm_join.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_join.html
> >> /usr/bin/install -c -m 644 MPI_Comm_rank.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_rank.html
> >> /usr/bin/install -c -m 644 MPI_Comm_remote_group.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_remote_group.html
> >> /usr/bin/install -c -m 644 MPI_Comm_remote_size.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_remote_size.html
> >> /usr/bin/install -c -m 644 MPI_Comm_set_attr.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_set_attr.html
> >> /usr/bin/install -c -m 644 MPI_Comm_set_errhandler.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_set_errhandler.html
> >> /usr/bin/install -c -m 644 MPI_Comm_set_name.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_set_name.html
> >> /usr/bin/install -c -m 644 MPI_Comm_size.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_size.html
> >> /usr/bin/install -c -m 644 MPI_Comm_spawn.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_spawn.html
> >> /usr/bin/install -c -m 644 MPI_Comm_spawn_multiple.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_spawn_multiple.html
> >> /usr/bin/install -c -m 644 MPI_Comm_split.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_split.html
> >> /usr/bin/install -c -m 644 MPI_Comm_test_inter.html
> >> /usr/local/mpich2/www/www3/MPI_Comm_test_inter.html
> >> /usr/bin/install -c -m 644 MPI_Dims_create.html
> >> /usr/local/mpich2/www/www3/MPI_Dims_create.html
> >> /usr/bin/install -c -m 644 MPI_Errhandler_create.html
> >> /usr/local/mpich2/www/www3/MPI_Errhandler_create.html
> >> /usr/bin/install -c -m 644 MPI_Errhandler_free.html
> >> /usr/local/mpich2/www/www3/MPI_Errhandler_free.html
> >> /usr/bin/install -c -m 644 MPI_Errhandler_get.html
> >> /usr/local/mpich2/www/www3/MPI_Errhandler_get.html
> >> /usr/bin/install -c -m 644 MPI_Errhandler_set.html
> >> /usr/local/mpich2/www/www3/MPI_Errhandler_set.html
> >> /usr/bin/install -c -m 644 MPI_Error_class.html
> >> /usr/local/mpich2/www/www3/MPI_Error_class.html
> >> /usr/bin/install -c -m 644 MPI_Error_string.html
> >> /usr/local/mpich2/www/www3/MPI_Error_string.html
> >> /usr/bin/install -c -m 644 MPI_Exscan.html
> >> /usr/local/mpich2/www/www3/MPI_Exscan.html
> >> /usr/bin/install -c -m 644 MPI_File_c2f.html
> >> /usr/local/mpich2/www/www3/MPI_File_c2f.html
> >> /usr/bin/install -c -m 644 MPI_File_call_errhandler.html
> >> /usr/local/mpich2/www/www3/MPI_File_call_errhandler.html
> >> /usr/bin/install -c -m 644 MPI_File_close.html
> >> /usr/local/mpich2/www/www3/MPI_File_close.html
> >> /usr/bin/install -c -m 644 MPI_File_create_errhandler.html
> >> /usr/local/mpich2/www/www3/MPI_File_create_errhandler.html
> >> /usr/bin/install -c -m 644 MPI_File_delete.html
> >> /usr/local/mpich2/www/www3/MPI_File_delete.html
> >> /usr/bin/install -c -m 644 MPI_File_f2c.html
> >> /usr/local/mpich2/www/www3/MPI_File_f2c.html
> >> /usr/bin/install -c -m 644 MPI_File_get_amode.html
> >> /usr/local/mpich2/www/www3/MPI_File_get_amode.html
> >> /usr/bin/install -c -m 644 MPI_File_get_atomicity.html
> >> /usr/local/mpich2/www/www3/MPI_File_get_atomicity.html
> >> /usr/bin/install -c -m 644 MPI_File_get_byte_offset.html
> >> /usr/local/mpich2/www/www3/MPI_File_get_byte_offset.html
> >> /usr/bin/install -c -m 644 MPI_File_get_errhandler.html
> >> /usr/local/mpich2/www/www3/MPI_File_get_errhandler.html
> >> /usr/bin/install -c -m 644 MPI_File_get_group.html
> >> /usr/local/mpich2/www/www3/MPI_File_get_group.html
> >> /usr/bin/install -c -m 644 MPI_File_get_info.html
> >> /usr/local/mpich2/www/www3/MPI_File_get_info.html
> >> /usr/bin/install -c -m 644 MPI_File_get_position.html
> >> /usr/local/mpich2/www/www3/MPI_File_get_position.html
> >> /usr/bin/install -c -m 644 MPI_File_get_position_shared.html
> >> /usr/local/mpich2/www/www3/MPI_File_get_position_shared.html
> >> /usr/bin/install -c -m 644 MPI_File_get_size.html
> >> /usr/local/mpich2/www/www3/MPI_File_get_size.html
> >> /usr/bin/install -c -m 644 MPI_File_get_type_extent.html
> >> /usr/local/mpich2/www/www3/MPI_File_get_type_extent.html
> >> /usr/bin/install -c -m 644 MPI_File_get_view.html
> >> /usr/local/mpich2/www/www3/MPI_File_get_view.html
> >> /usr/bin/install -c -m 644 MPI_File_iread_at.html
> >> /usr/local/mpich2/www/www3/MPI_File_iread_at.html
> >> /usr/bin/install -c -m 644 MPI_File_iread.html
> >> /usr/local/mpich2/www/www3/MPI_File_iread.html
> >> /usr/bin/install -c -m 644 MPI_File_iread_shared.html
> >> /usr/local/mpich2/www/www3/MPI_File_iread_shared.html
> >> /usr/bin/install -c -m 644 MPI_File_iwrite_at.html
> >> /usr/local/mpich2/www/www3/MPI_File_iwrite_at.html
> >> /usr/bin/install -c -m 644 MPI_File_iwrite.html
> >> /usr/local/mpich2/www/www3/MPI_File_iwrite.html
> >> /usr/bin/install -c -m 644 MPI_File_iwrite_shared.html
> >> /usr/local/mpich2/www/www3/MPI_File_iwrite_shared.html
> >> /usr/bin/install -c -m 644 MPI_File_open.html
> >> /usr/local/mpich2/www/www3/MPI_File_open.html
> >> /usr/bin/install -c -m 644 MPI_File_preallocate.html
> >> /usr/local/mpich2/www/www3/MPI_File_preallocate.html
> >> /usr/bin/install -c -m 644 MPI_File_read_all_begin.html
> >> /usr/local/mpich2/www/www3/MPI_File_read_all_begin.html
> >> /usr/bin/install -c -m 644 MPI_File_read_all_end.html
> >> /usr/local/mpich2/www/www3/MPI_File_read_all_end.html
> >> /usr/bin/install -c -m 644 MPI_File_read_all.html
> >> /usr/local/mpich2/www/www3/MPI_File_read_all.html
> >> /usr/bin/install -c -m 644 MPI_File_read_at_all_begin.html
> >> /usr/local/mpich2/www/www3/MPI_File_read_at_all_begin.html
> >> /usr/bin/install -c -m 644 MPI_File_read_at_all_end.html
> >> /usr/local/mpich2/www/www3/MPI_File_read_at_all_end.html
> >> /usr/bin/install -c -m 644 MPI_File_read_at_all.html
> >> /usr/local/mpich2/www/www3/MPI_File_read_at_all.html
> >> /usr/bin/install -c -m 644 MPI_File_read_at.html
> >> /usr/local/mpich2/www/www3/MPI_File_read_at.html
> >> /usr/bin/install -c -m 644 MPI_File_read.html
> >> /usr/local/mpich2/www/www3/MPI_File_read.html
> >> /usr/bin/install -c -m 644 MPI_File_read_ordered_begin.html
> >> /usr/local/mpich2/www/www3/MPI_File_read_ordered_begin.html
> >> /usr/bin/install -c -m 644 MPI_File_read_ordered_end.html
> >> /usr/local/mpich2/www/www3/MPI_File_read_ordered_end.html
> >> /usr/bin/install -c -m 644 MPI_File_read_ordered.html
> >> /usr/local/mpich2/www/www3/MPI_File_read_ordered.html
> >> /usr/bin/install -c -m 644 MPI_File_read_shared.html
> >> /usr/local/mpich2/www/www3/MPI_File_read_shared.html
> >> /usr/bin/install -c -m 644 MPI_File_seek.html
> >> /usr/local/mpich2/www/www3/MPI_File_seek.html
> >> /usr/bin/install -c -m 644 MPI_File_seek_shared.html
> >> /usr/local/mpich2/www/www3/MPI_File_seek_shared.html
> >> /usr/bin/install -c -m 644 MPI_File_set_atomicity.html
> >> /usr/local/mpich2/www/www3/MPI_File_set_atomicity.html
> >> /usr/bin/install -c -m 644 MPI_File_set_errhandler.html
> >> /usr/local/mpich2/www/www3/MPI_File_set_errhandler.html
> >> /usr/bin/install -c -m 644 MPI_File_set_info.html
> >> /usr/local/mpich2/www/www3/MPI_File_set_info.html
> >> /usr/bin/install -c -m 644 MPI_File_set_size.html
> >> /usr/local/mpich2/www/www3/MPI_File_set_size.html
> >> /usr/bin/install -c -m 644 MPI_File_set_view.html
> >> /usr/local/mpich2/www/www3/MPI_File_set_view.html
> >> /usr/bin/install -c -m 644 MPI_File_sync.html
> >> /usr/local/mpich2/www/www3/MPI_File_sync.html
> >> /usr/bin/install -c -m 644 MPI_File_write_all_begin.html
> >> /usr/local/mpich2/www/www3/MPI_File_write_all_begin.html
> >> /usr/bin/install -c -m 644 MPI_File_write_all_end.html
> >> /usr/local/mpich2/www/www3/MPI_File_write_all_end.html
> >> /usr/bin/install -c -m 644 MPI_File_write_all.html
> >> /usr/local/mpich2/www/www3/MPI_File_write_all.html
> >> /usr/bin/install -c -m 644 MPI_File_write_at_all_begin.html
> >> /usr/local/mpich2/www/www3/MPI_File_write_at_all_begin.html
> >> /usr/bin/install -c -m 644 MPI_File_write_at_all_end.html
> >> /usr/local/mpich2/www/www3/MPI_File_write_at_all_end.html
> >> /usr/bin/install -c -m 644 MPI_File_write_at_all.html
> >> /usr/local/mpich2/www/www3/MPI_File_write_at_all.html
> >> /usr/bin/install -c -m 644 MPI_File_write_at.html
> >> /usr/local/mpich2/www/www3/MPI_File_write_at.html
> >> /usr/bin/install -c -m 644 MPI_File_write.html
> >> /usr/local/mpich2/www/www3/MPI_File_write.html
> >> /usr/bin/install -c -m 644 MPI_File_write_ordered_begin.html
> >> /usr/local/mpich2/www/www3/MPI_File_write_ordered_begin.html
> >> /usr/bin/install -c -m 644 MPI_File_write_ordered_end.html
> >> /usr/local/mpich2/www/www3/MPI_File_write_ordered_end.html
> >> /usr/bin/install -c -m 644 MPI_File_write_ordered.html
> >> /usr/local/mpich2/www/www3/MPI_File_write_ordered.html
> >> /usr/bin/install -c -m 644 MPI_File_write_shared.html
> >> /usr/local/mpich2/www/www3/MPI_File_write_shared.html
> >> /usr/bin/install -c -m 644 MPI_Finalized.html
> >> /usr/local/mpich2/www/www3/MPI_Finalized.html
> >> /usr/bin/install -c -m 644 MPI_Finalize.html
> >> /usr/local/mpich2/www/www3/MPI_Finalize.html
> for dir in src/util/thread src/env src/pkgconfig  src/binding/f77
> src/binding/f90 src/binding/cxx  src/pm/mpd src/mpe2 - ; do \
> 		if [ "$dir" = "-" ] ; then break ; fi ; \
> 		(cd $dir && make installcheck ; ) ; done
> make[1]: Entering directory `/usr/local/mpich2-1.0.7/src/util/thread'
> make[1]: Nothing to be done for `installcheck'.
> make[1]: Leaving directory `/usr/local/mpich2-1.0.7/src/util/thread'
> make[1]: Entering directory `/usr/local/mpich2-1.0.7/src/env'
> make[1]: Leaving directory `/usr/local/mpich2-1.0.7/src/env'
> make[1]: Entering directory `/usr/local/mpich2-1.0.7/src/pkgconfig'
> make[1]: Leaving directory `/usr/local/mpich2-1.0.7/src/pkgconfig'
> make[1]: Entering directory `/usr/local/mpich2-1.0.7/src/binding/f77'
> make[1]: Leaving directory `/usr/local/mpich2-1.0.7/src/binding/f77'
> make[1]: Entering directory `/usr/local/mpich2-1.0.7/src/binding/f90'
> make[1]: Leaving directory `/usr/local/mpich2-1.0.7/src/binding/f90'
> make[1]: Entering directory `/usr/local/mpich2-1.0.7/src/binding/cxx'
> make[1]: Leaving directory `/usr/local/mpich2-1.0.7/src/binding/cxx'
> make[1]: Entering directory `/usr/local/mpich2-1.0.7/src/pm/mpd'
> make[1]: *** No rule to make target `installcheck'.  Stop.
> make[1]: Leaving directory `/usr/local/mpich2-1.0.7/src/pm/mpd'
> make[1]: Entering directory `/usr/local/mpich2-1.0.7/src/mpe2'
> Running installation linktest for C logging program...
> *** Link C program with the MPI tracing library
> .......................... Yes.
> *** Link C program with the MPI logging library
> *** Link C program with the MPI and manual logging libraries
> ............. Yes.
> Running installation linktest for Fortran logging program...
> *** Link F77 program with the MPI and manual logging libraries
> ........... Yes.
> Running installation linktest for C graphics program...
> *** Link C program with the MPI animation library
> *** Link C program with the X11 graphics library
> Running installation linktest for Fortran graphics program...
> *** Link F77 program with the X11 graphics library
> Running installation linktest for C collchk program...
> *** Link C program with the MPI collective/datatype checking library
> ..... Yes.
> Running installation linktest for Fortran collchk program...
> *** Link F77 program with the MPI collective/datatype checking library
> ... Yes.
> make[1]: Leaving directory `/usr/local/mpich2-1.0.7/src/mpe2'
> make installcheck-postamble
> make[2]: Entering directory `/usr/local/mpich2-1.0.7/src/mpe2'
> Running installation runtest for C logging program...
> *** Test C program with the MPI tracing library
> *** Test C program with the MPI logging library
>     Convert cpi_log.clog2 to slog2 file .............. Yes.
> *** Test C program with the MPI and manual logging libraries
> ............. Yes.
>     Convert cpilog.clog2 to slog2 file .............. Yes.
> Running installation runtest for Fortran logging program...
> *** Test F77 program with the MPI and manual logging libraries
> ........... Yes.
>     Convert fpilog.clog2 to slog2 file .............. Yes.
> Running installation runtest for C graphics program...
> *** Test C program with the MPI animation library
> ........................ No.
>     The failed command is :
> /usr/local/mpich2/bin/mpiexec -n 4 cpi_anim
> Could not open display
> Failed to connect to 192.168.1.4:0.0 from snow
> rank 2 in job 5  snow_47787   caused collective abort of all ranks
>   exit status of rank 2: killed by signal 11
> rank 1 in job 5  snow_47787   caused collective abort of all ranks
>   exit status of rank 1: killed by signal 11
> rank 0 in job 5  snow_47787   caused collective abort of all ranks
>   exit status of rank 0: killed by signal 11
> *** Test C program with the X11 graphics library
> ......................... No.
> /usr/local/mpich2/bin/mpiexec -n 4 cxgraphics
> 0 : MPE_Open_graphics() fails
> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0[cli_0]:
> aborting job:
> 2 : MPE_Open_graphics() fails
> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 2[cli_2]:
> aborting job:
> 1 : MPE_Open_graphics() fails
> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 1[cli_1]:
> aborting job:
> rank 2 in job 6  snow_47787   caused collective abort of all ranks
>   exit status of rank 2: return code 1
> rank 0 in job 6  snow_47787   caused collective abort of all ranks
>   exit status of rank 0: return code 1
> Running installation runtest for Fortran graphics program...
> *** Test F77 program with the X11 graphics library
> /usr/local/mpich2/bin/mpiexec -n 4 fxgraphics
>   0 : MPE_Open_graphics =   1
>   1 : MPE_Open_graphics =   1
>   2 : MPE_Open_graphics =   1
> rank 3 in job 7  snow_47787   caused collective abort of all ranks
>   exit status of rank 3: killed by signal 11
> rank 2 in job 7  snow_47787   caused collective abort of all ranks
> rank 0 in job 7  snow_47787   caused collective abort of all ranks
>   3 : MPE_Open_graphics =   1
> Running installation runtest for C collchk program...
> *** Test C program with the MPI collective/datatype checking library
> ..... No.
> /usr/local/mpich2/bin/mpiexec -n 4 wrong_int_byte
> Starting MPI Collective and Datatype Checking!
> Backtrace of the callstack at rank 3:
> 	At [0]: wrong_int_byte(CollChk_err_han+0x128)[0x8051c28]
> 	At [1]: wrong_int_byte(CollChk_dtype_scatter+0x117)[0x80539e7]
> 	At [2]: wrong_int_byte(CollChk_dtype_bcast+0x3d)[0x8053a8d]
> 	At [3]: wrong_int_byte(MPI_Bcast+0x7a)[0x8051a9a]
> 	At [4]: wrong_int_byte(main+0xbe)[0x8051a0e]
> 	At [5]:
> /lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe0)[0xb7da2450]
> 	At [6]: wrong_int_byte[0x80518e1]
> Fatal error in MPI_Comm_call_errhandler:
> Collective Checking: BCAST (Rank 3) --> Inconsistent datatype
> signatures detected between rank 3 and rank 0.
> [cli_3]: aborting job:
> rank 3 in job 8  snow_47787   caused collective abort of all ranks
>   exit status of rank 3: return code 1
> Running installation runtest for Fortran collchk program...
> *** Test F77 program with the MPI collective/datatype checking library
> ... No.
> /usr/local/mpich2/bin/mpiexec -n 4 wrong_reals
>  Process  0 of  4 is alive
>  Process  2 of  4 is alive
>  Process  1 of  4 is alive
>  Process  3 of  4 is alive
> 	At [0]: wrong_reals(CollChk_err_han+0x128)[0x8057dc8]
> 	At [1]: wrong_reals(CollChk_dtype_scatter+0x117)[0x805a2c7]
> 	At [2]: wrong_reals(CollChk_dtype_bcast+0x3d)[0x805a36d]
> 	At [3]: wrong_reals(MPI_Bcast+0x7a)[0x805774a]
> 	At [4]: wrong_reals(mpi_bcast__+0x35)[0x8054ac5]
> 	At [5]: wrong_reals(MAIN__+0x139)[0x8054755]
> 	At [6]: wrong_reals(main+0x39)[0x80d0a95]
> 	At [7]:
> /lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe0)[0xb7df3450]
> 	At [8]: wrong_reals[0x80545c1]
> rank 3 in job 9  snow_47787   caused collective abort of all ranks
> make[2]: Leaving directory `/usr/local/mpich2-1.0.7/src/mpe2'
