[mpich-discuss] Re: BOUNCE mpich-discuss at mcs.anl.gov:    Non-member submission from ["Paul, Brent S " <bpaul at alionscience.com>]
    Rajeev Thakur
    thakur at mcs.anl.gov
    Thu Sep  4 08:10:03 CDT 2008
This usually happens when there is a problem with timestamps on the
machine/file system. I would suggest deleting the mpich2 directory and
starting with a fresh untar of the tar file.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Pavan Balaji
> Sent: Wednesday, September 03, 2008 7:50 AM
> To: mpich-discuss at mcs.anl.gov
> Cc: bpaul at alionscience.com
> Subject: [mpich-discuss] Re: BOUNCE
> On 09/02/2008 01:06 PM, owner-mpich-discuss at mcs.anl.gov wrote:
> > 	I am having trouble installing MPICH2 (v2-1.0.7) on my
> system suitable with a link to GFORTRAN.  I have downloaded
> the most recent version and expand to /var/tmp.  I am running
> cygwin under a Windows 32-bit machine.  I then run the command:
> > CC=gcc CXX=g++ FC=gfortran F90=gfortran ./configure
> > --prefix=/usr/local/mpich2 --enable-f90
> > After this is completed (and without any obvious errors) I
> then tried to "make" the installation.  Here is the error I
> got.  Can anyone help me with what is wrong?  Thanks in advance.
> > Brent
> > $ make
> > Beginning make
> > make all-local
> > make[1]: Entering directory `/var/tmp/mpich2-1.0.7'
> > make[2]: Entering directory `/var/tmp/mpich2-1.0.7'
> > make clean && cd test && make clean
> > make[3]: Entering directory `/var/tmp/mpich2-1.0.7'
> > make cleanlibs
> > make[4]: Entering directory `/var/tmp/mpich2-1.0.7'
> > rm -f lib/libmpich.a lib/libpmpich.a
> > rm -f lib/libmpichcxx.a
> > rm -f lib/libfmpich.a lib/libmpichf90.a rm -f
> lib/libmpich.dll* rm -f
> > lib/libpmpich.dll* rm -f lib/libmpichcxx.dll* rm -f
> lib/libfmpich.dll*
> > rm -f lib/libmpich.*.dll* rm -f lib/libpmpich.*.dll* rm -f
> > lib/libmpichcxx.*.dll* rm -f lib/libfmpich.*.dll* rm -f
> > lib/libmpich.la* lib/libpmpich.la* rm -f lib/libmpichcxx.la* rm -f
> > lib/libfmpich.la*
> > make[4]: Leaving directory `/var/tmp/mpich2-1.0.7'
> > for dir in src  examples - ; do \
> >                 if [ "$dir" = "-" ] ; then break ; fi ; \
> >                 (cd $dir && make clean ; ) ; done
> > make[4]: Entering directory `/var/tmp/mpich2-1.0.7/src'
> > ( cd . &&
> /sandbox/balaji/trunk/maint/mpich2-1.0.7/maint/simplemake \
> >         -rootdir=../ \
> >         -configdir=. \
> -common=/sandbox/balaji/trunk/maint/mpich2-1.0.7/maint/makedefs \
> >         -docnamedefs=\${master_top_srcdir}/maint/docnotes \
> >         "-autoconf=-I ROOTDIR/confdb" \
> >         -libdir=\${MPILIBNAME}=ROOTDIR/lib \
> >         -smvar_doc_attop=0 \
> >                 Makefile.sm )
> > /bin/sh: line 1:
> > /sandbox/balaji/trunk/maint/mpich2-1.0.7/maint/simplemake: No such
> > file or directory
> > make[4]: *** [Makefile.in] Error 127
> > make[4]: Leaving directory `/var/tmp/mpich2-1.0.7/src'
> > make[4]: Entering directory `/var/tmp/mpich2-1.0.7/examples'
> > make[4]: Leaving directory `/var/tmp/mpich2-1.0.7/examples'
> > make[3]: Leaving directory `/var/tmp/mpich2-1.0.7'
> > make[3]: Entering directory `/var/tmp/mpich2-1.0.7/test'
> > for dir in mpi mpid util basic commands ; do \
> > make[4]: Entering directory `/var/tmp/mpich2-1.0.7/test/mpi'
> > ( cd . &&
> >         -rootdir=../../ \
> >         -configdir=test/mpi/ \
> >         -distcleanfiles="maint/testmerge runtests Makefile
> > basic/Makefile attr/Makefile util/Makefile coll/Makefile
> comm/Makefile
> > datatype/Makefile errhan/Makefile group/Makefile info/Makefile
> > init/Makefile pt2pt/Makefile rma/Makefile spawn/Makefile
> topo/Makefile
> > io/Makefile f77/Makefile f77/attr/Makefile f77/attr/attraints.h
> > f77/pt2pt/attr1aints.h f77/ext/add1size.h f77/datatype/Makefile
> > f77/datatype/typeaints.h f77/util/Makefile f77/coll/Makefile
> > f77/comm/Makefile f77/topo/Makefile f77/init/Makefile
> > f77/rma/addsize.h f77/pt2pt/Makefile f77/info/Makefile
> > f77/spawn/Makefile f77/spawn/type1aint.h f77/rma/Makefile
> > f77/ext/Makefile f77/ext/testlist f77/io/Makefile f77/io/iooffset.h
> > f77/io/iodisp.h f77/io/ioaint.h f90/Makefile f90/attr/Makefile
> > f90/datatype/Makefile f90/f90types/Makefile f90/util/Makefile
> > f90/coll/Makefile f90/comm/Makefile f90/topo/Makefile
> > f90/init/Makefile f90/pt2pt/Makefile f90/rma/Makefile
> > f90/info/Makefile f90/spawn/Makefile f90/timer/Makefile f90/ext/Mak
> e!
> > file f90/ext/testlist f90/io/Makefile f90/misc/Makefile
> cxx/Makefile cxx/util/Makefile cxx/attr/Makefile
> cxx/pt2pt/Makefile cxx/comm/Makefile cxx/coll/Makefile
> cxx/info/Makefile cxx/datatype/Makefile cxx/io/Makefile
> cxx/init/Makefile cxx/rma/Makefile cxx/spawn/Makefile
> threads/Makefile threads/pt2pt/Makefile threads/util/Makefile
> threads/comm/Makefile errors/Makefile errors/coll/Makefile
> errors/comm/Makefile errors/group/Makefile
> errors/pt2pt/Makefile errors/rma/Makefile
> errors/spawn/Makefile errors/topo/Makefile errors/io/Makefile
> errors/cxx/Makefile errors/cxx/errhan/Makefile
> errors/cxx/io/Makefile errors/f77/Makefile
> errors/f90/Makefile manual/Makefile manual/manyconnect
> perf/Makefile testlist cxx/testlist f77/testlist f90/testlist
> errors/testlist errors/cxx/testlist config.status config.log
> config.cache *conf.cache config.system" \
> >                 Makefile.sm )
> > /bin/sh: line 1:
> > file or directory
> > make[4]: Leaving directory `/var/tmp/mpich2-1.0.7/test/mpi'
> > make[4]: Entering directory `/var/tmp/mpich2-1.0.7/test/mpid'
> > (cd ch3 && make clean )
> > make[5]: Entering directory `/var/tmp/mpich2-1.0.7/test/mpid/ch3'
> > make[5]: Leaving directory `/var/tmp/mpich2-1.0.7/test/mpid/ch3'
> > make[4]: Leaving directory `/var/tmp/mpich2-1.0.7/test/mpid'
> > make[4]: Entering directory `/var/tmp/mpich2-1.0.7/test/util'
> > ( cd . &&
> >         -rootdir=../../ \
> >         -configdir=. \
> >         -distcleanfiles="Makefile" \
> >                 Makefile.sm )
> > /bin/sh: line 1:
> > file or directory
> > make[4]: Leaving directory `/var/tmp/mpich2-1.0.7/test/util'
> > make[4]: Entering directory `/var/tmp/mpich2-1.0.7/test/basic'
> > make[4]: Leaving directory `/var/tmp/mpich2-1.0.7/test/basic'
> > make[4]: Entering directory `/var/tmp/mpich2-1.0.7/test/commands'
> > rm -f err.txt out.log out.txt stdintest stdintest2 sdtiotest a.out
> > make[4]: Leaving directory `/var/tmp/mpich2-1.0.7/test/commands'
> > make[3]: Leaving directory `/var/tmp/mpich2-1.0.7/test'
> > rm -f lib/newconfig
> > make[2]: Leaving directory `/var/tmp/mpich2-1.0.7'
> > make[1]: Leaving directory `/var/tmp/mpich2-1.0.7'
> > make[1]: Entering directory `/var/tmp/mpich2-1.0.7/src'
> > ( cd . &&
> >         -rootdir=../ \
> >         -configdir=. \
> >                 Makefile.sm )
> > /bin/sh: line 1:
> > file or directory
> > make[1]: *** [Makefile.in] Error 127
> > make[1]: Leaving directory `/var/tmp/mpich2-1.0.7/src'
> > make: *** [all-redirect] Error 2
> > Brent S. Paul
> > Hydrodynamics and Hydroacoustic Signatures     Alion
> Science and Technology
> > Office:  (860) 462-1038                        fax:  (860) 415-2190
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
