[mpich-discuss] mpiexec returns 0
Calin Iaru
calin at dolphinics.com
Wed Sep 3 11:14:43 CDT 2008
I forgot about hostname. Thanks; there are no problems.
----- Original Message -----
To: 'Calin Iaru'
Cc: mpich-discuss at mcs.anl.gov
Sent: Tuesday, September 02, 2008 5:41 PM
Subject: RE: [mpich-discuss] mpiexec returns 0
# The job launcher and process manager can also be used to launch non-MPI programs (mpiexec -n 2 hostname). So the job launcher and PM are not tied to MPI programs.
# You can always get/handle the error code of MPI functions within the MPI process (Using the error handler for ex). An app dev/user also needs the application exit code to be reported some way.
The current design provides more information to the user/dev than the design you suggest.
Do you have any problems in your env with the current design ?
-Jayesh
From: owner-mpich-discuss at mcs.anl.gov [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Calin Iaru
Sent: Tuesday, September 02, 2008 10:23 AM
Subject: Re: [mpich-discuss] mpiexec returns 0
I would expect that smpd and mpiexec would not be interested in what is happening beyond MPI_Finalize. Can you tell me why was this decision made - to propagate the application exit code?
Thanks for the info so far.
To: 'Calin Iaru'
Sent: Tuesday, September 02, 2008 4:52 PM
Hmmm... not really. mpiexec provided with MPICH2 on windows returns the last non-zero exit code (has nothing to do wether MPI_Finalize() was called or not) returned from an MPI process associated with the job.
mpiexec also returns an error code if there is any error within mpiexec.
So if there is an error (in mpiexec OR in any MPI process) in the MPI job you should be able to determine that by a non-zero return code from mpiexec.
-Jayesh
Sent: Tuesday, September 02, 2008 3:23 AM
Subject: [mpich-discuss] mpiexec returns 0
I would like to have a confirmation that mpiexec would return 0 if all processes called MPI_Finalize(). Based on return value, some test scripts can be stopped instead of having the output parsed.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080903/394a63e0/attachment.htm>
