[mpich-discuss] mpich2 and IPoIB
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Mon Oct 27 14:26:10 CDT 2008
  Yes, you can use the "-ifhn" option in the machinefile with smpd.
  Let us know if you have any problems.
Jayesh
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Rajeev Thakur
Sent: Monday, October 27, 2008 2:22 PM
Subject: RE: [mpich-discuss] mpich2 and IPoIB
Probably :-). From doing a grep in the smpd directory it looks like it
might accept "-ifhn hostname"
Rajeev
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Fabio Motezuki
> Sent: Monday, October 27, 2008 2:12 PM
> Subject: Re: [mpich-discuss] mpich2 and IPoIB
> Thanks Rajeev,
> I'll try it, perhaps is there any options like this for smpd?
> Fabio
> Rajeev Thakur escreveu:
> > Try specifying the interface name using ifhn= in the
> mpd.hosts file as
> > described in Sec 5.1.5 of the installation guide.
> http://www.mcs.anl.gov/research/projects/mpich2/documentation/
> files/mpich2-1
> > .0.8-installguide.pdf
> > Rajeev
> Fabio Motezuki
> >> Sent: Monday, October 27, 2008 5:35 AM
> >> Subject: [mpich-discuss] mpich2 and IPoIB
> >> Hi all,
> >> I'm working on a cluster where each node is connected with two
> >> networks:
> >> eth0 - gigabit ethernet
> >> ib0 - IP over infiniband
> >> I would like to use the ib0 net for all mpi communications, but
> >> when I start the example cpi all comunications go through eth0 is
> this the
> >> expected behavior?
> >> I'm launching the example program with "mpiexec
> -machinefile mf -n 16
> >> ./cpi" where the file "mf" contains the ip address of infiniband
> >> cards.
> >> Fabio
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081027/1d4871ff/attachment.htm>
