[mpich-discuss] mpich2 and stdin longer than 1024 lines
Bryan Putnam bfp at purdue.edu
Mon Oct 27 08:27:14 CDT 2008
Hi All,
We've noticed that when using mpich2-1.0.7, the mpi application will hang
when using a stdin that is longer than 1024 lines.  You can easily
reproduce this using the famous "pi" program set up to read from stdin.
For example using 2 processors on each of 2 nodes:
perl -e 'print "100\n" x 1023; print "0\n"' > inp
mpdboot -n 2 -f $PBS_NODEFILE
mpirun -np 4 ./pi < inp
works fine, while
perl -e 'print "100\n" x 1024; print "0\n"' > inp
mpdboot -n -f $PBS_NODEFILE
hangs.
Note that a workaround is to do
mpirun -np 4 "cat inp | pi"
Any help on what to modify in the mpich2 scripts to fix this would be
appreciated.
Thanks!
Bryan
Bryan Putnam
Rosen Center for Advanced Computing, Purdue University
Young Hall (Rm. 519)
302 Wood Street
West Lafayette, IN 47907-2108
Ph 765-496-8225 Fax 765-494-0566
bfp at purdue.edu
http://www.rcac.purdue.edu
