[mpich-discuss] Internal memory allocation error?
Brian Harker
brian.harker at gmail.com
Mon Oct 20 09:35:20 CDT 2008
Hi Gib-
Thanks for the idea, it's now running by dispatching full columns at a
time, so maybe I'll avoid the error, since the number of sends and
receives is drastically reduced. I'll keep you posted.
On Sun, Oct 19, 2008 at 7:17 PM, Gib Bogle <g.bogle at auckland.ac.nz> wrote:
> Hi Brian,
> You don't really send the data pixel-by-pixel do you? If so that would be
> horrendously inefficient. Why not send a row or column at a time? Have I
> misunderstood you?
> Cheers
> Gib
> Brian Harker wrote:
>> Hi Rajeev-
>> The code I have posted is pared down quite a bit. I print the
>> "numsent" variable after each send and receive to make sure the
>> correct pixel has been dispatched. I guess I should mention that if I
>> run the same program on some other data that I have, which has only
>> 68K pixels, it works flawlessly.
>> On Sun, Oct 19, 2008 at 5:57 PM, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
>>> Brian,
>>> This code should not even need an Irecv because the master and slave
>>> operate in lock step. And if you call Irecv followed by a Wait
>>> immediately,
>>> you could as well call Recv.
>>> Since it fails with even one slave, run the 1 master 1 slave version and
>>> add
>>> print statements after the sends and receives to see how many sends and
>>> receives are happening.
>>> Rajeev
>>>> -----Original Message-----
>>>> From: owner-mpich-discuss at mcs.anl.gov
>>>> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Brian Harker
>>>> Sent: Sunday, October 19, 2008 6:05 PM
>>>> To: mpich-discuss at mcs.anl.gov
>>>> Subject: Re: [mpich-discuss] Internal memory allocation error?
>>>> Hi list-
>>>> Here's my sample code for those that are wary of opening
>>>> email attachments :) Didn't think about that until just now.
>>>> PROGRAM mpi_main
>>>> USE subroutines ! contains subroutine "invert_pixel"
>>>> IMPLICIT NONE
>>>> INCLUDE "mpif.h"
>>>> ! total number of pixels
>>>> INTEGER, PARAMETER :: np = nx * ny !nx,ny specified in
>>>> module "subroutines"
>>>> ! parameter at each pixel
>>>> DOUBLE PRECISION :: par
>>>> ! full-size parameter array
>>>> DOUBLE PRECISION, DIMENSION(nx,ny) :: map
>>>> ! pixel coordinates
>>>> INTEGER, DIMENSION(2) :: pxl
>>>> ! dummy termination message
>>>> INTEGER, PARAMETER :: term = 0
>>>> ! MPI-related
>>>> INTEGER :: proc_id
>>>> INTEGER :: proc_num
>>>> INTEGER :: master
>>>> INTEGER :: ierr
>>>> INTEGER :: sender
>>>> INTEGER :: tag
>>>> INTEGER :: numsent
>>>> INTEGER :: request
>>>> INTEGER, DIMENSION(MPI_STATUS_SIZE) :: status
>>>> ! local indices
>>>> INTEGER :: i
>>>> !************************** BEGIN PROGRAM ***************************!
>>>> master = 0
>>>> ! initialize MPI libraries...
>>>> CALL MPI_Init( ierr )
>>>> CALL MPI_Comm_size( MPI_COMM_WORLD, proc_num, ierr ) CALL
>>>> MPI_Comm_rank( MPI_COMM_WORLD, proc_id, ierr )
>>>> ! master process code !
>>>> IF ( proc_id == master ) THEN
>>>> ! dispatch first group of pixels to slave processes...
>>>> numsent = 0
>>>> DO i = 1, proc_num - 1
>>>> pxl(1) = INT(numsent/ny) + 1
>>>> pxl(2) = MOD(numsent,ny) + 1
>>>> CALL MPI_Send( pxl, 2, MPI_INTEGER, i, numsent+1,
>>>> MPI_COMM_WORLD, ierr )
>>>> numsent = numsent + 1
>>>> END DO
>>>> mstr: DO
>>>> ! receive inferred parameter back from a slave...
>>>> CALL MPI_Recv( par, 1, MPI_DOUBLE_PRECISION,
>>>> MPI_ANY_SOURCE, MPI_ANY_TAG, MPI_COMM_WORLD, status, ierr )
>>>> sender = status(MPI_SOURCE)
>>>> tag = status(MPI_TAG)
>>>> ! assemble into full-size array...
>>>> x = INT(tag/ny) + 1
>>>> y = MOD(tag,ny) + 1
>>>> map(x,y) = par
>>>> IF ( tag == np ) THEN
>>>> ! all done, send termination message...
>>>> DO j = 1, proc_num - 1
>>>> CALL MPI_Send( term, 1, MPI_INTEGER, j, 0,
>>>> END DO
>>>> EXIT mstr
>>>> END IF
>>>> ! send the next available pixel to same slave...
>>>> pxl(1) = INT((numsent+1) / ny) + 1
>>>> pxl(2) = MOD((numsent+1), ny) + 1
>>>> CALL MPI_Send( pxl, 2, MPI_INTEGER, sender,
>>>> numsent+1, MPI_COMM_WORLD, ierr )
>>>> END DO mstr
>>>> ! slave process code !
>>>> ELSE
>>>> slv: DO
>>>> ! receive pixel coordinates from master...
>>>> CALL MPI_Irecv( pxl, 2, MPI_INTEGER, master,
>>>> MPI_ANY_TAG, MPI_COMM_WORLD, request, ierr )
>>>> CALL MPI_Wait( request, status, ierr )
>>>> IF ( tag == 0 ) THEN
>>>> ! all done, exit program...
>>>> EXIT slv
>>>> END IF
>>>> ! call genetic algorithm for inversion...
>>>> CALL invert_pixel( pxl, par )
>>>> ! send parameter result back to master...
>>>> CALL MPI_Send( par, 1, MPI_DOUBLE_PRECISION, master,
>>>> tag, MPI_COMM_WORLD, ierr )
>>>> END DO slv
>>>> END IF
>>>> ! shut down MPI...
>>>> CALL MPI_Finalize( ierr )
>>>> WRITE(*,*) ""
>>>> IF ( ierr == 0 ) WRITE(*,*) "Goodbye from process",proc_id
>>>> !**************************** END PROGRAM ***************************!
>>>> STOP
>>>> END PROGRAM mpi_main
>>>> Cheers,
>>>> Brian
>>>> "In science, there is only physics; all the rest is stamp-collecting."
>>>> -Ernest Rutherford
Cheers,
Brian
-Ernest Rutherford
