[mpich-discuss] Internal memory allocation error?
    Rajeev Thakur
    thakur at mcs.anl.gov
    Sun Oct 19 18:57:41 CDT 2008
Brian,
      This code should not even need an Irecv because the master and slave
operate in lock step. And if you call Irecv followed by a Wait immediately,
you could as well call Recv.
Since it fails with even one slave, run the 1 master 1 slave version and add
print statements after the sends and receives to see how many sends and
receives are happening.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Brian Harker
> Sent: Sunday, October 19, 2008 6:05 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] Internal memory allocation error?
> Hi list-
> Here's my sample code for those that are wary of opening
> email attachments  :)  Didn't think about that until just now.
> PROGRAM mpi_main
> USE subroutines  ! contains subroutine "invert_pixel"
> IMPLICIT NONE
> INCLUDE "mpif.h"
> ! total number of pixels
> INTEGER, PARAMETER :: np = nx * ny   !nx,ny specified in
> module "subroutines"
> ! parameter at each pixel
> DOUBLE PRECISION :: par
> ! full-size parameter array
> DOUBLE PRECISION, DIMENSION(nx,ny) :: map
> ! pixel coordinates
> INTEGER, DIMENSION(2) :: pxl
> ! dummy termination message
> INTEGER, PARAMETER :: term = 0
> ! MPI-related
> INTEGER :: proc_id
> INTEGER :: proc_num
> INTEGER :: master
> INTEGER :: ierr
> INTEGER :: sender
> INTEGER :: tag
> INTEGER :: numsent
> INTEGER :: request
> INTEGER, DIMENSION(MPI_STATUS_SIZE) :: status
> ! local indices
> INTEGER :: i
> !************************** BEGIN PROGRAM ***************************!
> master = 0
> ! initialize MPI libraries...
> CALL MPI_Init( ierr )
> CALL MPI_Comm_size( MPI_COMM_WORLD, proc_num, ierr ) CALL
> MPI_Comm_rank( MPI_COMM_WORLD, proc_id, ierr )
> !             master process code               !
> IF ( proc_id == master ) THEN
>  ! dispatch first group of pixels to slave processes...
>  numsent = 0
>  DO i = 1, proc_num - 1
>   pxl(1) = INT(numsent/ny) + 1
>   pxl(2) = MOD(numsent,ny) + 1
>   CALL MPI_Send( pxl, 2, MPI_INTEGER, i, numsent+1,
> MPI_COMM_WORLD, ierr )
>   numsent = numsent + 1
>  END DO
>  mstr: DO
>         ! receive inferred parameter back from a slave...
>         CALL MPI_Recv( par, 1, MPI_DOUBLE_PRECISION,
> MPI_ANY_SOURCE, MPI_ANY_TAG, MPI_COMM_WORLD, status, ierr )
>         sender = status(MPI_SOURCE)
>         tag = status(MPI_TAG)
>         ! assemble into full-size array...
>         x = INT(tag/ny) + 1
>         y = MOD(tag,ny) + 1
>         map(x,y) = par
>         IF ( tag == np ) THEN
>          ! all done, send termination message...
>          DO j = 1, proc_num - 1
>           CALL MPI_Send( term, 1, MPI_INTEGER, j, 0,
>          END DO
>          EXIT mstr
>         END IF
>         ! send the next available pixel to same slave...
>         pxl(1) = INT((numsent+1) / ny) + 1
>         pxl(2) = MOD((numsent+1), ny) + 1
>         CALL MPI_Send( pxl, 2, MPI_INTEGER, sender,
> numsent+1, MPI_COMM_WORLD, ierr )
>        END DO mstr
> !              slave process code               !
> ELSE
>  slv: DO
>        ! receive pixel coordinates from master...
>        CALL MPI_Irecv( pxl, 2, MPI_INTEGER, master,
> MPI_ANY_TAG, MPI_COMM_WORLD, request, ierr )
>        CALL MPI_Wait( request, status, ierr )
>        IF ( tag == 0 ) THEN
>         ! all done, exit program...
>         EXIT slv
>        END IF
>        ! call genetic algorithm for inversion...
>        CALL invert_pixel( pxl, par )
>        ! send parameter result back to master...
>        CALL MPI_Send( par, 1, MPI_DOUBLE_PRECISION, master,
> tag, MPI_COMM_WORLD, ierr )
>       END DO slv
> END IF
> ! shut down MPI...
> CALL MPI_Finalize( ierr )
> WRITE(*,*) ""
> IF ( ierr == 0 ) WRITE(*,*) "Goodbye from process",proc_id
> !**************************** END PROGRAM ***************************!
> STOP
> END PROGRAM mpi_main
> Cheers,
> Brian
> brian.harker at gmail.com
> "In science, there is only physics; all the rest is stamp-collecting."
> -Ernest Rutherford
