[mpich-discuss] Internal memory allocation error?
Brian Harker
brian.harker at gmail.com
Sun Oct 19 17:41:24 CDT 2008
Hi Rajeev and list-
Here's a code sample. I'm assuming you could replace my subroutine
"invert_pixel" with a dummy subroutine, and integer parameters, nx and
ny (415 and 509 in my code) with something else. BTW, I am using
MPICH2 1.0.7 with the Intel icc,icpc,ifort compiler suite. Thanks a
lot!
On Sun, Oct 19, 2008 at 3:59 PM, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
> Can you send us a code fragment that shows exactly what you are doing and
> how many sends/recvs are being issued? You don't need to change sends to
> isends, just the recvs.
> Rajeev
>> -----Original Message-----
>> From: owner-mpich-discuss at mcs.anl.gov
>> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Brian Harker
>> Sent: Sunday, October 19, 2008 4:39 PM
>> To: mpich-discuss at mcs.anl.gov
>> Subject: Re: [mpich-discuss] Internal memory allocation error?
>> Hello Rajeev and list-
>> Well, I've replaced MPI_Send with MPI_ISend and MPI_Recv with
>> MPI_Irecv, with the corresponding MPI_Wait calls as late as I
>> possibly can while doing the intermediate calculations, and I
>> still get the error. The error even comes up when I use only
>> one slave process to do the calculations (in essence the
>> serial version of the algorithm).
>> Is there a limit on the tag value that accompanies the MPI_Send?
>> On Sat, Oct 18, 2008 at 3:39 PM, Rajeev Thakur
>> > Yes, you do need MPI_Wait or MPI_Waitall but you can call
>> the Irecv as
>> > early as possible and delay the Wait until just before you
>> need the data.
>> > Rajeev
>> >> Sent: Saturday, October 18, 2008 11:38 AM
>> >> Thanks Rajeev...since MPI_Irecv is nonblocking, should I
>> pair it up
>> >> with an MPI_Wait to make sure I'm not trying to access a
>> buffer that
>> >> hasn't been written to yet?
>> >> On Sat, Oct 18, 2008 at 9:38 AM, Rajeev Thakur
>> >> wrote:
>> >> > This can happen if the sender does too many sends and
>> the receiver
>> >> > doesn't post receives fast enough. Try using MPI_Irecv
>> and posting
>> >> > enough of them to match the incoming sends.
>> >> > Rajeev
>> Brian Harker
>> >> >> Sent: Friday, October 17, 2008 4:19 PM
>> >> >> Subject: [mpich-discuss] Internal memory allocation error?
>> >> >> Hello list-
>> >> >> I have a fortran 90 program that loops over pixels in
>> an image in
>> >> >> parallel. There are 211K total pixels in the
>> >> field-of-view, and the
>> >> >> code always crashes around the 160K^th pixel, give or take
>> >> a hundred
>> >> >> or so, with the following message:
>> >> >> Fatal error in MPI_Recv: Other MPI error, error stack:
>> >> >> MPI_Recv(186).............................:
>> >> >> MPI_Recv(buf=0x82210d0, count=2, MPI_INTEGER, src=0,
>> >> tag=MPI_ANY_TAG,
>> >> >> MPI_COMM_WORLD,
>> >> >> status=0x82210e0) failed
>> >> >> MPIDI_CH3i_Progress_wait(214).............: an error
>> >> occurred while
>> >> >> handling an event returned by MPIDU_Sock_Wait()
>> >> >> MPIDI_CH3I_Progress_handle_sock_event(436):
>> >> >> MPIDI_EagerContigIsend(567)...............: failure
>> occurred while
>> >> >> allocating memory for a request object[cli_2]: aborting job:
>> >> >> Now, I have no dynamically allocatable variables in the
>> >> code, so the
>> >> >> error means there is not enough memory in the buffer
>> for all the
>> >> >> communication at this step? I have increased
>> >> MP_BUFFER_MEM from the
>> >> >> default 64M to 128M with no change in the error. Is it
>> >> possible that
>> >> >> I'm just trying to do too much at once with my dual-core
>> >> processor?
>> >> >> I wouldn't think so, I'm only running the code with 6
>> >> processes...and
>> >> >> I don't believe this is a data problem.
>> >> >> Any ideas would be appreciated, and I can post any other
>> >> information
>> >> >> anyone wants. Thanks!
>> >> >> Cheers,
>> >> >> Brian
>> >> >> "In science, there is only physics; all the rest is
>> >> stamp-collecting."
>> >> >> -Ernest Rutherford
>> >> Cheers,
>> >> Brian
>> stamp-collecting."
>> >> -Ernest Rutherford
>> Cheers,
>> Brian
>> "In science, there is only physics; all the rest is stamp-collecting."
>> -Ernest Rutherford
Cheers,
Brian
-Ernest Rutherford
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081019/0e33e71a/attachment.obj>
