[mpich-discuss] Internal memory allocation error?
    Rajeev Thakur
    thakur at mcs.anl.gov
    Sat Oct 18 16:39:12 CDT 2008
Yes, you do need MPI_Wait or MPI_Waitall but you can call the Irecv as early
as possible and delay the Wait until just before you need the data.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Brian Harker
> Sent: Saturday, October 18, 2008 11:38 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] Internal memory allocation error?
> Thanks Rajeev...since MPI_Irecv is nonblocking, should I pair
> it up with an MPI_Wait to make sure I'm not trying to access
> a buffer that hasn't been written to yet?
> On Sat, Oct 18, 2008 at 9:38 AM, Rajeev Thakur
> <thakur at mcs.anl.gov> wrote:
> > This can happen if the sender does too many sends and the receiver
> > doesn't post receives fast enough. Try using MPI_Irecv and posting
> > enough of them to match the incoming sends.
> > Rajeev
> >> Sent: Friday, October 17, 2008 4:19 PM
> >> Subject: [mpich-discuss] Internal memory allocation error?
> >> Hello list-
> >> I have a fortran 90 program that loops over pixels in an image in
> >> parallel.  There are 211K total pixels in the
> field-of-view, and the
> >> code always crashes around the 160K^th pixel, give or take
> a hundred
> >> or so, with the following message:
> >> Fatal error in MPI_Recv: Other MPI error, error stack:
> >> MPI_Recv(186).............................:
> >> MPI_Recv(buf=0x82210d0, count=2, MPI_INTEGER, src=0,
> tag=MPI_ANY_TAG,
> >> MPI_COMM_WORLD,
> >> status=0x82210e0) failed
> >> MPIDI_CH3i_Progress_wait(214).............: an error
> occurred while
> >> handling an event returned by MPIDU_Sock_Wait()
> >> MPIDI_CH3I_Progress_handle_sock_event(436):
> >> MPIDI_EagerContigIsend(567)...............: failure occurred while
> >> allocating memory for a request object[cli_2]: aborting job:
> >> Now, I have no dynamically allocatable variables in the
> code, so the
> >> error means there is not enough memory in the buffer for all the
> >> communication at this step?  I have increased
> MP_BUFFER_MEM from the
> >> default 64M to 128M with no change in the error.  Is it
> possible that
> >> I'm just trying to do too much at once with my dual-core
> processor?
> >> I wouldn't think so, I'm only running the code with 6
> processes...and
> >> I don't believe this is a data problem.
> >> Any ideas would be appreciated, and I can post any other
> information
> >> anyone wants.  Thanks!
> >> Cheers,
> >> Brian
> >> brian.harker at gmail.com
> >> "In science, there is only physics; all the rest is
> stamp-collecting."
> >> -Ernest Rutherford
> Cheers,
> Brian
> "In science, there is only physics; all the rest is stamp-collecting."
> -Ernest Rutherford
