[mpich-discuss] SMPD, Problem launching when using -host
James S Perrin james.s.perrin at manchester.ac.uk
Fri Oct 17 12:18:54 CDT 2008
	The -path option is of no use as I think mpiexec only uses this path to
find the executable. I don't think that it is then set in the
environment that the executable is launched in, hence the executable
still can't find DLLs.
	Using -genvlist PATH or similar seems to work however.
Regards
James
Jayesh Krishna wrote:
>  Hi,
>   It is recommended that you use the "-path" option available with
> mpiexec to specify the path to the executable.
> Regards,
> Jayesh
> -----Original Message-----
> From: James S Perrin [mailto:james.s.perrin at manchester.ac.uk]
> Sent: Friday, October 10, 2008 4:57 AM
> To: Jayesh Krishna
> Cc: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] SMPD, Problem launching when using -host
> Hi,
> I have found the reason why my executable is failing to start, however I
>   think -host is not behaving as it should or at least the documentation
> needs clarifying.
> I guessed that using -host was somehow changing the executable's
> environment and so it is failing to start correctly because it couldn't
> find a dll.
> On windows the PATH variable should be made up of the system wide
> settings and the user specific additions:
> ie echo %PATH% => <system settings>;<user settings>
> The user settings are required to launch the process. When I launch as
> follows:
> mpiexec -localroot -n 1 master : -n 1 slave
> both get the path setting as above, however if I use
> mpiexec -localroot -n 1 master : -host roobarb -n 1 slave
> process 1 has PATH=<system settings>;<user settings> but process 2 has
> PATH=<system settings> only
> I have no idea why the following works but it does, if I add -host
> roobarb to the process 1 process 2 now gets the full PATH variable
> mpiexec -localroot -host roobarb -n 1 master : -host roobarb -n 1 slave
> Final permutation, if I now don't specify -localroot both processes only
> get the only the system settings for PATH:
> mpiexec -host roobarb -n 1 master : -host roobarb -n 1 slave
> In summary using -host only the system path settings are used and not
> the user specific settings. Is this a security feature or a
> non-iteractive login issue c.f bash under linux the .bashrc is not
> executed for processes started remotely?
> A little extra testing confirmed that when process gets both the system
> and user path settings it is getting this from the current cmd shell.
> The solution is to either make sure paths are added to the system path
> variable or launch via a script that sets up the environment for each
> processes though I would have like to avoid this if possible. The first
> is a pain for development and the later a pain for user installations.
> FYI I was examining the PATH variable using:
> mpiexec -l -host roobarb -n 1 env : -host roobarb -n 1 env | grep \]PATH=
> I have the UNIX commands env and grep in my PATH.
> Regards
> James
>  >  Hi,
>  >   Can you send us the debug output of mpiexec and smpd ? Please follow
>  > the instructions below to send us the debug output,
>  > # Stop any instances of smpd using the command, smpd -stop # Start
>  > smpd in the debug mode using the command, smpd -d # Run a non-MPI
>  > program with mpiexec in the verbose mode using the command, mpiexec
>  > -verbose -n 1 hostname : -host IPADDRESS_OF_roobarb -n
>  > 1 hostname
>  > # Run an MPI program (cpi.exe provided with MPICH2) with mpiexec in
>  > the verbose mode using the command, mpiexec -verbose -n 1 cpi.exe :
>  > -host IPADDRESS_OF_roobarb -n 1 cpi.exe
>  > # Send us the debug/verbose outputs of mpiexec and smpd.
>  >   Let us know the results.
>  > Regards,
>  > Jayesh
>  > From: owner-mpich-discuss at mcs.anl.gov
>  > [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of James S Perrin
>  > Sent: Tuesday, October 07, 2008 5:25 AM
>  > Hi,
>  >      No I get the same error if I use the ipaddress.
>  > Regards
>  > James
>  >  >  Hi,
>  >  >   Does it work if you specify the ipaddress of the machine instead of
>  >  > hostname (mpiexec -n 1 master : -host IPADDRESS_OF_roobarb -n 1
> slave) ?
>  >  > Regards,
>  >  > Jayesh
>  >  > Sent: Monday, October 06, 2008 5:18 AM  > To: Jayesh Krishna  > Cc:
>  > mpich-discuss at mcs.anl.gov  > Subject: Re: [mpich-discuss] SMPD,
>  > Problem launching when using -host  >  > Hi,  >  > Jayesh Krishna
>  > wrote:
>  >  >  >  Hi,
>  >  >  >  >> mpiexec -n 1 -host roobarb master : -n 1 slave
>  >  >  >         The command above("-host" option specified for only one
>  >  >  > executable) works for me. What is the error message that you get
>  > >  > (Provide us with the snapshot of your command and the error
>  > output. It  > > would also help us if you provide more details - Is
>  > roobarb a remote  > > machine ? etc) ?
>  >  > The error is:
>  >  > [0] PMI_Init failed: FAIL - init called when another process has  >
>  > exited without calling init Fatal error in MPI_Init_thread: Other MPI
>  > > error, error stack:
>  >  > MPIR_Init_thread(294): Initialization failed  >
>  > MPID_Init(82)........: channel initialization failed  >
>  > MPID_Init(333).......: PMI_Init returned -1unable to read the cmd  >
>  > header on the pmi context, generic socket failure, error stack:
>  >  > MPIDU_Sock_wait(2603): The specified network name is no longer  >
>  > available. (errno 64).
>  >  > job aborted:
>  >  > rank: node: exit code[: error message]  > 0: ROOBARB: 3: Fatal
>  > error in MPI_Init_thread: Other MPI error, error
>  > stack:
>  > MPID_Init(333).......: PMI_Init returned -1  > 1: roobarb: -1073741515
>  > >  > The second process is not starting for some reason.
>  >  > roobarb happens to be the local machine in this case but the
>  > problem  > also occurs on a cluster.
>  >  > It will launch correctly if I use:
>  >  > mpiexec -n 1 master : -n 1 slave - SUCCESS  >  > which should be no
>  > different from:
>  >  > mpiexec -n 1 master : -host roobarb -n 1 slave - FAILS  >  > when
>  > everything is running on roobarb.
>  >  >  >  >> mpiexec -localroot -n 1 roobarb master : -host roobarb -n 1
>  > > slave  >
>  >  >  >         When using the "-localroot" option you should not
> specify the
>  >  >  > hostname for the 1st executable. The command should be,  >  >
>  > >>  > mpiexec -localroot -n 1 master : -host roobarb -n 1 slave  >  >
>  > sorry typo I meant if would work I used:
>  > > slave  >  > Regards  > James  >  >  >  >  > -----Original
>  > Message-----  >  > From: owner-mpich-discuss at mcs.anl.gov  >  >
>  > > > Sent: Friday, October 03, 2008 12:13 PM  > To: mpich  > Subject:
>  >  > [mpich-discuss] SMPD, Problem launching when using -host  >  > Hi,
>  >  >  >      Processes fail to start if -host is used for only some but not
>  >  >  > all processes when launching. ie the machines that some
>  > processes  > > launch on is left up to the smpd to allocate.
>  >  >  > eg
>  >  >  > mpiexec -n 1 -host roobarb master : -n 1 slave  >  > when  >
>  > -localroot is used the following fails unless -host is also  >  >
>  > specified for the master.
>  >  >  > mpiexc -localroot -n 1 roobarb master : -host roobarb -n 1 slave
>  > >  > > Using MPICH2 1.0.7 on WinXP ia32.
>  >  >  > Regards
>  >  >  > James
>  >  >  >    James S. Perrin
>  >  >  >    Visualization
>  >  >  >    Research Computing Services
>  >  >  >    The University of Manchester
>  >  >  >    Kilburn Building, Oxford Road
>  >  >  >    Manchester, M13 9PL
>  >  >  >    t: +44 (0) 161 275 6945
>  >  >  >    e: james.perrin at manchester.ac.uk
>  >  >  >    w: www.manchester.ac.uk/researchcomputing
>  >  >  >   "The test of intellect is the refusal to belabour the obvious"
>  >  >  >   - Alfred Bester
>  >  >    James S. Perrin
>  >  >    Visualization
>  >  >    Manchester, M13 9PL
>  >  >   - Alfred Bester
>  >    James S. Perrin
>  >    Visualization
>  >    Manchester, M13 9PL
>  >   - Alfred Bester
>    James S. Perrin
>    Visualization
>    Manchester, M13 9PL
>   - Alfred Bester
   James S. Perrin
   Visualization
   Rm 074B, Devonshire House, University Precinct
   Oxford Road, Manchester, M13 9PL
  - Alfred Bester
