[mpich-discuss] Strange behavior of mpd
    Bellanca Gaetano
    gaetano.bellanca at unife.it
    Thu Oct  9 17:00:45 CDT 2008
Hi Gus and list,
I came back to my problem with mpd and tested my code on a small PC
cluster of 10PEs.
In this case, the first one with a 'true' cluster (in other cases I
tested the code on a dual core and a two processors quad/core
machine), I was unable to run the simulation with a 'big' data
set  also after a mpd reboot.
Therefore, following the suggestion of Gus, I modified the code
reducing the message size sending data by 2D slices. This solves my
problem. Now I'm able to run the simulation with a small number of
PEs also with a big data set.
Thanks for your help in solving the problem.
Gaetano
Gaetano Bellanca - Department of Engineering - University of Ferrara
Via Saragat, 1 - 44100 - Ferrara - ITALY
Voice (VoIP):  +39 0532 974809     Fax:  +39 0532 974870
mailto:gaetano.bellanca at unife.it
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081010/58572c88/attachment.htm>
