[mpich-discuss] MPICH2 & Large data
Robert Kubrick robertkubrick at gmail.com
Thu Oct 2 08:16:11 CDT 2008
Do you want to receive a message for which you don't know the number
of elements in the array? You can use MPI_Probe() to get the number
of elements of the incoming message and allocate a buffer large enough.
Or you could setup a two steps send/recv, where in the first step you
send the number of elements you need to deliver.
On Oct 2, 2008, at 8:36 AM, Hisham Adel wrote:
> Hi,
> I am trying to send large data (2.5GB) using MPICH2. When the other
> node is going to receive the data it can not cause in MPI_RECV
> (void * buffer, Int count, .......) the count number will be very
> large than the integer range.
> how can I make it receive large data ?
> Is there any solution for this problem ?
> Thanks alot
> Regards,
> Hisham Adel
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081002/e0af57e1/attachment.htm>
