[mpich-discuss] MPICH2 & Large data
The Source
thesourcehim at gmail.com
Thu Oct 2 08:08:06 CDT 2008
Send, using different MPI data types. For example MPI_INT instead of
MPI_CHAR, so element number will be 4 time smaller. The other way is to
split data to several messages.
Hisham Adel ?????:
> Hi,
> I am trying to send large data (2.5GB) using MPICH2. When the other
> node is going to receive the data it can not cause in MPI_RECV (void *
> buffer, Int count, .......) the count number will be very large than
> the integer range.
> how can I make it receive large data ?
> Is there any solution for this problem ?
> Thanks alot
> Regards,
> Hisham Adel
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081002/06c7c489/attachment.htm>
