[mpich-discuss] Executables from mpif90 can only be run with mpiexec
    Marcel Mohr
    marcel at physik.tu-berlin.de
    Wed Oct  1 01:48:38 CDT 2008
Thanks Jayesh & Rajeev
I will give the cvs trunk a chance.
Marcel
On Tue, 30 Sep 2008, Rajeev Thakur wrote:
> And if you use the default MPD process manager, it should work even in 1.0.7.
> Rajeev
> _________________________________________________________________________________________________________________________________________________________
> From: owner-mpich-discuss at mcs.anl.gov [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Jayesh Krishna
> Sent: Tuesday, September 30, 2008 2:47 PM
> To: 'Marcel Mohr'
> Cc: mpich-discuss at mcs.anl.gov
> Subject: RE: [mpich-discuss] Executables from mpif90 can only be run with mpiexec
>  Hi,
>   This issue has been fixed in the 1.1.0a1 release (developer pre-release). The fix will also be included in the upcoming 1.0.8 stable
> release.
>   Please try MPICH2 1.1.0a1 (available at http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads) or the latest
> source from trunk and get back to us if you still have problems.
> Regards,
> Jayesh
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Marcel Mohr
> Sent: Tuesday, September 30, 2008 8:11 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] Executables from mpif90 can only be run with mpiexec
> Dear list
> within the last mpich2 version I used (1.04) I could run executables directly (serial) or with mpiexec (parallel). This is not possible
> anymore with version 1.07 , running directly gives these errors
> MPIDU_Socki_handle_connect(791): connection failure (set=1,sock=16777216,errno=111:Connection refused) unable to connect mpiexec tree,
> socket connection failed, error stack:
> MPIDU_Socki_handle_connect(791): connection failure (set=1,sock=16777216,errno=111:Connection refused).
> I was using for mpich2 compilation:
> ./configure --prefix=/usr/local/mpich2-intel' '--with-pm=smpd' 'CC=icc'
> 'CXX=icc'
> 'F90=ifort' '--enable-ROMIO' '--with-file-system=nfs' '--with-pmi=smpd'
> '--with-device=ch3:ssm
> Any hints/clues what is the reason for this behavior?
> Cheers
> Marcel
