[mpich-discuss] mpich2 and IPoIB
Fabio Motezuki
kenji_japanese at ig.com.br
Fri Oct 31 13:11:43 CDT 2008
We got something here, now the communications goes through infiniband. The machinefile for smpd is a bit different from the mpd.
Also tested the machinefile with 1.0.7 and works too.
Fabio
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Friday, October 31, 2008 2:03 PM
To: 'Fabio Kenji'
Cc: mpich-discuss at mcs.anl.gov
Subject: RE: [mpich-discuss] mpich2 and IPoIB
Can you try specifying hostnames and interface ipaddresses in your machinefile (also see the difference in the way interface ipaddr is specified) ?
Hostname_of_10_2_5_10 -ifhn 10.2.10.10
Hostname_of_10_2_5_11 -ifhn 10.2.10.11
Jayesh
-----Original Message-----
From: Fabio Kenji [mailto:kenji_japanese at ig.com.br]
Sent: Friday, October 31, 2008 6:39 AM
To: Jayesh Krishna
Subject: Re: [mpich-discuss] mpich2 and IPoIB
Compiled the 1.0.8 with the following options:
./configure --enable-cxx --with-pm=smpd --prefix=<path> make && make install
to started the smpd using
<path>smpd -s
to launch the program I'm using
<path>mpiexec -n 4 -machinefile mf <program>
the mf file contains:
10.2.5.10 ifhn=10.2.10.10
10.2.5.11 ifhn=10.2.10.11
where 10.2.5.xx is ethernet and 10.2.10.xx is infiniband
and the communications are going through ethernet
Fabio
2008/10/30, Jayesh Krishna <jayesh at mcs.anl.gov>:
> Hi,
> Can you try the latest stable release (1.0.8) of MPICH2 ?
> I just tried entering a non-existant ipaddress in the machinefile using the "-ifhn" option and my program failed (expected failure). A quick look of the smpd debug output shows that smpd is setting the right (as per the "-ifhn" args) environment before launching the process.
> Please let us know if MPICH2 1.0.8 + smpd + "-ifhn" option does not work for you.
> Regards,
> Jayesh
> From: Fabio Motezuki [mailto:kenji_japanese at ig.com.br]
> Sent: Wednesday, October 29, 2008 8:36 PM
> To: Jayesh Krishna
> Returning, I compiled de 1.0.8rc1 source and using mpd the ifhn in the mpd.hosts file worked well, but not with interface name resolution, just using ip directly.
> In 1.0.7 I tried to use ifhn in the machinefile for smpd execution, but no effect even when using the ip address of the infiniband interface.
> Fabio
> Jayesh Krishna escreveu:
> > Hi,
> > Yes, you can use the "-ifhn" option in the machinefile with smpd.
> > Let us know if you have any problems.
> > Regards,
> > Jayesh
> > From: owner-mpich-discuss at mcs.anl.gov >
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Rajeev Thakur >
> Sent: Monday, October 27, 2008 2:22 PM > To:
> mpich-discuss at mcs.anl.gov > Subject: RE: [mpich-discuss] mpich2 and
> IPoIB > > Probably :-). From doing a grep in the smpd directory it
> looks like it > might accept "-ifhn hostname"
> > Rajeev
> > > From: owner-mpich-discuss at mcs.anl.gov > >
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Fabio Motezuki
> > > Sent: Monday, October 27, 2008 2:12 PM > > To:
> mpich-discuss at mcs.anl.gov > > Subject: Re: [mpich-discuss] mpich2 and
> IPoIB > > > > Thanks Rajeev, > > > > I'll try it, perhaps is there
> any options like this for smpd?
> > > Fabio
> > > Rajeev Thakur escreveu:
> > > > Try specifying the interface name using ifhn= in the > >
> mpd.hosts file as > > > described in Sec 5.1.5 of the installation
> guide.
> > > http://www.mcs.anl.gov/research/projects/mpich2/documentation/
> > > files/mpich2-1
> > > > .0.8-installguide.pdf
> > > > Rajeev
> > > >> From: owner-mpich-discuss at mcs.anl.gov > > >>
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of > > Fabio
> Motezuki > > >> Sent: Monday, October 27, 2008 5:35 AM > > >> To:
> mpich-discuss at mcs.anl.gov > > >> Subject: [mpich-discuss] mpich2 and
> IPoIB > > >> > > >> Hi all, > > >> > > >> I'm working on a cluster
> where each node is connected with two > > >> networks:
> > > >> eth0 - gigabit ethernet
> > > >> ib0 - IP over infiniband
> > > >> I would like to use the ib0 net for all mpi communications,
> but > > >> when I start the example cpi all comunications go through
> eth0 is > > this the > > >> expected behavior?
> > > >> I'm launching the example program with "mpiexec > >
> -machinefile mf -n 16 > > >> ./cpi" where the file "mf" contains the
> ip address of infiniband > > >> cards.
> > > >> Fabio
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081031/86059c89/attachment.htm>
