[mpich-discuss] mpich2 and IPoIB
    Fabio Kenji
    kenji_japanese at ig.com.br
    Fri Oct 31 06:38:54 CDT 2008
Compiled the 1.0.8 with the following options:
./configure --enable-cxx --with-pm=smpd --prefix=<path>
make && make install
to started the smpd using
<path>smpd -s
to launch the program I'm using
<path>mpiexec -n 4 -machinefile mf <program>
the mf file contains:
10.2.5.10 ifhn=10.2.10.10
10.2.5.11 ifhn=10.2.10.11
where 10.2.5.xx is ethernet and 10.2.10.xx is infiniband
and the communications are going through ethernet
Fabio
2008/10/30, Jayesh Krishna <jayesh at mcs.anl.gov>:
>  Hi,
>    Can you try the latest stable release (1.0.8) of MPICH2 ?
>    I just tried entering a non-existant ipaddress in the machinefile using the "-ifhn" option and my program failed (expected failure). A quick look of the smpd debug output shows that smpd is setting the right (as per the "-ifhn" args) environment before launching the process.
>    Please let us know if MPICH2 1.0.8 + smpd + "-ifhn" option does not work for you.
>  Regards,
>  Jayesh
>  -----Original Message-----
>  From: Fabio Motezuki [mailto:kenji_japanese at ig.com.br]
>  Sent: Wednesday, October 29, 2008 8:36 PM
>  To: Jayesh Krishna
>  Cc: mpich-discuss at mcs.anl.gov
>  Subject: Re: [mpich-discuss] mpich2 and IPoIB
>  Returning, I compiled de 1.0.8rc1 source and using mpd the ifhn in the mpd.hosts file worked well, but not with interface name resolution, just using ip directly.
>  In 1.0.7 I tried to use ifhn in the machinefile for smpd execution, but no effect even when using the ip address of the infiniband interface.
>  Fabio
>  Jayesh Krishna escreveu:
>  >  Hi,
>  >   Yes, you can use the "-ifhn" option in the machinefile with smpd.
>  >   Let us know if you have any problems.
>  > Regards,
>  > Jayesh
>  > From: owner-mpich-discuss at mcs.anl.gov
>  > [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Rajeev Thakur
>  > Sent: Monday, October 27, 2008 2:22 PM
>  > To: mpich-discuss at mcs.anl.gov
>  > Subject: RE: [mpich-discuss] mpich2 and IPoIB
>  > Probably :-). From doing a grep in the smpd directory it looks like it
>  > might accept "-ifhn hostname"
>  > Rajeev
>  > > [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Fabio Motezuki
>  > > Sent: Monday, October 27, 2008 2:12 PM
>  > > Thanks Rajeev,
>  > > I'll try it, perhaps is there any options like this for smpd?
>  > > Fabio
>  > > Rajeev Thakur escreveu:
>  > > > Try specifying the interface name using ifhn= in the
>  > > mpd.hosts file as
>  > > > described in Sec 5.1.5 of the installation guide.
>  > > http://www.mcs.anl.gov/research/projects/mpich2/documentation/
>  > > files/mpich2-1
>  > > > .0.8-installguide.pdf
>  > > > Rajeev
>  > > Fabio Motezuki
>  > > >> Sent: Monday, October 27, 2008 5:35 AM
>  > > >> Subject: [mpich-discuss] mpich2 and IPoIB
>  > > >> Hi all,
>  > > >> I'm working on a cluster where each node is connected with two
>  > > >> networks:
>  > > >> eth0 - gigabit ethernet
>  > > >> ib0 - IP over infiniband
>  > > >> I would like to use the ib0 net for all mpi communications, but
>  > > >> when I start the example cpi all comunications go through eth0 is
>  > > this the
>  > > >> expected behavior?
>  > > >> I'm launching the example program with "mpiexec
>  > > -machinefile mf -n 16
>  > > >> ./cpi" where the file "mf" contains the ip address of infiniband
>  > > >> cards.
>  > > >> Fabio
