[mpich-discuss] need to compile unix code as windows exe
    Manal Helal
    manalorama at gmail.com
    Wed Oct 29 01:40:57 CDT 2008
Thank you for your reply,
sorry for not trying that, I always link with mpicc, but it is  not working
under cygwin so far,
I tried gcc -lmpi, it seems working better but I think the 0 kb libmpi.a
problem is the one now,
here is the output:
/cygdrive/f/Program Files/MPICH2/lib/libmpi.a: file not recognized: File
truncat
ed
collect2: ld returned 1 exit status
I tried repairing the windows mpich2, but the file didn't change, and I
unisiatlled and removed the Program Files/MPICH2, and still the file size is
0 kb, and the same output when linking with gcc
please advise,
thank you very much,
Manal
2008/10/29 Dmitri Chubarov <dmitri.chubarov at gmail.com>
> Normally you should specify -lmpi on the command line to link against
> libmpi.a the same holds for libmpich.a (-lmpich) or libm.a (-lm).
> That's a decades old UNIX convention. Would you please try that.
> On Wed, Oct 29, 2008 at 11:57 AM, Manal Helal <manalorama at gmail.com>
> wrote:
> > Hello
> > I tried the following from the configure script, just to create the
> > references for the windows installation:
> > ln -s libmpich.a libmpi.a
> > ln -s libmpich.so.1 libmpi.so.1
> > I just also found that the windows mpich2 installation installed a 0 kb
> > libmpi.a in the "Program Files\MPICH2\lib" path?!
> > I think I am on the wrong direction all together, please help,
> > Kind Regards,
> > Manal
> > 2008/10/29 Manal Helal <manalorama at gmail.com>
> >> I think I can make the gcc compiler see the mpi.h by adding the -I
> >> argument and the folder of the mpi.h and similarly the -L to the library
> >> path, this compiled the code with no problems.
> >> However it is not linking to libmpi or libmpi.a, giving me the following
> >> errors:
> >> /usr/lib/gcc/i686-pc-cygwin/3.4.4/../../../../i686-pc-cygwin/bin/ld:
> >> cannot find
> >>  -libmpi.a
> >> this happens when I use -libmpi or -libmpi.a in the gcc command
> >> I think this has to do with the library reference name not defined to
> link
> >> with, I am not sure how to solve this, google gives me general
> explanation
> >> on library names,
> >> I am not sure if I should post this in gcc or linux forums, but I hope
> >> someone here could help,
> >> thanks again,
> >> Manal
> >> 2008/10/28 Jayesh Krishna <jayesh at mcs.anl.gov>
> >>> Hi,
> >>>  There are two ways you can compile your MPI program using MPICH2 on
> >>> windows,
> >>> 1. Install MPICH2 on windows
> >>> # Use MS Visual Studio compiler to compile your MPI source to generate
> an
> >>> exe (Use mpi.lib while linking).
> >>> # Use gcc from cygwin to compile your MPI source (Use libmpi.a while
> >>> linking).
> >>> 2. Configure/make/install MPICH2 on Cygwin
> >>> # Use the mpicc script after installing MPICH2 to compile your MPI
> >>> program.
> >>>  Let us know if you need further information.
> >>> Regards,
> >>> Jayesh
> >>> ________________________________
> >>> From: owner-mpich-discuss at mcs.anl.gov
> >>> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Manal Helal
> >>> Sent: Sunday, October 26, 2008 11:31 PM
> >>> To: mpich-discuss at mcs.anl.gov
> >>> Subject: [mpich-discuss] need to compile unix code as windows exe
> >>> Hi
> >>> I need to compile Unix code under windows generating an exe file. I
> >>> downloaded cygwin with gcc and make (that what I use on Solaris and
> Linux
> >>> flavors) , and downloaded mpich2 for windows which didn't contain mpicc
> this
> >>> is what I use in my make files.
> >>> Will you please advise on the easiest efficient way to compile Unix
> code
> >>> on a windows platform and link to mpich in the compilation process?
> sorry if
> >>> it is a basic question, I searched google, and couldn't get an easy
> step by
> >>> step tutorial that covers all requirements.
> >>> Thank you very much in advance,
> >>> Kind Regards,
> >>> Manal
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081029/92ed277b/attachment.htm>
