[mpich-discuss] need to compile unix code as windows exe
    Manal Helal
    manalorama at gmail.com
    Wed Oct 29 00:38:57 CDT 2008
I think I can make the gcc compiler see the mpi.h by adding the -I argument
and the folder of the mpi.h and similarly the -L to the library path, this
compiled the code with no problems.
However it is not linking to libmpi or libmpi.a, giving me the following
errors:
/usr/lib/gcc/i686-pc-cygwin/3.4.4/../../../../i686-pc-cygwin/bin/ld: cannot
find
 -libmpi.a
collect2: ld returned 1 exit status
this happens when I use -libmpi or -libmpi.a in the gcc command
I think this has to do with the library reference name not defined to link
with, I am not sure how to solve this, google gives me general explanation
on library names,
I am not sure if I should post this in gcc or linux forums, but I hope
someone here could help,
thanks again,
Manal
2008/10/28 Jayesh Krishna <jayesh at mcs.anl.gov>
>  Hi,
>  There are two ways you can compile your MPI program using MPICH2 on
> windows,
> 1. Install MPICH2 on windows
> # Use MS Visual Studio compiler to compile your MPI source to generate an
> exe (Use mpi.lib while linking).
> # Use gcc from cygwin to compile your MPI source (Use libmpi.a while
> linking).
> 2. Configure/make/install MPICH2 on Cygwin
> # Use the mpicc script after installing MPICH2 to compile your MPI program.
>  Let us know if you need further information.
> Regards,
> Jayesh
> *From:* owner-mpich-discuss at mcs.anl.gov [mailto:
> owner-mpich-discuss at mcs.anl.gov] *On Behalf Of *Manal Helal
> *Sent:* Sunday, October 26, 2008 11:31 PM
> *To:* mpich-discuss at mcs.anl.gov
> *Subject:* [mpich-discuss] need to compile unix code as windows exe
> Hi
> I need to compile Unix code under windows generating an exe file. I
> downloaded cygwin with gcc and make (that what I use on Solaris and Linux
> flavors) , and downloaded mpich2 for windows which didn't contain mpicc this
> is what I use in my make files.
> Will you please advise on the easiest efficient way to compile Unix code on
> a windows platform and link to mpich in the compilation process? sorry if it
> is a basic question, I searched google, and couldn't get an easy step by
> step tutorial that covers all requirements.
> Thank you very much in advance,
> Kind Regards,
> Manal
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081029/0b253a86/attachment.htm>
