[mpich-discuss] Multiple mpds launched by one user on same machine
Rajeev Thakur thakur at mcs.anl.gov
Tue Oct 28 12:39:41 CDT 2008
You can use the "-1" option to mpdboot.
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at lists.mcs.anl.gov
> [mailto:mpich-discuss-bounces at lists.mcs.anl.gov] On Behalf Of
> Volker Amedick
> Sent: Tuesday, October 28, 2008 10:41 AM
> To: mpich-discuss at mcs.anl.gov
> Cc: volker.amedick at siemens.com
> Subject: [mpich-discuss] Multiple mpds launched by one user
> on same machine
> Hi,
> I have an issue with MPICH2 which I cannot resolve on my own.
> In our computer environment we have a multi-processor compute
> grid (SMP). The access to the compute grid is controlled by a
> queueing system called Condor which also manages the CPU
> resources of the grid. IT allows access to the compute grid
> only through Condor.
> When I now want to run a program using MPICH2 I submit a
> shell script to Condor that (1) launches a ring of mpds on
> the CPUs provided by Condor, (2) launches the program which
> uses MPICH2. When the program finishes, the shell script
> finishes also. As the script has finished the ring of mpds is
> stopped by Condor. This is working fine as long as I run only
> one job on the compute grid. When I submit a second job, I am
> not able to launch a 2nd ring of mpds on the same computer
> but need to use the existing ring of the 1st job.
> Unfortunately, when the 1st job has finished, its ring of
> mpds is stopped by Condor causing the 2nd job to fail as it
> lost connection to the mpds.
> To circumvent this issue I suggested to IT to run an mpd as
> root allowing other users to access root's ring of mpds. But
> IT declined as this might allow users to bypass Condor. Is
> there an alternative possibility to launch multiple rings of
> mpds on the same computer by the same user. And if so, how
> does a MPICH2 program then know to which ring of mpds it belongs.
> Any help is highly appreciated. Thanks in advance,
> Volker
> Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s
> mit allen: http://www.gmx.net/de/go/multimessenger
