[mpich-discuss] [PATCH] Make the CS_ENTER/EXIT macros start using device code again.
Joe Ratterman
jratt0 at gmail.com
Tue Nov 25 14:35:22 CST 2008
This adds more checks for "MPID_DEFINES_MPID_CS", successfully
removing the default macros from the compile. Using the DCMFd device,
it also shows how to update an existing device to provide all the
required macro replacements.
Use "patch -p2" to apply from within the mpich2/ dir in SVN/tarball.
Signed-off-by: Joe Ratterman <jratt at us.ibm.com>
mpich2/src/include/mpiimplthread.h | 8 ++-
mpich2/src/mpi/init/initthread.c | 2 +-
mpich2/src/mpid/dcmfd/include/mpidpre.h | 32 +----------
mpich2/src/mpid/dcmfd/include/mpidthread.h | 91 ++++++++++++++++++++++++++++
4 files changed, 100 insertions(+), 33 deletions(-)
create mode 100644 mpich2/src/mpid/dcmfd/include/mpidthread.h
diff --git a/mpich2/src/include/mpiimplthread.h b/mpich2/src/include/mpiimplthread.h
index 37afe7a..5c6dae4 100644
--- a/mpich2/src/include/mpiimplthread.h
+++ b/mpich2/src/include/mpiimplthread.h
@@ -221,6 +221,7 @@ int MPIR_Thread_CS_Finalize( void );
#endif
+#if !defined(MPID_DEFINES_MPID_CS)
#ifdef MPICH_IS_THREADED
#ifdef HAVE_RUNTIME_THREADCHECK
@@ -287,12 +288,14 @@ int MPIR_Thread_CS_Finalize( void );
#define MPIU_THREADSAFE_INIT_CLEAR(_var) _var=0
#define MPIU_THREADSAFE_INIT_BLOCK_END(_var)
#endif /* MPICH_IS_THREADED */
+#endif /* !defined(MPID_DEFINES_MPID_CS) */
* New definitions for controling the granularity of thread atomicity
/*M MPIU_THREAD_CS_ENTER - Enter a named critical section
@@ -371,8 +374,10 @@ M*/
#define MPIU_THREAD_CHECK_END
#define MPIU_ISTHREADED(_s)
-#endif
+#endif /* MPICH_IS_THREADED */
/* Helper definitions */
@@ -597,6 +602,7 @@ typedef struct MPIU_ThreadDebug {
#define MPIU_THREAD_CS_EXIT(_name,_context)
#define MPIU_THREAD_CS_YIELD(_name,_context)
+#endif /* !defined(MPID_DEFINES_MPID_CS)a */
#endif /* !defined(MPIIMPLTHREAD_H_INCLUDED) */
diff --git a/mpich2/src/mpi/init/initthread.c b/mpich2/src/mpi/init/initthread.c
index 4a2a1d1..d79f5a1 100644
--- a/mpich2/src/mpi/init/initthread.c
+++ b/mpich2/src/mpi/init/initthread.c
@@ -97,7 +97,7 @@ MPICH_PerThread_t MPIR_Thread = { 0 };
MPICH_PerThread_t MPIR_ThreadSingle = { 0 };
#endif
-#if defined(MPICH_IS_THREADED)
+#if defined(MPICH_IS_THREADED) && !defined(MPID_DEFINES_MPID_CS)
/* This routine is called when a thread exits; it is passed the value
associated with the key. In our case, this is simply storage allocated
with MPIU_Calloc */
diff --git a/mpich2/src/mpid/dcmfd/include/mpidpre.h b/mpich2/src/mpid/dcmfd/include/mpidpre.h
index 47ad308..08a7ff5 100644
--- a/mpich2/src/mpid/dcmfd/include/mpidpre.h
+++ b/mpich2/src/mpid/dcmfd/include/mpidpre.h
@@ -68,37 +68,7 @@ typedef DCQuad DCMF_CollectiveProtocol_t[1];
#endif /* !MPID_Dev_datatype_destroy_hook */
- * \brief Mutexes for interrupt driven mode
-#ifdef MPID_CS_ENTER
-#error "MPID_CS_ENTER is already defined"
-#endif
-#define MPID_DEFINES_MPID_CS 1
-#if (MPICH_THREAD_LEVEL != MPI_THREAD_MULTIPLE)
-#define MPID_CS_INITIALIZE() {}
-#define MPID_CS_FINALIZE() {}
-#define MPID_CS_ENTER() {}
-#define MPID_CS_EXIT() {}
-#define MPID_CS_CYCLE() {}
-#else
-#define MPID_CS_INITIALIZE() \
- /* Create thread local storage for nest count that MPICH uses */ \
- MPID_Thread_tls_create(NULL, &MPIR_ThreadInfo.thread_storage, NULL); \
-#define MPID_CS_FINALIZE() \
- /* Destroy thread local storage created during MPID_CS_INITIALIZE */\
- MPID_Thread_tls_destroy(&MPIR_ThreadInfo.thread_storage, NULL); \
-#define MPID_CS_ENTER() DCMF_CriticalSection_enter(0);
-#define MPID_CS_EXIT() DCMF_CriticalSection_exit(0);
-#define MPID_CS_CYCLE() DCMF_CriticalSection_cycle(0);
-#endif
+#include <mpidthread.h>
typedef int MPIDI_VCR;
typedef struct MPIDI_VCRT * MPID_VCRT;
diff --git a/mpich2/src/mpid/dcmfd/include/mpidthread.h b/mpich2/src/mpid/dcmfd/include/mpidthread.h
new file mode 100644
index 0000000..eb49a30
--- /dev/null
+++ b/mpich2/src/mpid/dcmfd/include/mpidthread.h
@@ -0,0 +1,91 @@
+/* (C)Copyright IBM Corp. 2007, 2008 */
+ * \file include/mpidthread.h
+ * \brief ???
+ * (C) 2001 by Argonne National Laboratory.
+ * See COPYRIGHT in top-level directory.
+#ifndef MPICH_MPIDTHREAD_H_INCLUDED
+#define MPICH_MPIDTHREAD_H_INCLUDED
+ * \brief Mutexes for thread/interrupt safety
+#ifdef MPID_CS_ENTER
+#error "MPID_CS_ENTER is already defined"
+#endif
+#define MPID_DEFINES_MPID_CS 1
+#if (MPICH_THREAD_LEVEL != MPI_THREAD_MULTIPLE)
+#define MPID_CS_INITIALIZE() {}
+#define MPID_CS_FINALIZE() {}
+#define MPID_CS_ENTER() {}
+#define MPID_CS_EXIT() {}
+#define MPID_CS_CYCLE() {}
+#define MPIU_THREAD_CHECK_BEGIN
+#define MPIU_THREAD_CHECK_END
+#define MPIU_THREAD_CS_ENTER(_name,_context)
+#define MPIU_THREAD_CS_EXIT(_name,_context)
+#define MPIU_THREAD_CS_YIELD(_name,_context)
+#define MPIU_THREADSAFE_INIT_DECL(_var) static int _var=1
+#define MPIU_THREADSAFE_INIT_STMT(_var,_stmt) if (_var) { _stmt; _var = 0; }
+#define MPIU_THREADSAFE_INIT_BLOCK_BEGIN(_var)
+#define MPIU_THREADSAFE_INIT_CLEAR(_var) _var=0
+#define MPIU_THREADSAFE_INIT_BLOCK_END(_var)
+#else
+#define HAVE_RUNTIME_THREADCHECK
+#define MPIU_THREAD_CHECK_BEGIN if (MPIR_ThreadInfo.isThreaded) {
+#define MPIU_THREAD_CHECK_END }
+#define MPIU_THREAD_CS_ENTER(_name,_context) DCMF_CriticalSection_enter(0);
+#define MPIU_THREAD_CS_EXIT(_name,_context) DCMF_CriticalSection_exit(0);
+#define MPIU_THREAD_CS_YIELD(_name,_context) DCMF_CriticalSection_cycle(0);
+#define MPIU_THREADSAFE_INIT_DECL(_var) static volatile int _var=1
+#define MPIU_THREADSAFE_INIT_STMT(_var,_stmt) \
+ if (_var) { \
+ MPIU_THREAD_CS_ENTER(INITFLAG,); \
+ _stmt; _var=0; \
+ MPIU_THREAD_CS_EXIT(INITFLAG,); \
+#define MPIU_THREADSAFE_INIT_BLOCK_BEGIN(_var) \
+ if (_var) {
+#define MPIU_THREADSAFE_INIT_BLOCK_END(_var) \
+#define MPID_CS_INITIALIZE() \
+ /* Create thread local storage for nest count that MPICH uses */ \
+ MPID_Thread_tls_create(NULL, &MPIR_ThreadInfo.thread_storage, NULL); \
+#define MPID_CS_FINALIZE() \
+ /* Destroy thread local storage created during MPID_CS_INITIALIZE */ \
+ MPID_Thread_tls_destroy(&MPIR_ThreadInfo.thread_storage, NULL); \
+#define MPID_CS_ENTER() DCMF_CriticalSection_enter(0);
+#define MPID_CS_EXIT() DCMF_CriticalSection_exit(0);
+#define MPID_CS_CYCLE() DCMF_CriticalSection_cycle(0);
+#endif
+#define MPIU_ISTHREADED(_s) { MPIU_THREAD_CHECK_BEGIN _s MPIU_THREAD_CHECK_END }
+#endif /* !MPICH_MPIDTHREAD_H_INCLUDED */
1.6.0.4.1.g57b5
