[mpich-discuss] Error with MPI_Comm_spawn on MPICH2
    Shah, Mrunal J
    mrunal.shah at gatech.edu
    Mon Nov 24 23:56:59 CST 2008
Thanks a lot.
That solves it. I'll upgrade to 1.1a2.
Thanks again!
Mrunal
----- Original Message -----
Sent: Tuesday, November 25, 2008 12:53:52 AM GMT -05:00 US/Canada Eastern
Subject: Re: [mpich-discuss] Error with MPI_Comm_spawn on MPICH2
The default netmod in ch3:nemesis doesn't support dynamic processes in
the 1.0.x series of MPICH2. You can either upgrade to 1.1a2 (preferred),
or configure mpich2 with --with-device=ch3:sock if you want to stick
with 1.0.8.
  -- Pavan
On 11/24/2008 11:48 PM, Shah, Mrunal J wrote:
> mpich2version
> MPICH2 Version:         1.0.8
> MPICH2 Release date:    Unknown, built on Fri Nov  7 23:45:25 EST 2008
> MPICH2 Device:          ch3:nemesis
> MPICH2 configure:       --prefix=/usr/local/apps/mpich2/1.0.8-nemesis--x86_64-gcc4.3.2 --with-device=ch3:nemesis
> MPICH2 CC:      gcc  -O2
> MPICH2 CXX:     c++  -O2
> MPICH2 F77:     g77  -O2
> MPICH2 F90:     pgf90
> Am using MPD.
> To launch my app I use
> mpd &
> mpiexec -n 4 ./newspawn
> Thanks
> Mrunal
> From: "Pavan Balaji" <balaji at mcs.anl.gov>
> Sent: Tuesday, November 25, 2008 12:29:14 AM GMT -05:00 US/Canada Eastern
> Mrunal,
> You can install mpich2 in your home directory without any root access to
> try it out.
> But before you do that, can you let us know what process manager you are
> using? Can you send us the output for "mpich2version" and also the steps
> you are following to launch your application?
>   -- Pavan
> On 11/24/2008 11:26 PM, Shah, Mrunal J wrote:
>> Thanks Rajeev,
>> I am student at Georgia Tech and am working on an MPICH installation present on one of the college clusters.
>> I will ask for permissions to re install it and let you know if I see anything out of the ordinary.
>> Thanks a lot again!
>> Mrunal
>> From: "Rajeev Thakur" <thakur at mcs.anl.gov>
>> Sent: Monday, November 24, 2008 11:59:40 PM GMT -05:00 US/Canada Eastern
>> I can run this with 1.0.8 without any problem. The program is too simple to
>> fail. Probably something wrong with your installation. Did you use any
>> special configure options or compilers? Try starting from scratch again with
>> a fresh untar of the tar file. If you notice anything unusual in the output
>> of configure and make that is printed on the screen, send it to us.
>> Rajeev
>>> -----Original Message-----
>>> From: mpich-discuss-bounces at mcs.anl.gov
>>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Shah, Mrunal J
>>> Sent: Monday, November 24, 2008 10:33 PM
>>> #include "mpi.h"
>>> #include <stdio.h>
>>> int main(int argc, char **argv)
>>>         int size, myRank;
>>>         MPI_Comm parent;
>>>         MPI_Init(&argc, &argv);
>>>         MPI_Comm_get_parent(&parent);
>>>         MPI_Comm_rank(MPI_COMM_WORLD, &myRank);
>>>         MPI_Comm_remote_size(parent, &size);
>>>         printf("IN WORKER: parent size %d\n", size);
>>>         printf("\nhello from worker %d", myRank);
>>>         MPI_Finalize();
>>>         return 0;
>>> Thanks again!
>>> Mrunal
>>> Sent: Monday, November 24, 2008 11:20:42 PM GMT -05:00
>>> US/Canada Eastern
>>> Can you send the worker program as well?
>>> Rajeev
>>> Shah, Mrunal J
>>>> Sent: Monday, November 24, 2008 10:18 PM
>>>> Using 1.0.8
>>>> Running on a x86_64 machine
>>>> The test program:
>>>> #include "mpi.h"
>>>>         int world_size, flag, myRank;
>>>>         MPI_Comm everyone;
>>>>         MPI_Comm_size(MPI_COMM_WORLD, &world_size);
>>>>         printf("world_size %d\n", world_size);
>>>>         MPI_Comm_spawn("./workertest", MPI_ARGV_NULL, world_size,
>>>> MPI_INFO_NULL, 0, MPI_COMM_WORLD, &everyone, MPI_ERRCODES_IGNORE);
>>>>         printf("hello from master %d", myRank);
>>>>         MPI_Finalize();
>>>>         return 0;
>>>> Thanks,
>>>> Mrunal
>>>> Sent: Monday, November 24, 2008 11:04:03 PM GMT -05:00 US/Canada
>>>> Eastern
>>>> Which version of MPICH2 are you using and on what platform?
>>>> Please send us a small test program if you can.
>>>> Rajeev
>>>> Shah, Mrunal J
>>>>> Sent: Monday, November 24, 2008 8:32 PM
>>>>> Subject: [mpich-discuss] Error with MPI_Comm_spawn on MPICH2
>>>>> Hi All,
>>>>> I am having issues with spawning processes using MPI_Comm_spawn.
>>>>> Using a simple example for spawning processes:
>>>>> The error I get is:
>>>>> Fatal error in MPI_Comm_spawn: Internal MPI error!, error stack:
>>>>> MPI_Comm_spawn(130)............:
>>>>> MPI_Comm_spawn(cmd="./workertest", argv=(nil), maxprocs=4,
>>>>> MPI_INFO_NULL, root=0, MPI_COMM_WORLD, intercomm=0x7fbffff6ac,
>>>>> errors=(nil)) failed
>>>>> MPIDI_Comm_spawn_multiple(172).:
>>>>> MPID_Open_port(65).............:
>>>>> MPIDI_CH3_Get_business_card(99): Internal MPI
>>> error!universe_size 1
>>>>> I believe this could be a machine specific error, since
>>> running the
>>>>> same code on another machine with a different
>>> implementation of MPI
>>>>> (OpenMPI) does not give any errors.
>>>>> But I am not sure what I am missing here.
>>>>> Thanks!
>>>>> Mrunal
Pavan Balaji
http://www.mcs.anl.gov/~balaji
