[mpich-discuss] mpdboot failure
Cesar Covarrubias cesar at uci.edu
Tue Nov 18 13:14:58 CST 2008
Hello,
We are still having trouble getting mpd running on a large number of our
nodes. The error we get is mpdboot_bduc-sched.nacs.uci.edu
(handle_mpd_output 392): failed to handshake with mpd on bduc-i32-6;
recvd output={}. The problem is that it the node it chooses to fail on
is random. It is not always the same node. All nodes have
the /etc/mpd.conf file chmod'ed to 600. mpd is not running on any of the
nodes. The mpdcheck returns no errors (as you can see by the output
below). All the nodes are on a private subnet.
Ideas as to why this is failing?
Very Respectfully,
Cesar Covarrubias
-bash-3.2# mpdcheck -f mpd.hosts -ssh -v
obtaining hostname via gethostname and getfqdn
gethostname gives  bduc-sched.nacs.uci.edu
getfqdn gives  bduc-sched.nacs.uci.edu
checking out unqualified hostname; make sure is not "localhost", etc.
checking out qualified hostname; make sure is not "localhost", etc.
obtain IP addrs via qualified and unqualified hostnames;  make sure
other than 127.0.0.1
gethostbyname_ex:  ('bduc-sched.nacs.uci.edu', ['bduc-sched'],
['128.200.15.19'])
['128.200.15.19'])
checking that IP addrs resolve to same host
now do some gethostbyaddr and gethostbyname_ex for machines in hosts
filechecking gethostbyXXX for unqualified bduc-i32-1
gethostbyname_ex:  ('bduc-i32-1', [], ['192.168.0.10'])
checking gethostbyXXX for qualified bduc-i32-1
checking gethostbyXXX for unqualified bduc-i32-3
gethostbyname_ex:  ('bduc-i32-3', [], ['192.168.0.12'])
checking gethostbyXXX for qualified bduc-i32-3
checking gethostbyXXX for unqualified bduc-i32-4
gethostbyname_ex:  ('bduc-i32-4', [], ['192.168.0.13'])
checking gethostbyXXX for qualified bduc-i32-4
checking gethostbyXXX for unqualified bduc-i32-5
gethostbyname_ex:  ('bduc-i32-5', [], ['192.168.0.14'])
checking gethostbyXXX for qualified bduc-i32-5
checking gethostbyXXX for unqualified bduc-i32-6
gethostbyname_ex:  ('bduc-i32-6', [], ['192.168.0.15'])
checking gethostbyXXX for qualified bduc-i32-6
checking gethostbyXXX for unqualified bduc-i32-7
gethostbyname_ex:  ('bduc-i32-7', [], ['192.168.0.16'])
checking gethostbyXXX for qualified bduc-i32-7
checking gethostbyXXX for unqualified bduc-i32-8
gethostbyname_ex:  ('bduc-i32-8', [], ['192.168.0.17'])
checking gethostbyXXX for qualified bduc-i32-8
checking gethostbyXXX for unqualified bduc-i32-9
gethostbyname_ex:  ('bduc-i32-9', [], ['192.168.0.18'])
checking gethostbyXXX for qualified bduc-i32-9
checking gethostbyXXX for unqualified bduc-i32-10
gethostbyname_ex:  ('bduc-i32-10', [], ['192.168.0.19'])
checking gethostbyXXX for qualified bduc-i32-10
checking gethostbyXXX for unqualified bduc-i32-11
gethostbyname_ex:  ('bduc-i32-11', [], ['192.168.0.20'])
checking gethostbyXXX for qualified bduc-i32-11
checking gethostbyXXX for unqualified bduc-i32-12
gethostbyname_ex:  ('bduc-i32-12', [], ['192.168.0.21'])
checking gethostbyXXX for qualified bduc-i32-12
checking gethostbyXXX for unqualified bduc-i32-13
gethostbyname_ex:  ('bduc-i32-13', [], ['192.168.0.22'])
checking gethostbyXXX for qualified bduc-i32-13
checking gethostbyXXX for unqualified bduc-i32-14
gethostbyname_ex:  ('bduc-i32-14', [], ['192.168.0.23'])
checking gethostbyXXX for qualified bduc-i32-14
checking gethostbyXXX for unqualified bduc-i32-15
gethostbyname_ex:  ('bduc-i32-15', [], ['192.168.0.24'])
checking gethostbyXXX for qualified bduc-i32-15
checking gethostbyXXX for unqualified bduc-i32-16
gethostbyname_ex:  ('bduc-i32-16', [], ['192.168.0.25'])
checking gethostbyXXX for qualified bduc-i32-16
checking gethostbyXXX for unqualified bduc-i32-17
gethostbyname_ex:  ('bduc-i32-17', [], ['192.168.0.26'])
checking gethostbyXXX for qualified bduc-i32-17
checking gethostbyXXX for unqualified bduc-i32-18
gethostbyname_ex:  ('bduc-i32-18', [], ['192.168.0.27'])
checking gethostbyXXX for qualified bduc-i32-18
checking gethostbyXXX for unqualified bduc-i32-19
gethostbyname_ex:  ('bduc-i32-19', [], ['192.168.0.28'])
checking gethostbyXXX for qualified bduc-i32-19
checking gethostbyXXX for unqualified bduc-i32-20
gethostbyname_ex:  ('bduc-i32-20', [], ['192.168.0.29'])
checking gethostbyXXX for qualified bduc-i32-20
checking gethostbyXXX for unqualified bduc-i32-21
gethostbyname_ex:  ('bduc-i32-21', [], ['192.168.0.30'])
checking gethostbyXXX for qualified bduc-i32-21
checking gethostbyXXX for unqualified bduc-i32-22
gethostbyname_ex:  ('bduc-i32-22', [], ['192.168.0.31'])
checking gethostbyXXX for qualified bduc-i32-22
checking gethostbyXXX for unqualified bduc-i32-24
gethostbyname_ex:  ('bduc-i32-24', [], ['192.168.0.33'])
checking gethostbyXXX for qualified bduc-i32-24
checking gethostbyXXX for unqualified bduc-i32-25
gethostbyname_ex:  ('bduc-i32-25', [], ['192.168.0.34'])
checking gethostbyXXX for qualified bduc-i32-25
checking gethostbyXXX for unqualified bduc-i32-27
gethostbyname_ex:  ('bduc-i32-27', [], ['192.168.0.36'])
checking gethostbyXXX for qualified bduc-i32-27
checking gethostbyXXX for unqualified bduc-i32-28
gethostbyname_ex:  ('bduc-i32-28', [], ['192.168.0.37'])
checking gethostbyXXX for qualified bduc-i32-28
checking gethostbyXXX for unqualified bduc-i32-29
gethostbyname_ex:  ('bduc-i32-29', [], ['192.168.0.38'])
checking gethostbyXXX for qualified bduc-i32-29
checking gethostbyXXX for unqualified bduc-i32-30
gethostbyname_ex:  ('bduc-i32-30', [], ['192.168.0.39'])
checking gethostbyXXX for qualified bduc-i32-30
checking gethostbyXXX for unqualified bduc-i32-31
gethostbyname_ex:  ('bduc-i32-31', [], ['192.168.0.40'])
checking gethostbyXXX for qualified bduc-i32-31
checking gethostbyXXX for unqualified bduc-i32-32
gethostbyname_ex:  ('bduc-i32-32', [], ['192.168.0.41'])
checking gethostbyXXX for qualified bduc-i32-32
checking gethostbyXXX for unqualified bduc-i32-33
gethostbyname_ex:  ('bduc-i32-33', [], ['192.168.0.42'])
checking gethostbyXXX for qualified bduc-i32-33
checking gethostbyXXX for unqualified bduc-i32-34
gethostbyname_ex:  ('bduc-i32-34', [], ['192.168.0.43'])
checking gethostbyXXX for qualified bduc-i32-34
checking gethostbyXXX for unqualified bduc-i32-35
gethostbyname_ex:  ('bduc-i32-35', [], ['192.168.0.44'])
checking gethostbyXXX for qualified bduc-i32-35
checking gethostbyXXX for unqualified bduc-i32-36
gethostbyname_ex:  ('bduc-i32-36', [], ['192.168.0.45'])
checking gethostbyXXX for qualified bduc-i32-36
checking gethostbyXXX for unqualified bduc-i32-37
gethostbyname_ex:  ('bduc-i32-37', [], ['192.168.0.46'])
checking gethostbyXXX for qualified bduc-i32-37
checking gethostbyXXX for unqualified bduc-i32-38
gethostbyname_ex:  ('bduc-i32-38', [], ['192.168.0.47'])
checking gethostbyXXX for qualified bduc-i32-38
checking gethostbyXXX for unqualified bduc-i32-39
gethostbyname_ex:  ('bduc-i32-39', [], ['192.168.0.48'])
checking gethostbyXXX for qualified bduc-i32-39
checking gethostbyXXX for unqualified bduc-i32-40
gethostbyname_ex:  ('bduc-i32-40', [], ['192.168.0.49'])
checking gethostbyXXX for qualified bduc-i32-40
trying: ssh bduc-i32-1 -x -n /bin/echo hello
trying: ssh bduc-i32-3 -x -n /bin/echo hello
trying: ssh bduc-i32-4 -x -n /bin/echo hello
trying: ssh bduc-i32-5 -x -n /bin/echo hello
trying: ssh bduc-i32-6 -x -n /bin/echo hello
trying: ssh bduc-i32-7 -x -n /bin/echo hello
trying: ssh bduc-i32-8 -x -n /bin/echo hello
trying: ssh bduc-i32-9 -x -n /bin/echo hello
trying: ssh bduc-i32-10 -x -n /bin/echo hello
trying: ssh bduc-i32-11 -x -n /bin/echo hello
trying: ssh bduc-i32-12 -x -n /bin/echo hello
trying: ssh bduc-i32-13 -x -n /bin/echo hello
trying: ssh bduc-i32-14 -x -n /bin/echo hello
trying: ssh bduc-i32-15 -x -n /bin/echo hello
trying: ssh bduc-i32-16 -x -n /bin/echo hello
trying: ssh bduc-i32-17 -x -n /bin/echo hello
trying: ssh bduc-i32-18 -x -n /bin/echo hello
trying: ssh bduc-i32-19 -x -n /bin/echo hello
trying: ssh bduc-i32-20 -x -n /bin/echo hello
trying: ssh bduc-i32-21 -x -n /bin/echo hello
trying: ssh bduc-i32-22 -x -n /bin/echo hello
trying: ssh bduc-i32-24 -x -n /bin/echo hello
trying: ssh bduc-i32-25 -x -n /bin/echo hello
trying: ssh bduc-i32-27 -x -n /bin/echo hello
trying: ssh bduc-i32-28 -x -n /bin/echo hello
trying: ssh bduc-i32-29 -x -n /bin/echo hello
trying: ssh bduc-i32-30 -x -n /bin/echo hello
trying: ssh bduc-i32-31 -x -n /bin/echo hello
trying: ssh bduc-i32-32 -x -n /bin/echo hello
trying: ssh bduc-i32-33 -x -n /bin/echo hello
trying: ssh bduc-i32-34 -x -n /bin/echo hello
trying: ssh bduc-i32-35 -x -n /bin/echo hello
trying: ssh bduc-i32-36 -x -n /bin/echo hello
trying: ssh bduc-i32-37 -x -n /bin/echo hello
trying: ssh bduc-i32-38 -x -n /bin/echo hello
trying: ssh bduc-i32-39 -x -n /bin/echo hello
trying: ssh bduc-i32-40 -x -n /bin/echo hello
starting server: /sge62/mpich2/bin/mpdcheck.py -s
starting client: ssh bduc-i32-1 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 43076
starting client: ssh bduc-i32-3 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 38649
starting client: ssh bduc-i32-4 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 40831
starting client: ssh bduc-i32-5 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 57153
starting client: ssh bduc-i32-6 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 60407
starting client: ssh bduc-i32-7 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 52646
starting client: ssh bduc-i32-8 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 47523
starting client: ssh bduc-i32-9 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 50172
starting client: ssh bduc-i32-10 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 51821
starting client: ssh bduc-i32-11 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 36082
starting client: ssh bduc-i32-12 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 57250
starting client: ssh bduc-i32-13 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 47474
starting client: ssh bduc-i32-14 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 51971
starting client: ssh bduc-i32-15 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 54481
starting client: ssh bduc-i32-16 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 49851
starting client: ssh bduc-i32-17 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 33898
starting client: ssh bduc-i32-18 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 56621
starting client: ssh bduc-i32-19 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 37119
starting client: ssh bduc-i32-20 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 38601
starting client: ssh bduc-i32-21 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 43570
starting client: ssh bduc-i32-22 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 42130
starting client: ssh bduc-i32-24 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 41582
starting client: ssh bduc-i32-25 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 50515
starting client: ssh bduc-i32-27 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 48864
starting client: ssh bduc-i32-28 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 47361
starting client: ssh bduc-i32-29 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 44604
starting client: ssh bduc-i32-30 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 41417
starting client: ssh bduc-i32-31 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 48330
starting client: ssh bduc-i32-32 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 47243
starting client: ssh bduc-i32-33 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 35428
starting client: ssh bduc-i32-34 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 59147
starting client: ssh bduc-i32-35 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 54136
starting client: ssh bduc-i32-36 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 56116
starting client: ssh bduc-i32-37 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 59475
starting client: ssh bduc-i32-38 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 52834
starting client: ssh bduc-i32-39 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 58080
starting client: ssh bduc-i32-40 -x -n /sge62/mpich2/bin/mpdcheck.py -c
bduc-sched.nacs.uci.edu 57115
